Re: Milling cylinder heads??
[Re: RapidRobert]
#243571
03/05/09 01:04 PM
03/05/09 01:04 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Have the shop cc a couple chambers and then tell you waht you need. They are always larger than the factory specs.
[Re: moper]
#243572
03/05/09 01:14 PM
03/05/09 01:14 PM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
Have the shop cc a couple chambers and then tell you what you need. They are always larger than the factory specs.
you can't just ASSUME they are a certain cc
[Re: cdp]
#243575
03/07/09 06:49 PM
03/07/09 06:49 PM
JohnRR
U.S.S.A.
Just a rough measure and they were 75cc. I thought all of them were under 80 from the start?
they must have been cut before ? how thick is the boss where the outer rom of headbolts are under the exh ? something better than a rough measure , don't use a tape measure
[Re: Baxter61]
#243578
03/07/09 09:27 PM
03/07/09 09:27 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
You would think with those closed chambers you could go higher on the compression. (Depending on cam.)
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: cdp]
#243580
03/08/09 02:10 AM
03/08/09 02:10 AM
JohnRR
U.S.S.A.
I cc'd them a while ago, this time with a plexiglass plate and a syringe from the local animal supply. I get right at 78-80. The thickness is 1.000-1.010 (digital calipers).
You are still seeing a .010 difference , that 10 thou , thats alot with a digital caliper , but the heads haven't been planed , if much at all .
[Re: JohnRR]
#243581
03/08/09 08:22 AM
03/08/09 08:22 AM
RapidRobert
factory miling marks on th head deck are straight wheras machine shop ones leave circular marks. this may help you determine if it is original/unmilled
[Re: RapidRobert]
#243583
03/08/09 09:50 AM
03/08/09 09:50 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not nessessarly so. Depends on the machine shop.
[Re: cdp]
#243584
03/08/09 10:11 AM
03/08/09 10:11 AM
JohnRR
U.S.S.A.
Someones used a scotchbrite on the gasket surfaces with a air tool or something. Makes it hard to tell.
Those things can screw up the flatness of the surface real easy , the heads should be at a minimum SKIMMED to true the surface .
