Re: Upgrades?
[Re: justinp61]
#2434086
01/13/18 08:45 PM
01/13/18 08:45 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
What year Dart? I would put the battery in the trunk as far back as possible on the passenger side up close to the outer 1/4 panel before I would spend the money for those upper A arms
Re: Upgrades?
[Re: justinp61]
#2434138
01/13/18 10:37 PM
01/13/18 10:37 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A lot depends on what the car is doing now. Is it deadly consistant from good to poor traction situations? If not, then moving the battery makes sense. I am guessing you want to go faster, or is consistancy more important? The extra cable i needed to move the battery was 15 lbs. Thats a loss off .015 et on weight that you have to get back with traction, that might be available with some chassis tuning. Look to see if it is possible to move the engine and tranny back at all. Moving 800 lbs of motor, tranny ,etc a 1/2 inch may be worth the trouble. Any chance you could move the rear axle forward?
Re: Upgrades?
[Re: gregsdart]
#2434179
01/13/18 11:57 PM
01/13/18 11:57 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
So, you want consistancy then! What kind of shocks do you have? My thinking is if you have room for improvement there, that is where i would go. New Viking da's front and rear last year.
Re: Upgrades?
[Re: Sport440]
#2434324
01/14/18 11:26 AM
01/14/18 11:26 AM
gregsdart
What year Dart? I would put the battery in the trunk as far back as possible on the passenger side up close to the outer 1/4 panel before I would spend the money for those upper A arms Moving the bat to the back is a double benefit, 40# off the front, 40# on the right rear. The effects are more then just a 40#,s Make this one of your easy upgrades. The benefit of moving weight varies by distance. Measure from the current battery location to where it will go and divide by the wheelbase. The result will be the percent change in weight shifted. Move it 125 inch in a 100 inch wb car, it is like moving 125 percent of the battery wieght. So, 50 lb moved 125 inch in a 100 inch wb car is like moving 62.5 lbs off the front, and onto the rear. Then recalculate the percentages of front to rear.
Re: Upgrades?
[Re: justinp61]
#2434421
01/14/18 02:37 PM
01/14/18 02:37 PM
Thumperdart
State of confusion
Greg it consistently spins the tires (radials) on mediocre tracks, that's why I bought John's trans brake that will leave in second. I like fast, but cars that consistently go down the track win races.
Get stiff-wall slicks.............Problem solved.........
Re: Upgrades?
[Re: Thumperdart]
#2434480
01/14/18 04:34 PM
01/14/18 04:34 PM
justinp61
W. Kentucky
Get stiff-wall slicks.............Problem solved......... I have a par of 28 x 10.5S, but you can't run them in a street car shoot out type stuff. Okay I'll move the battery. From what I've read if I move the battery the car has to have a master power kill? Which switch? Also the best way to wire it? It looks like some guys use a ford solenoid in the trunk so the main power wire to the front isn't hot unless the engine is cranking. With the Moroso box I won't need a bulkhead behind the rear seat so that looks like the simplest rout to go. Thanks
Re: Upgrades?
[Re: justinp61]
#2434518
01/14/18 05:35 PM
01/14/18 05:35 PM
Thumperdart
State of confusion
Get stiff-wall slicks.............Problem solved......... [/quote
Gotcha...........
Re: Upgrades?
[Re: justinp61]
#2434592
01/14/18 08:00 PM
01/14/18 08:00 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I run a Jeep relay for the starter, its from an early 80s Jeep CJ I think. The jeep relay works like a ford relay but it has a post that has to be grounded by the neutral safety to allow it to start. This is the same way the stock relay works. It has worked well for me for years.
For killing the power with the master switch there is simpler ways to do it but I use a continuous duty solenoid on the inside of the firewall to kill the alternator feed. Once I bought a quality solenoid(Cole Hersee) it has been trouble free.
68 Barracuda Formula S 340
Re: Upgrades?
[Re: justinp61]
#2434720
01/14/18 11:48 PM
01/14/18 11:48 PM
Cab_Burge
Okay I'll move the battery. From what I've read if I move the battery the car has to have a master power kill? Which switch? Thanks [/quote] Get a good one that is rated at or above 250 amps I've wore out the lower rated Moroso and Mr Gasket cheaper ones Nothing like have a street car that won't start due to that darn switch
