Hellcat crate? #2436857
01/18/18 02:37 PM
01/18/18 02:37 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Just curious, does anyone know what the Hellcat crate motor weighs? I know they recommend the six speed. But has anyone tried a built 727 behind one yet. Curious how it would run with only 3 gears. Also what kind of times do you think a proper setup e body run with the 707 HP calibration Crate run? Thanks
Re: Hellcat crate? [Re: 70VcodeCoronetRT] #2437330
01/19/18 05:29 AM
01/19/18 05:29 AM
houston texas
gremlinsteve Offline
houston texas
It would be an awesome ride
No reason that a built 727 wouldn't work
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Hellcat crate? [Re: 70VcodeCoronetRT] #2437365
01/19/18 11:00 AM
01/19/18 11:00 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Weight should be around 650,
Long Block is around 400lbs no accessories.
https://www.youtube.com/watch?v=tRRWyO0RoYI
727 behind any Hemi is a good choice.
Re: Hellcat crate? [Re: 70VcodeCoronetRT] #2446551
02/04/18 10:45 PM
02/04/18 10:45 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
How about how it runs with only 2-gears!
https://www.youtube.com/watch?v=4DO2KLsbsYc
Re: Hellcat crate? [Re: 70VcodeCoronetRT] #2448339
02/08/18 03:30 AM
02/08/18 03:30 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I would say it would run in the low 10's and in the high 9's with a set up chassis ...
