Page 3 of 3 1 2 3
Re: Milling cylinder heads?? [Re: NachoRT74] #243608
03/08/09 03:31 PM
03/08/09 03:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Pretty understandable really, I prefer to check my facts twice rather than get it wrong too. And if I get it wrong replacement heads are probably alot easier to find in California then Venezuela..
Re: Milling cylinder heads?? [Re: psycho_440] #243609
03/08/09 03:35 PM
03/08/09 03:35 PM
dogdays Offline
dogdays  Offline
I think for smallblocks it is something like 0.95 mil for every mil taken off the deck surface. The 1.23 from the Mopar guide is right for bigblocks.
R.
Re: Milling cylinder heads?? [Re: 1_WILD_RT] #243610
03/08/09 03:49 PM
03/08/09 03:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes, but also beside what is on my car actually I have 4 used 452 heads more, I know where to find locally 2 NOS 452 heads and could get some more heads around ( 346 ) so REALLY REALLY is mostly to save machine job expenses
Re: Milling cylinder heads?? [Re: NachoRT74] #243611
03/08/09 05:22 PM
03/08/09 05:22 PM
My MP eng bok states for each .010" from the head(deck) .0095 needs to come off the intake side and .0048" off of the deck loses 1cc(340-360) and .0053" off of the deck loses 1cc(273-318).
Re: Milling cylinder heads?? [Re: NachoRT74] #243612
03/08/09 06:45 PM
03/08/09 06:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Heres a question: How does it affect the valley pan gasket when taking that much material off?
if you cut alot off the heads and or the deck the valley end rails need to be cut after a certian point as the valley gasket won't fit well without :hammering .
I have a block that was decked .018 , the heads have about .050 cut off , I had to cut close to .080 off the valley rails to get the gasket to fit the way I wanted to . I think the number off the rail is the same as what you take off the intake side of the head , .0123
Re: Milling cylinder heads?? [Re: RapidRobert] #243613
03/08/09 06:46 PM
03/08/09 06:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Smallblock is DIFFERENT than big block
Re: Milling cylinder heads?? [Re: JohnRR] #243614
03/08/09 07:24 PM
03/08/09 07:24 PM
yes they are
Page 3 of 3 1 2 3
