Re: Wiring in an oxy sensor and is a relay needed...........
[Re: Thumperdart]
#2434594
01/14/18 08:03 PM
01/14/18 08:03 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
No, the unit doesn't draw much power. If you have noise problems try running your power and ground for the controller right to the battery.
68 Barracuda Formula S 340
[Re: mopar dave]
#2434685
01/14/18 11:02 PM
01/14/18 11:02 PM
dartman366
Mt. Vernon, Ohio
Dom, what i have is a Painless wiring fuse box for all my added accessories. It has its own relay and holds 7 fuses. I have my Innovate plugged into this box as well as all added acc. Only thing wired to the original fuse box is what came on the car. Hope this helps. I have the 6 switch version of the same box and I run my lm-2 from the switched 12 volt engine run switch and grounded to a bulkhead stud for grounds this has all my grounds tied together and a main ground wire back to the battery including the engine ground I am also using the rpm function and that has the tach signal coming straight off the tach post on my 7al and grounded to the same battery ground, no relay, have not seen any goofy readings with mine.
[Re: Thumperdart]
#2434823
01/15/18 03:03 AM
01/15/18 03:03 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
No relay needed for it, but I'm pretty sure it calls for an inline fuse...if doesn't, add one.
Wire 101: Run a large isolated ground from battery to mid point in the car and ground everything to that, don't use the chassis for ground. How large of a ground you ask? add up your amps used and grab a chart off Google. Once you realize power flows out of the negative side of the battery it all makes sense
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Thumperdart]
#2434995
01/15/18 02:33 PM
01/15/18 02:33 PM
Posts: 740 WA
JD Dart
WA
And since the data logger is seeing 0-5 volts the ground reference should be the same ground as the data logger. But that's only important if you want to see accurate readings.
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: Adobedude]
#2435109
01/15/18 06:07 PM
01/15/18 06:07 PM
Thumperdart
State of confusion
Wire 101: Run a large isolated ground from battery to mid point in the car and ground everything to that, don't use the chassis for ground. How large of a ground you ask? add up your amps used and grab a chart off Google. Once you realize power flows out of the negative side of the battery it all makes sense Actually found a page where the relay is used so I'm under the dash now and going to see if I can burn this thing to the ground............ ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif)
[Re: mopar dave]
#2435195
01/15/18 08:47 PM
01/15/18 08:47 PM
Thumperdart
State of confusion
So, I had the wb gauge hooked up directly to my ign. switch which went directly to my msd box so I installed the relay in line w/the gauge and hooked the batt. lead to ign. on and same damn thing. Gauge goes crazy till I turn the headlights on.............I'm lost and totally wiring challenged so maybe a filter of some sort?????????????
[Re: Bad340fish]
#2435219
01/15/18 09:20 PM
01/15/18 09:20 PM
Thumperdart
State of confusion
No, the unit doesn't draw much power. If you have noise problems try running your power and ground for the controller right to the battery. Just called Innovate and they said at LEAST run the 12 v feed to the battery stating that it acts as a filter so I will tackle that right now and go from there.......... ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif)
[Re: Thumperdart]
#2435501
01/16/18 10:42 AM
01/16/18 10:42 AM
BradH
... the wb used to show rich and the plugs said otherwise. Any feel for how different the old vs new readings are?
[Re: Thumperdart]
#2435560
01/16/18 12:40 PM
01/16/18 12:40 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
FYI, a single o2 sensor draws <3 amps when warming up. When i am warning up all 8 O2's at the same time, the power draw is 23 amps.
Joe
Without Data, you’re just another guy with an opinion.
