Page 1 of 3 1 2 3
stealth heads??????? #243207
03/04/09 07:33 PM
03/04/09 07:33 PM
mt.ephraim , new jersey
jsmopar1072 Offline OP
1.out of the box how do they compare to a ported 906 head?
2.can you buy them un assembled?
3.is anyone using them and whats the noticed difference from what you had?
WINNING IS ALL LUCK,ASK ANY LOSER! OBJECTS IN MIRROR APPEAR TO BE LOSING! JEFF'S BUDGET DODGE GARAGE!!!!
Re: stealth heads??????? [Re: jsmopar1072] #243208
03/04/09 11:44 PM
03/04/09 11:44 PM
anyone?
Re: stealth heads??????? [Re: jsmopar1072] #243209
03/05/09 12:08 AM
03/05/09 12:08 AM
I have not used mine yet, I have seen posts on here from people who have had them flowed and they flowed better than the professionally ported big valve 906 heads that I have had flowed and used on my car and other motors that I have built and dyno tested for customers IHTHs Call 440source for question # 2 I wanted 3 sets of the bare castings and ended up with one set of the complete heads, I ended up having to cancel the other sets due to the slowing of the economy and so on. The so on is that I ended up buying a set of ported B1 from Koffels and a set of 440-1 from another member on here you know the old adage "go big or go home"
Re: stealth heads??????? [Re: jsmopar1072] #243210
03/05/09 12:08 AM
03/05/09 12:08 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Well, not sure about your questions, but I used a set of them on a motor we built for my wife's 64 vert. Mind you, this is meant to be a cruiser, may even put 2.94 or 2.76 gears in it.
413 block bored to 4.25, 3.75 stroke, so the motor is a 426.
9.6:1 cr with ross pistons. Comp xe275hl cam, 231/237 at 50, .525 lift.
440 source heads ported by ou812/IMM. RPM intake with 770 holley street avenger vac sec carb.
Made "only" 470hp and 486 tq on the dts dyno.
440source head dyno pull
Re: stealth heads??????? [Re: jsmopar1072] #243211
03/05/09 12:13 AM
03/05/09 12:13 AM
mopar heaven
rustbucket Offline
rustbucket  Offline
mopar heaven
You cannot buy them unassembled. If you want to build anything really healthy you are going to have to buy new springs , retainers and locks. I did not want to waste money on parts I would never use.....That is why I did not buy them.
Re: stealth heads??????? [Re: rustbucket] #243212
03/05/09 07:54 AM
03/05/09 07:54 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Have them on my 440.It definetly made a difference.I changed the springs locks and retainers.My .588 solid cam and 4 speed dictated it.If I had Eddys I would have had to do the same thing.My machinist said the springs woukd be OK for a Hyd cam and auto.Rocky
Chrysler Firepower
Re: stealth heads??????? [Re: rustbucket] #243213
03/05/09 10:04 AM
03/05/09 10:04 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
This is the answer you get from the people that don't own a pair and just want to stir up crap.
Do a search on the heads and you will find hundreds of opinions.
I own a pair of the first that was made.I have beat the snot out of them for 1 season. I gained .2 to .35 in the 1/8th mile over a pair of very good ported 915s.No other changes just the heads.I had to use roller springs so the stock retainers and springs had to be replaced but there was nothing wrong with them.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: stealth heads??????? [Re: slippery440] #243214
03/05/09 11:48 AM
03/05/09 11:48 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Re: stealth heads??????? [Re: QWK_ENUF] #243215
03/05/09 12:16 PM
03/05/09 12:16 PM
aren't you being just a little oversensitive? i read his remark as there are other choices out there where heads can be purchased bare. maybe he went that route instead.he didn't make a big deal out of it or say anything derogatory, just expressing his thoughts, as asked.
apparently he wanted to spend his hard earned money differently, that's all.
personally, the way i see it, there are plenty of options out there for any given combo. the Stealth heads are just one option. i wouldn't condemn the guy just because he didn't buy from what is possibly "your" preferred provider.
just for the record, i've built combo's with the stealths, edelbrocks, indy's and so on. many have the same pro's and cons to them but it's still a free country to choose what you feel is right for you and express your opinion about it, isn't it?
Re: stealth heads??????? [Re: slippery440] #243216
03/05/09 12:16 PM
03/05/09 12:16 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I have to disagree. in this case, it was not a type post..it had useful info and he simply explained why he did'nt choose to buy them..and I think its a good reason, IMHO.
Re: stealth heads??????? [Re: B1Fish540] #243217
03/05/09 01:18 PM
03/05/09 01:18 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
"You cannot buy them unassembled. If you want to build anything really healthy you are going to have to buy new springs , retainers and locks. I did not want to waste money on parts I would never use.....That is why I did not buy them. "
maybe not
but if you were building something REALLY healthy would you consider a basic head that is set up for a mild hyd cammed application anyway or move up to a differnt head altogether
i thought of the stealth/performer heads but went with the victors since i used my own springs.
WAXER
Re: stealth heads??????? [Re: QWK_ENUF] #243218
03/05/09 02:04 PM
03/05/09 02:04 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I don't fault them for not offering a bare head, not at all. However, if they DO offer one later I'd like to see: enough meat in the roof for lots of porting, LONG VALVE spring seat location, and enough meat in the pushrod area for a window width anywhere from 1.2-1.5". I suppose a slightly raised valve cover rail would be a good idea as well but staying with the 'stealth' concept.
Re: stealth heads??????? [Re: @#$%&*!] #243219
03/05/09 03:41 PM
03/05/09 03:41 PM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
i had to change springs retainers and locks on my 3k indy heads. and i had to change them on my stealth heads most of the time when you are building something you will end up with a little extra. the stealth heads look great and perform fantastic for the cost are there better heads, absolutely. is there a better head for the money NO
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
Re: stealth heads??????? #243220
03/05/09 08:14 PM
03/05/09 08:14 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
DRAM I read the if you want to build anything healthy you would need to change the springs and retainers and locks. Well DAH that is a no brainer and aplys to all the out of box heads.I am not talking about the high dollar B1s or Indys.I wonder what Rustbucket bought instead?He didn't say.
I will put it to you this way .If I had a prety heathy motor that had a cam that had a lift of lets say .540 I would take the stealth heads out of the box and bolt them on.I would put alot of machine shops out of buiness.
Everyone needs to stop and think before jumping a idea.
It should be a moparts rule that if you post on any product either bad or good you first must own that product and used it personly.This would stop all the mopar gods that sit in there own little world and make judgement calls on products they have never used.BTW That was not pointed at you Dram.I see that you have used them. You said a mouth full when you said they ALL have pro's and con's.
Re: stealth heads??????? [Re: slippery440] #243221
03/05/09 08:38 PM
03/05/09 08:38 PM
keep in mind that the bold print above was not a quote from me.
Re: stealth heads??????? [Re: Cab_Burge] #243222
03/05/09 09:16 PM
03/05/09 09:16 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
personally I think buying the Stealth heads and ditching the springs, etc is still cheaper than buying a pair of bare Edelbrock RPM's.
Re: stealth heads??????? [Re: Defbob] #243223
03/05/09 10:07 PM
03/05/09 10:07 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
DRAM I knew that.
Re: stealth heads??????? [Re: slippery440] #243224
03/05/09 11:53 PM
03/05/09 11:53 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
There is a guy here that had a BRAND NEW set crack and break off an entire cylinder. This is no joke. They did send him a new head and told him due to the way the cast/machine these heads to only torque them to 50 ft/lbs. This is a true story. I'll try and get pictures of the one that broke, a complete, cylinder off.
Re: stealth heads??????? [Re: DaKuda] #243225
03/06/09 12:30 AM
03/06/09 12:30 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
How would the head gasket seal at that torque setting ? You have a link to this story, was it posted on here.
Re: stealth heads??????? [Re: DaKuda] #243226
03/06/09 02:47 AM
03/06/09 02:47 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Wha??? Ok I might be wrong but I want to be the first to call BS!
Page 1 of 3 1 2 3
