replacing carb on 383 eng
#2435863
01/16/18 08:04 PM
01/16/18 08:04 PM
Posts: 514 georgia
moparpro
georgia
this one has a electric choke,where should i run the positive wire from choke to for power?what guage wire to run.stock set up.thanks
Re: replacing carb on 383 eng
[Re: moparpro]
#2435948
01/16/18 10:17 PM
01/16/18 10:17 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
Maybe tap the wire into the blue "run" wire off the ignition? I'm not sure what is stock. I guess you could run the wire to a switch if you wanted to.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: moparpro]
#2436086
01/17/18 01:19 AM
01/17/18 01:19 AM
Posts: 5,445 So Cal
Sinitro
So Cal
EZ to do.. Get a dual male 0.25" tab connector to a 0.25" female tab connector available everywhere. Connect to 12V input terminal on the ballast resistor, reconnect the original lead to 1 side of the dual tab connector and run a separate wire lead from the other side of the dual tab connector to the choke... No cutting or splicing, very clean.. Just my $0.02..
[Re: Sinitro]
#2436384
01/17/18 04:17 PM
01/17/18 04:17 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
EZ to do.. Get a dual male 0.25" tab connector to a 0.25" female tab connector available everywhere. Connect to 12V input terminal on the ballast resistor, reconnect the original lead to 1 side of the dual tab connector and run a separate wire lead from the other side of the dual tab connector to the choke... No cutting or splicing, very clean.. Just my $0.02.. I like this approach
[Re: Sinitro]
#2436701
01/18/18 02:36 AM
01/18/18 02:36 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
EZ to do.. Get a dual male 0.25" tab connector to a 0.25" female tab connector available everywhere. Connect to 12V input terminal on the ballast resistor, reconnect the original lead to 1 side of the dual tab connector and run a separate wire lead from the other side of the dual tab connector to the choke... No cutting or splicing, very clean.. Just my $0.02.. This is also a good method to run a hot wire to the pertronix!
