Re: Electrical good, won't turn over
[Re: poorboy]
#2437740
01/19/18 11:56 PM
01/19/18 11:56 PM
RapidRobert
What Gene said, ground the clutch switch male terminal that's on the starter relay & see if it will (now) crank. see if the yellow "ign" wire at the starter relay is hot when the key is turned to "start".
[Re: Moparmaniacc]
#2438136
01/20/18 10:21 PM
01/20/18 10:21 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Any little exhaust leak will cause a backfire on decal....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
