Spark Plug recommendation #2434632
01/14/18 09:53 PM
01/14/18 09:53 PM
SW FLORIDA
MPRB Offline OP
MPRB  Offline OP
SW FLORIDA
I need plugs for a 408 Stroker ma-x heads 9.8 to 1 cr
street ride. Need to be 5/8 plugs what do you guys recommend?
Re: Spark Plug recommendation [Re: MPRB] #2434671
01/14/18 10:47 PM
01/14/18 10:47 PM
NGK gets good reviews here & iirc one other brand I forget. Just me I wouldn't sweat the brand too much. most are made overseas now. wallace raceing has good plug heat range info/pics
Re: Spark Plug recommendation [Re: MPRB] #2434694
01/14/18 11:15 PM
01/14/18 11:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used Autolite race plugs in my 12.5 aluminum head 440.Went NGK and have used them in all our stuff now.Used them a lot at work also.Never a problem.Rocky
Chrysler Firepower
Re: Spark Plug recommendation [Re: MPRB] #2434700
01/14/18 11:22 PM
01/14/18 11:22 PM
Are you needing 14 MM 3/4 reach with the 5/8 body size? If so I would and do use either the Autolite #3924 or Champion RC12YC up scope
I don't remember the proper NGK numbers right now blush
The low compression street pump gas motor needs a plug that will be hot enough to not foul at light part throttle cruise and cold enough to not detonate at WOT work
Those two plugs have work very well for me in the past on pump gas motors up
