Gen III costs #2429899
01/06/18 01:50 PM
01/06/18 01:50 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I've been interested in the Gen III stuff for a while and the introduction of the Hellcrate has had me thinking about selling all my small block stuff and buying one. 700 reliable, drive anywhere horsepower for $15000, plus a 3 year warranty doesn't sound bad. But.........what could a guy build (gen III) for the same money? It would have to be reliable, run on pump gas, preferably boosted.
I know the Hellcrate will require a controller, wiring, headers and possibly a pan, but any gen III build will need all this stuff so it's a wash as far as costs go.
What do you guys think?
Re: Gen III costs [Re: justinp61] #2430076
01/06/18 06:18 PM
01/06/18 06:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I for one think a 6.4 long block with a tall drag pack intake and quality headers would be a killer "buy it and drop it in" package, MSD ignition and a carb is about as cheap as it could get and it's cheaper than building a 392 stroker 5.7. The SRT 392 is 485 HP in emmisions NVH and MPG choked form, you add a much better intake, tune and exhaust and give it a gross instead of net HP rating and I bet you can find 575 HP at the crank. I know its not 700 hp but it would be a whole barrell of fun for minimal investment. A cam upgrade should be able to put you solidly in the 600 HP range.
Re: Gen III costs [Re: justinp61] #2430142
01/06/18 08:14 PM
01/06/18 08:14 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Since the budget is $15k
Whipple 2.9 Supercharger with TB and injectors about $7k + whatever long block you can build for $8k= $15K
Probably could build a pretty decent long block for $8K or just get a 6.4 and add the whipple.
Re: Gen III costs [Re: justinp61] #2430273
01/07/18 12:32 AM
01/07/18 12:32 AM
Northern Colorado
E
EagleDuster Offline
EagleDuster  Offline
E
Northern Colorado
Pull-out and junkyard engines are pretty cheap and plentiful now too in case you wanted to get something to "practice" on. I like HotRodDave's idea, you could start out with a stock 6.4 SRT engine and pretty easily mod it incrementally up to 600+ N/A horses, probably for a lot less than $15k. Then add a blower if you need more.
Khalid
1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
Re: Gen III costs [Re: RTSE4ME] #2430279
01/07/18 12:40 AM
01/07/18 12:40 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Gen III costs [Re: justinp61] #2430285
01/07/18 01:00 AM
01/07/18 01:00 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Find a BGE 6.4 (ram 2500/3500) drop out and add your favorite supercharger. BGE's use Hellcat block, Hellcat heads with a standard bolt pattern, supposedly crank, maybe rods and rumored to have forged pistons. If the pistons aren't forged buy some drop in's and away you go.
Re: Gen III costs [Re: WO23Coronet] #2430453
01/07/18 01:13 PM
01/07/18 01:13 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
I'd put aftermarket forged rods into as well, then they'll truly be drop-ins.
Re: Gen III costs [Re: SRT6776] #2430553
01/07/18 03:55 PM
01/07/18 03:55 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
What you guys are missing is the fact that the Hellcat motor is net 700 hp.
Long tube and a tune and it goes up! Add a pulley and your in the 900 HP.
Do what you want but IMO that 15000 is a real good investement.
Matt
Re: Gen III costs [Re: MattW] #2430556
01/07/18 03:59 PM
01/07/18 03:59 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Stock Hellcat challengers are running 9:70??? That nothing more than a tune and headers? I'm not talking about the stripped out version either. This is at a 4400 lbs without driver?
Add that to a 1000lbs less car and its even faster.
Matt
Re: Gen III costs [Re: pittsburghracer] #2430580
01/07/18 04:41 PM
01/07/18 04:41 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By pittsburghracer
I am not familiar with ATK.
What type of reputation do they have?
Bill
Re: Gen III costs [Re: MattW] #2431062
01/08/18 02:45 PM
01/08/18 02:45 PM
W. Kentucky
W. Kentucky
Matt
This is what I'm getting at. Can I build a reliable, 700 hp boosted Gen III for what the Hellcrate costs? I already have a pump gas small block that is near that and it's a hoot to drive, but it's pretty raunchy. With the Hellcrate just hit the key and it's running, put it in gear and drive off, no worrying about killer pressure valve springs, needle bearings in roller lifters or rockers and checking lash. Just check the oil and have fun.
Re: Gen III costs [Re: justinp61] #2431082
01/08/18 03:19 PM
01/08/18 03:19 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I’ve seen some hellcat pullouts for 12-13k. I’d buy one of those
Re: Gen III costs [Re: justinp61] #2431558
01/09/18 12:55 PM
01/09/18 12:55 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What is BGE?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Gen III costs [Re: Hemi_Joel] #2431597
01/09/18 02:10 PM
01/09/18 02:10 PM
Renton Washington
Triple Threat Offline
Renton Washington
Originally Posted By Hemi_Joel
What is BGE?
Big Gas Engine, it basically refers to 6.4 Hemi's that come in 2500 and 3500 trucks. Different heads than a 6.4 apache.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Gen III costs [Re: Triple Threat] #2431999
01/10/18 01:06 AM
01/10/18 01:06 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
BGE heads have the same ports as an Apache, just made out of better material (same stuff as the Hellcat)
Re: Gen III costs [Re: justinp61] #2432034
01/10/18 02:14 AM
01/10/18 02:14 AM
ghinmi Offline
ghinmi  Offline
If all you're after is 700 at the crank, just put some drop-in pistons/rods in a 2009+ 5.7 and add boost. Simple, cheap, easy.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Gen III costs [Re: WO23Coronet] #2432552
01/11/18 12:10 AM
01/11/18 12:10 AM
Northern Colorado
E
EagleDuster Offline
EagleDuster  Offline
E
Northern Colorado
Those engines have only been out for a few years I don't think they're quite that easy and cheap to come by, yet...
Khalid
Re: Gen III costs [Re: MattW] #2432562
01/11/18 12:27 AM
01/11/18 12:27 AM
Home
SRT6776 Offline
SRT6776  Offline
Home
Matt
9.60's seems to be the number they run with the pulleys, tune and traction.
Re: Gen III costs [Re: justinp61] #2432582
01/11/18 12:51 AM
01/11/18 12:51 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yeah a local guy has one that is full weight with pulleys and a tune and injectors. His problem has been traction, its been 10.0X and 140 mph but won't hook up. The 8 speed finally laid down on him after 300 something runs so he is trying to get that upgraded now.
68 Barracuda Formula S 340
Re: Gen III costs [Re: Bad340fish] #2432691
01/11/18 09:01 AM
01/11/18 09:01 AM
Home
SRT6776 Offline
SRT6776  Offline
Home
$9500 core charge, dang
http://www.paramountperformanceproducts....erformance.aspx
In all fairness its probably because there's no HP90's around. All the wrecked hellcats seem to have the drivetrain and electronics sold as a package so it can be swapped into something else.
The 5.7's and 392's use the HP70.
