10.5 Flywheel Specification #2433579
01/12/18 08:44 PM
01/12/18 08:44 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
I have a 10.5 inch manual transmission flywheel that needs resurfaced. Is there any place that will give the thickness of a new flywheel, or how much can I safely machined off ?
Thanks!
Re: 10.5 Flywheel Specification [Re: mopar4ya] #2433598
01/12/18 09:20 PM
01/12/18 09:20 PM
E
earlymopar Offline
earlymopar  Offline
E
They usually just Blanchard grind them until the surface imperfections clean up which is normally .005" to .010".
- EM
Re: 10.5 Flywheel Specification [Re: earlymopar] #2433648
01/12/18 11:11 PM
01/12/18 11:11 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Yep, I understand that. My problem is a customer brought one in for me to grind and wanted to know how much has already been taken off of it. My AERA flywheel spec book does not give me any information on what the flywheel was when new, or a discard thickness. Other than to say it looks ok to cut, I really don't have anything to go on. I meant to post the casting # when I was at work and didn't get it, so I will post one up in the morning if it will help. Pretty sure it is a early to mid 70's small block. Flywheel casting # is 2264598.
Thanks!
