Re: Gen III costs
[Re: justinp61]
#2430076
01/06/18 06:18 PM
01/06/18 06:18 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I for one think a 6.4 long block with a tall drag pack intake and quality headers would be a killer "buy it and drop it in" package, MSD ignition and a carb is about as cheap as it could get and it's cheaper than building a 392 stroker 5.7. The SRT 392 is 485 HP in emmisions NVH and MPG choked form, you add a much better intake, tune and exhaust and give it a gross instead of net HP rating and I bet you can find 575 HP at the crank. I know its not 700 hp but it would be a whole barrell of fun for minimal investment. A cam upgrade should be able to put you solidly in the 600 HP range.
Re: Gen III costs
[Re: justinp61]
#2430273
01/07/18 12:32 AM
01/07/18 12:32 AM
Posts: 24 Northern Colorado
EagleDuster
Northern Colorado
Pull-out and junkyard engines are pretty cheap and plentiful now too in case you wanted to get something to "practice" on. I like HotRodDave's idea, you could start out with a stock 6.4 SRT engine and pretty easily mod it incrementally up to 600+ N/A horses, probably for a lot less than $15k. Then add a blower if you need more.
Khalid 1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
Re: Gen III costs
[Re: WO23Coronet]
#2430453
01/07/18 01:13 PM
01/07/18 01:13 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Find a BGE 6.4 (ram 2500/3500) drop out and add your favorite supercharger. BGE's use Hellcat block, Hellcat heads with a standard bolt pattern, supposedly crank, maybe rods and rumored to have forged pistons. If the pistons aren't forged buy some drop in's and away you go. I'd put aftermarket forged rods into as well, then they'll truly be drop-ins.
Re: Gen III costs
[Re: MattW]
#2431062
01/08/18 02:45 PM
01/08/18 02:45 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
What you guys are missing is the fact that the Hellcat motor is net 700 hp. Long tube and a tune and it goes up! Add a pulley and your in the 900 HP. Do what you want but IMO that 15000 is a real good investement. Matt This is what I'm getting at. Can I build a reliable, 700 hp boosted Gen III for what the Hellcrate costs? I already have a pump gas small block that is near that and it's a hoot to drive, but it's pretty raunchy. With the Hellcrate just hit the key and it's running, put it in gear and drive off, no worrying about killer pressure valve springs, needle bearings in roller lifters or rockers and checking lash. Just check the oil and have fun.
Re: Gen III costs
[Re: justinp61]
#2431558
01/09/18 12:55 PM
01/09/18 12:55 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Gen III costs
[Re: Hemi_Joel]
#2431597
01/09/18 02:10 PM
01/09/18 02:10 PM
Triple Threat
Renton Washington
Big Gas Engine, it basically refers to 6.4 Hemi's that come in 2500 and 3500 trucks. Different heads than a 6.4 apache.
Re: Gen III costs
[Re: justinp61]
#2432034
01/10/18 02:14 AM
01/10/18 02:14 AM
Posts: 112 Michigan
ghinmi
If all you're after is 700 at the crank, just put some drop-in pistons/rods in a 2009+ 5.7 and add boost. Simple, cheap, easy.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
Re: Gen III costs
[Re: WO23Coronet]
#2432552
01/11/18 12:10 AM
01/11/18 12:10 AM
EagleDuster
Northern Colorado
Find a BGE 6.4 (ram 2500/3500) drop out and add your favorite supercharger. BGE's use Hellcat block, Hellcat heads with a standard bolt pattern, supposedly crank, maybe rods and rumored to have forged pistons. If the pistons aren't forged buy some drop in's and away you go. Those engines have only been out for a few years I don't think they're quite that easy and cheap to come by, yet...
Re: Gen III costs
[Re: MattW]
#2432562
01/11/18 12:27 AM
01/11/18 12:27 AM
Posts: 9,719 Home
SRT6776
Home
Stock Hellcat challengers are running 9:70??? That nothing more than a tune and headers? I'm not talking about the stripped out version either. This is at a 4400 lbs without driver? Add that to a 1000lbs less car and its even faster. Matt 9.60's seems to be the number they run with the pulleys, tune and traction.
Re: Gen III costs
[Re: justinp61]
#2432582
01/11/18 12:51 AM
01/11/18 12:51 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Yeah a local guy has one that is full weight with pulleys and a tune and injectors. His problem has been traction, its been 10.0X and 140 mph but won't hook up. The 8 speed finally laid down on him after 300 something runs so he is trying to get that upgraded now.
68 Barracuda Formula S 340
Re: Gen III costs
[Re: Bad340fish]
#2432691
01/11/18 09:01 AM
01/11/18 09:01 AM
Posts: 9,719 Home
SRT6776
Home
Yeah a local guy has one that is full weight with pulleys and a tune and injectors. His problem has been traction, its been 10.0X and 140 mph but won't hook up. The 8 speed finally laid down on him after 300 something runs so he is trying to get that upgraded now. $9500 core charge, dang http://www.paramountperformanceproducts....erformance.aspxIn all fairness its probably because there's no HP90's around. All the wrecked hellcats seem to have the drivetrain and electronics sold as a package so it can be swapped into something else. The 5.7's and 392's use the HP70.
