Re: Speed Pro forged aluminium pistons - Any good?
[Re: vinnyd76]
#2430558
01/07/18 04:01 PM
01/07/18 04:01 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
[Re: 340Cuda]
#2430559
01/07/18 04:03 PM
01/07/18 04:03 PM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
I think those are the same as what used to be called TRW. If so, used them a lot in the distant past. No problems at all other than they were heavy and we often had to cut the valve reliefs deeper for roller cams.
Bill Below are a couple of photos of the Speed Pro Piston.
[Re: vinnyd76]
#2430576
01/07/18 04:36 PM
01/07/18 04:36 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I ran the Speed Pro pistons in the TT440. The first set I had was treated viciously and went through a LOT of detonation as I was learning the ins and outs of turbos. When I pulled them out they were scuffed and 4 of them had rings so badly broken they fell out in pieces. Still, the pistons held together.
The second set saw higher boost pressures (surged to 21 psi at one point) and put up with alcohol injection at 15 psi. They were still running in the engine when I sold the car a couple years ago.
They aren't be best thing out there but they put up with my abuse.
[Re: vinnyd76]
#2430579
01/07/18 04:40 PM
01/07/18 04:40 PM
crabman173
crabman173
Wiseco Street ProTru so much better deal-- light-- with rings and priced right
[Re: vinnyd76]
#2430629
01/07/18 06:21 PM
01/07/18 06:21 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
I ran their forged flat tops in a 360 for ten years. No valve reliefs and heavy as boat anchors, but held up just fine. Never saw and power adders though.
[Re: vinnyd76]
#2430634
01/07/18 06:27 PM
01/07/18 06:27 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
Decent forged pistons in my opinion, but heavy as others have said. Not bad on a budget, moderate performance engine.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2430655
01/07/18 07:05 PM
01/07/18 07:05 PM
RapidRobert
X3 on the weight, iirc mine were 2355's (was 30 yrs ago).
[Re: vinnyd76]
#2430712
01/07/18 09:12 PM
01/07/18 09:12 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
...I was not familiar with the brand. I must be getting old. The older stuff is good when it was made here.
[Re: vinnyd76]
#2430720
01/07/18 09:17 PM
01/07/18 09:17 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I don't believe they are made in India any longer. They had lots of problems with them when they made that change, and lost a lot of sales as a result. I can't remember where I was told they're coming from now...... But I think it's Mexico.
[Re: mgoblue9798]
#2431128
01/08/18 04:24 PM
01/08/18 04:24 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
In general, coated pistons skirts are good. It's supposed to reduce piston-to-wall friction.
[Re: PurpleBeeper]
#2431230
01/08/18 08:23 PM
01/08/18 08:23 PM
dogdays
History: When I started the real HP car stuff in 1972 Speed Pro and TRW were the two manufacturers of forged pistons for American engines. That is, if you could get them for your engine. They were reasonably priced. If you couldn't get them for your engine then you went to Arias or Venolia or Forgedtrue and paid a lot more. That was it. They were strong but heavy, same weight as the cast pistons they replaced. There were guys who earned a living lightening TRW and Speed Pro forged pistons for racers.
Then I was out of the game for a while.
Now, Federal Mogul makes Sealed Power for regular performance, and Speed Pro for the high performance crowd. Ironically. the Speed Pro pistons many times use the old TRW part numbers. But TRW pistons are no more. The pistons are still heavy and stout but now they cost quite a bit more than they used to, counting for inflation.
There has sprung up a crop of aftermarket forged piston makers who for a couple of hundred dollars more make a superior piston, in terms of weight and suitability for much higher performance. They used to be double the old TRWs, but now they aren't so much more cost. They have flexibility in specifications and there are many part numbers for shelf stock pistons. Changes to the pistons can sometimes be done for a few dollars or free, so your pistons will be a lot closer to what you need.
In the case of a 383 which has Speed Pro pistons already installed, if it's for a street engine they are about unbreakable. It's not worth trashing them to spend another $800 on a set of "better" pistons.
As far as the carping on the Speed Pros, most of those come from real racers or people who use their engines hard. The JE, SRP, Wiseco, ProTru, Diamond, Icon, Ross, etc pistons fit their needs better. If one was building a 383 from scratch I'd suggest using one of these, but mainly for compression reasons. You can tailor the CR by making modifications to the pistons that are not available from S-P.
R.
[Re: vinnyd76]
#2431692
01/09/18 05:08 PM
01/09/18 05:08 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I built a stroked 4.0 I6 for my jeep about 14 years ago. The kit I used came with speed-pro pistons and it is still working great.
68 Barracuda Formula S 340
[Re: ]
#2431913
01/09/18 11:20 PM
01/09/18 11:20 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Wiseco Street ProTru so much better deal-- light-- with rings and priced right I have these in my 493 and I really couldn't believe the level quality for the price Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dogdays]
#2433332
01/12/18 01:01 PM
01/12/18 01:01 PM
DaytonaTurbo
Manitoba, Canada
Dogdays makes lots of good points. These days the speed pro's are so costly as well as being made overseas so you have to really consider if they're worth it. The TRW's used to be nice forged, inexpensive pistons. They were strong but heavy, same weight as the cast pistons they replaced.
A lot of guys like to comment on the weight of the old TRW's but the reality is they were about the same weight as the stock pistons they replaced. There are still guys running old school stock stroke 440 combos with the TRW's running the 11's.
