383 Pistons #2431136
01/08/18 04:45 PM
01/08/18 04:45 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Does anybody make a good zero deck 383 piston any more? I don't care if it's cast or forged, just not a hypereutectic piston.
Re: 383 Pistons [Re: 6PakBee] #2431214
01/08/18 07:58 PM
01/08/18 07:58 PM
dogdays Offline
dogdays  Offline
Did they ever?
IMHO your best bet is one of the aftermarket specialty forged piston makers.
R.
Re: 383 Pistons [Re: dogdays] #2431254
01/08/18 08:55 PM
01/08/18 08:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted By dogdays
Did they ever?
Well per the 330hp vs 335hp thread it seems they did... some even over the deck for couple of cents
( not me, just what I read there shruggy even I began the thread )
Re: 383 Pistons [Re: 6PakBee] #2431269
01/08/18 09:19 PM
01/08/18 09:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If the after market ever did, it was before 1977.
Its been awhile since I've looked so you should look to see what might be out there now. The old Speed Pro 2315 is tall enough to get you to zero deck with some deck machining, and proper gasket selection. It'll be 0.010" to 0.018" below an uncut deck.
Re: 383 Pistons [Re: 6PakBee] #2431347
01/08/18 11:25 PM
01/08/18 11:25 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
I agree with BSB67's comment about the TRW 2315's . My Bee's original 383 motor had .008-.016 deck height with 2315's after cutting the decks .010.
One option would be to run the old 2315 TRW's, do a light cleanup cut on the decks, and have the crank slightly offset ground to push the piston to zero deck height. Problem is that factory rod lengths are all over the map so getting close to zero on all 8 cylinders will likely take 2-3 sets of rod cores and/or some selective machining.
The cost to correct the machining of factory parts really starts to eat away at the cost delta of a stroker kit.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: 383 Pistons [Re: 6PakBee] #2431543
01/09/18 12:25 PM
01/09/18 12:25 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Re: 383 Pistons [Re: Twostick] #2431548
01/09/18 12:41 PM
01/09/18 12:41 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Thanks to everyone who responded. A huge help! up
Re: 383 Pistons [Re: 6PakBee] #2431603
01/09/18 02:16 PM
01/09/18 02:16 PM
dogdays Offline
dogdays  Offline
The guy who really knows this is JohnRR. Maybe a PM to him is in order.
IMHO by the time you get done messing around trying to make this or that piston work, you will be within spitting di$tance of a custom forged piston which will be exactly what you need. Trying to find a new set of old TRW slugs is a hassle, buying a set of Speed Pros will cost more than you think. Either choice will be incredibly heavy, because the OEM pistons were heavy. The TRW or Speed Pro pistons were built to replace stock pistons. You should be able to save over 100 grams per piston with a custom forged piston from one of the companies I mentioned in my last post.
Really check your options before buying a piston.
R.
Re: 383 Pistons [Re: 6PakBee] #2431910
01/09/18 11:12 PM
01/09/18 11:12 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Re: 383 Pistons [Re: 6PakBee] #2432175
01/10/18 01:52 PM
01/10/18 01:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Unless you're trying to make some fairly serious power, and/or turn a lot of rpm, the 2315's will work just fine.
Easy balance job on the crank since the weight is close to the OE pistons.
Got 'em in my 383....... Stock rods w-arp bolts...... Goes 7100 through the lights on a good weather day.
Re: 383 Pistons [Re: Twostick] #2432610
01/11/18 01:50 AM
01/11/18 01:50 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
The "mike s" pistons were promising when he had a Compression Distance of 1.930", but as of late, they are 1.920". These are not game changers. It’s unfortunate someone can’t simply produce a copy of a 68/69 HP piston with modern ring packs and modern alloy. My belief is that a majority of people building stock stroke 383s are doing so for restoration or nostalgia purposes and not for max power/torque; too many stroker kits for that.
I'll be ordering a semi-custom set of pistons to get exactly what I want for my 383. Poor, poor, pistons choices everywhere else...
Re: 383 Pistons [Re: CompSyn] #2432671
01/11/18 04:56 AM
01/11/18 04:56 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
1.920 cd flat top
1/16-1/16-3/16 ring pack
valve notches
accumulater groove
4032 alloy
std 1.094 pin,press or float with forced pin oiling
What's not modern?
Leave the gun.......take the Cannoli's....Mike
Re: 383 Pistons [Re: mike s] #2432725
01/11/18 10:01 AM
01/11/18 10:01 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By mike s
1.920 cd flat top
valve notches
accumulater groove
4032 alloy
What's not modern?
I'm with you.
You can get to zero deck easy enough, valve notches, 75cc aftermarket aluminum cylinder heads and good quench for a motor that has been out of production more than 45 years. The 383 never had it so good.
Piston weight on a 3.38" stroke 383 is really a none issue.
If you are looking for or expecting more than this, you really did not want a street 383 anyway, IMO
Re: 383 Pistons [Re: mike s] #2432734
01/11/18 10:24 AM
01/11/18 10:24 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
1.920 cd flat top
valve notches
accumulater groove
4032 alloy
What's not modern?
When the summer comes, I'm going to take a close look at these pistons. Just the facts that they have an accumulator groove and the 1.920 compression height are big pluses in my book.
Re: 383 Pistons [Re: BSB67] #2432765
01/11/18 12:42 PM
01/11/18 12:42 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I agree exc for one thing. The piston weight makes a huge difference.
I am having issues posting the pics, so far I can not attach any to my posts. When you see them judge them. Email me for pics threerail@msn.com
Re: 383 Pistons [Re: mike s] #2432830
01/11/18 03:20 PM
01/11/18 03:20 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
1.920 cd flat top
valve notches
accumulater groove
4032 alloy
What's not modern?
The only other thing not modern about them besides the pin is the shorter 1.920" CD. A lower than stock CD; lower compression aftermarket pistons which have plagued 383s for decades.
Why not start with the factory 68/69 HP CD of 1.932", and IF there is a concern of lower deck heights on a particular block, one can simply deck the pistons to the desired CD. Right!? Because you can remove some material from new pistons but cannot add new material to a block.
Re: 383 Pistons [Re: mike s] #2432982
01/11/18 07:55 PM
01/11/18 07:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Not for what we're talking about here.
Re: 383 Pistons [Re: 6PakBee] #2433011
01/11/18 08:50 PM
01/11/18 08:50 PM
So. Burlington, Vt.
So. Burlington, Vt.
A 1.920c/h piston, 1/16 rings, 1.094 pin, with valve pockets sounds good to me.
That's only .014 down the hole, and I'm going to deck the block anyway, so it's an easy zero deck combo.
Re: 383 Pistons [Re: 6PakBee] #2433073
01/11/18 10:13 PM
01/11/18 10:13 PM
A727Tflite Offline
A727Tflite  Offline
Mike S-
To post a picture -
Type in your post info then look below and you will see Switch To Full Repky Screen, then you will see File Manager - click on that.
Files have to be available on the device you are posting from - on your phone/iPad/computer/USB memory stick/etc.
Attach photos
Re: 383 Pistons [Re: A727Tflite] #2433228
01/12/18 03:58 AM
01/12/18 03:58 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Thanks!
