NEED STROKER ADVISE #2438160
01/20/18 11:18 PM
01/20/18 11:18 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Need some advise on cylinder heads for my next engine build. The car is a 68 Charger, auto, 3:54 rear. I've been working on the car for about a year upgrading it to handle the more powerful engine. Chassis, brakes, cooling, rear, suspension, is complete and drivetrain is next. Transmission will be from Cope. Converter wont be picked until engine is run on he dyno. Engine will be 400 block with 440 source stroker kit. Final cubic inch should be about 512. A couple of things about the car: not a race car, 100% street. It will not hook up. I'm unwilling to cut the car for the appropriate suspension to make it hook up. Everything has to fit under the stock hood. That will restrict intake and I'm good with that. Finally, torque is more important than HP. Big engine is bragging rights and for fun. So that being said, Trick flow is at the top of the list. Which head would work better for this application: 240 or 270? Cam will be hydraulic roller. Secondly, knowing that this engine will make more useable power than really needed, would it better to go the Eddy heads? I have a 496 with Eddy heads (with some work done to them) and it's a hell of a fun car to drive. The engine will be professionally built and all necessary upgrades complied with. Is there another option? Finally, I don't mind paying more for better parts. Your thoughts?
Frank
Re: NEED STROKER ADVISE [Re: frank] #2438191
01/21/18 12:03 AM
01/21/18 12:03 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
I have a 400/470 with E-heads in a E-body. If I was ever to build a bigger motor, I would use the TF240 heads. Those will give you room to grow if you ever change your mind about what you want out of the car, but still work quite well on the street with your CI. The right cam and intake will make a street torque monster. Call around for advise on the cam, and then pick the intake that works best. I don't know enough about Chargers to tell you which intake will fit under the stock hood.
Re: NEED STROKER ADVISE [Re: davenc] #2438197
01/21/18 12:11 AM
01/21/18 12:11 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Trickflow Powerport 240 heads
Howards .545 Hydraulic roller
HOLLEY Street Dominator intake
Cal-trac setup with adjustable shocks
Mickey Thompson ET Street Pro's
'63 Dodge 330
11.19 @ 121 mph
Re: NEED STROKER ADVISE [Re: GY3] #2438220
01/21/18 12:49 AM
01/21/18 12:49 AM
tucson az
frank Offline OP
frank  Offline OP
tucson az
How is the ride with the Cal Tracs? That was on the list but I figured just go stock with a snubber. Have a SD on my 496 and hood just barely closes but that's a 440 block n96 car
Re: NEED STROKER ADVISE [Re: frank] #2438238
01/21/18 01:40 AM
01/21/18 01:40 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
However you want it to be.
The ride is more dependent upon the shocks and springs you have. I have mine set to where there's about a nickel width between the pivot and the spring. Some people add preload. My family rides in it and never has an issue.
'63 Dodge 330
11.19 @ 121 mph
Re: NEED STROKER ADVISE [Re: frank] #2438251
01/21/18 02:14 AM
01/21/18 02:14 AM
AndyF Offline
AndyF  Offline
Head choice for a street car should take into account the exhaust system. If you are going to run headers then make sure you can find a set that works with the angle plugs. If you are going to use manifolds then you probably want to run a straight plug head.
I think the 240 head is the best choice for your engine if you can find a header that fits properly. You might be able to fit a 383 Performer RPM under the hood but you'll just have to check it.
Another way to go would be EFI. A throttle body is shorter than a carb so that might help with hood clearance. Also, the engine will run better with EFI and it will last longer.
Re: NEED STROKER ADVISE [Re: frank] #2438255
01/21/18 02:27 AM
01/21/18 02:27 AM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Exhaust will be TTI 3 inch with TTI 1 7/8 headers
Re: NEED STROKER ADVISE [Re: frank] #2438265
01/21/18 03:05 AM
01/21/18 03:05 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
TTI part# 383-178 has a couple foot notes under their product ID section.
It doesn't list T/F heads. I don't know what the diff. is between those and EZ's??? Also, one note says built for angled plug clearance.
Re: NEED STROKER ADVISE [Re: Dave Hall] #2438269
01/21/18 03:29 AM
01/21/18 03:29 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
1350 joints, u-bolts instead of bolts and straps for the rear yoke and good screw in studs for the rear axles are all going to be necessary if you have sticky tires and abuse it often. Trust me on this...
You said 3.54 gears so I'm assuming Dana 60?
'63 Dodge 330
11.19 @ 121 mph
Re: NEED STROKER ADVISE [Re: frank] #2438287
01/21/18 06:15 AM
01/21/18 06:15 AM
sweden
carter Offline
carter  Offline
sweden
512ci sitting in a bone stock E-body, 3860 with driver. This is my weekend cruiser that see a track once or twice a year. Beating on it for two summers since I built it, old school and simple.
4.25 x 4.375. B-block
TF 240 OOTB. 802-COO
10.4:1
Holley 850 DP (4781)
Holley SD intake with 1" open spacer
MP .528 with 1.6 rockers
6 Quarter "Hemi pan"
MP Dist 18°/36°
Carter mech fuel pump with 3/8" original fuel line
TTI 1 7/8 headers with full 3" exhaust
Not a -68 B-body but a 14" aircleaner with 4" filter fits under the hood on my E-Body. Im very satisfied with my TF 240 heads, engine is very snappy and fun to drive on the street.
Re: NEED STROKER ADVISE [Re: carter] #2438296
01/21/18 09:32 AM
01/21/18 09:32 AM
IN
ahy Offline
ahy  Offline
IN
For headers, 1 7/8" TTI's were listed for the RPM heads I run in an E and fit as advertised. I told TTI I would be running Ed heads and I believe they put some small reliefs in to help with the angle plugs.
For intake, as Andy says, EFI helps. I fit a M1 single plane under a flat E hood with short EFI throttle body and mild drop base air cleaner.
Re: NEED STROKER ADVISE [Re: frank] #2438298
01/21/18 09:48 AM
01/21/18 09:48 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Depending on what your doing with cam and power goals, consider the 440-2D intake. It is tight with hood clearance, but you can make it work.
Re: NEED STROKER ADVISE [Re: frank] #2438392
01/21/18 01:49 PM
01/21/18 01:49 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
400 block.......cant use the 440-2D ......... unless you’re running stage 6 heads.
Sounds like the OP has a good handle on what he wants.
None of the low deck manifolds that will fit the TF270 heads are really compatible with how the OP is describing the way the car will be used.
I’d suggest the 240 heads and an SD or RPM manifold.
Re: NEED STROKER ADVISE [Re: frank] #2438430
01/21/18 02:58 PM
01/21/18 02:58 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
I have a 400 stroked to 505 in my Challenger. TF 240 heads and TTI headers.
I have a 2 inch scoop on my hood and I have a victor intake so that won't help you any.
If you go with the TF heads just make sure you get the right rocker setup.
I have the Harland Sharp set for Mopar heads but they are too long and don't hit the valve stem right. I have the HS set coming that are made for the TF heads.
Re: NEED STROKER ADVISE [Re: patosmith] #2438465
01/21/18 04:18 PM
01/21/18 04:18 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Was there any problem with the TTI fit on the 240? Is HS the only rockers for these heads or are they the best working rockers for these heads?
Re: NEED STROKER ADVISE [Re: frank] #2438467
01/21/18 04:27 PM
01/21/18 04:27 PM
AndyF Offline
AndyF  Offline
I tested a bunch of rocker arms on the 240 heads. They all work, just need to pick the price range that you are comfortable with.
http://www.hotrod.com/articles/trying-find-extra-power-rocker-arm-testing/
Re: NEED STROKER ADVISE [Re: fast68plymouth] #2438490
01/21/18 05:14 PM
01/21/18 05:14 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Ooooops
Re: NEED STROKER ADVISE [Re: AndyF] #2439132
01/22/18 06:29 PM
01/22/18 06:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
EFI........... down Learn how to tune the "original" bad ass fuel/air metering manifold cooling device and you'll "get it"..........It's funny to me that you're suggesting/running EFI on your street cars after all of that max hp carb stuff you posted in your book and on here........ work beer
Re: NEED STROKER ADVISE [Re: AndyF] #2439142
01/22/18 06:54 PM
01/22/18 06:54 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i put a performer RPM manifold on my dads 69 charger with factory hood.
aftermarket mild drop base air cleaner, 3" element i think.
906 heads, 383, holley 3310 and i think a .50" spacer.
should be able to make a performer RPM fit unless the TF heads put the manifold in a different spot somehow..
Re: NEED STROKER ADVISE [Re: frank] #2439153
01/22/18 07:06 PM
01/22/18 07:06 PM
USA, CA, Los Angeles
Thilove Offline
Thilove  Offline
thanks a lot for all the information i found here. been wondering about some things about my stroker and i found a lot of useful info here. thanks. i was just wondering if i can ask questions here? i'm new here. thanks
