Drag Race Torsion Bars #2430413
01/07/18 11:18 AM
01/07/18 11:18 AM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Hi,
I'm looking for a way to leave my front suspension softer. I was measuring my OE torsion bars and I found a 0.890" DIA and it's looks like too stiff for a Small Block car.
I was searching on internet and Mancini Racing has a Mopar Performance Drag Race torsion bars with 0.810" DIA for sale.
http://www.manciniracing.com/mop810diam.html
My only concern is about street usage. Can I still running normally on the street with my car installing this torsion bars??
If someone knows any different torsion bars that will works for my application I really appreciate.
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2430427
01/07/18 12:26 PM
01/07/18 12:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We run the stock 6 cylinder .860" bars on Dizusters 360 car. Drives fine on the street without issue. Though it is no Road Racer.
Doug
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2430504
01/07/18 02:34 PM
01/07/18 02:34 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I've got the .810 MP Drag Race bars in my 62 Valiant Drag Week car. Right away I had the adjusters near the top to achieve the ride height I wanted, and after four Drag Weeks and around 5500 street miles they are completely shot and will no longer hold up the front of the car. This is in a 3000 lb car, small block with aluminum heads and aluminum radiator. With my experience the .860s are the smallest I would go. I'm going to put .890s in mine, as I think I don't need the front end that loose at the power level I'm at.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2430512
01/07/18 02:51 PM
01/07/18 02:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
68 B body......my car has had the same set of 6 cyl bars in it for over 30 years.
Love that pic of the Valiant on the street Billy!
Re: Drag Race Torsion Bars [Re: fast68plymouth] #2430515
01/07/18 02:57 PM
01/07/18 02:57 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I believe the torsion bar would be a good move.. they're also lighter.. you're also going to save weight with the upper control arms..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Drag Race Torsion Bars [Re: MoparBilly] #2430532
01/07/18 03:27 PM
01/07/18 03:27 PM
Thanks for your feedback Billy. This is my concern about .810 torsion bars because I run with my car at street every week. I'll doesn't like to change torsion bars every two years So I'm looking for something that can help me with weight tranfer for the rear at track but don't kill the car for the street. By the way, I liked your car!
Best 1/8 mile ET
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2430542
01/07/18 03:39 PM
01/07/18 03:39 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
that's right I forget about the whole streetcar thing..
Re: Drag Race Torsion Bars [Re: WHITEDART] #2430543
01/07/18 03:41 PM
01/07/18 03:41 PM
Yes man! I've three different things to change in car in my mind.. upper control arm, torsion bars and monoleafs but now I just have budget for one. In your opinion what should be the first thing to change?
Best 1/8 mile ET
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2430547
01/07/18 03:48 PM
01/07/18 03:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
.840's here, BB 3050+ lbs and mid 9's...........STREET CAR......... beer
Re: Drag Race Torsion Bars [Re: Thumperdart] #2430557
01/07/18 03:59 PM
01/07/18 03:59 PM
I Like it! Should works on mine!
Best 1/8 mile ET
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2430564
01/07/18 04:13 PM
01/07/18 04:13 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
My choice would be monoleafs (assuming you already have CalTracs) torsion bars, then upper control arms.
Bill
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2430587
01/07/18 04:52 PM
01/07/18 04:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
I don’t believe .840’s are an option for a B body.
Re: Drag Race Torsion Bars [Re: fast68plymouth] #2430595
01/07/18 05:11 PM
01/07/18 05:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No clue on that............. work
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2430640
01/07/18 06:42 PM
01/07/18 06:42 PM
A727Tflite Online content
A727Tflite  Online Content
MoparBilly - what tire and size do you have on the front of your rocket ?
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2431628
01/09/18 02:54 PM
01/09/18 02:54 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Hi,
Just what is your application? Is your car a '73-up B-body? Up here those use a bar about 43.5" long. Our 1962-72 B-bodies use a 41" bar. The ones you linked are for A-body (~=35-1/2"). You should probably measure the length of your bars before spending any money.
Re: Drag Race Torsion Bars [Re: @#$%&*!] #2431662
01/09/18 03:50 PM
01/09/18 03:50 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I believe it is a Brazilian charger but it's A body... I think it's kind of like a repackaged dart
Re: Drag Race Torsion Bars [Re: WHITEDART] #2432086
01/10/18 07:55 AM
01/10/18 07:55 AM
You're right Shiloh! up
Best 1/8 mile ET
Re: Drag Race Torsion Bars [Re: @#$%&*!] #2432088
01/10/18 08:04 AM
01/10/18 08:04 AM
Application is around 50% street, 50% Track. Torsion Bars length as Shiloh said is A-Body standard length. I did weight front of the car and found 1600 lbs. 52% of the total weight.
Best 1/8 mile ET
Re: Drag Race Torsion Bars [Re: 360tripleblack77] #2432127
01/10/18 12:09 PM
01/10/18 12:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Where can a guy buy A body .840-.860" torsion bars? Mancini lists the .890" bars as big block bars.
Re: Drag Race Torsion Bars [Re: justinp61] #2432785
01/11/18 01:49 PM
01/11/18 01:49 PM
Good question Justin. I tried to find .840" on internet but I can't. I found .830" (slant six) for sale. Should this work in my car?
Best 1/8 mile ET
