Instrument Voltage Regulator upgrade: why 5V instead of 6V?
#2429558
01/05/18 06:47 PM
01/05/18 06:47 PM
Posts: 85 New Brunswick Canada
copperSwinger
Will be redoing the Dash on a 68 Barracuda and will be converting the Instrument Voltage Regulator to Solid State per the November 1992 Mopar Muscle Article. Most of these conversions use a "7805" voltage regulator which supplies a constant 5V to the gauges. My question is WHY 5V? These gauges are meant to run on 6V so why not get a "7806" voltage regulator instead? I have heard that people using the 7805 dont get full gauge travel and accuracy. Wouldnt a 7806 therefore be the answer? Also I have seen some people soldering the additional Capacitor (which is meant to protect the Voltage regulator from spikes) to the 12V input side of the Regulator, and other people soldering it to the 5V output side of the Regulator. The Mopar Muscle article shows it soldered to the Output side and to ground. This doesnt make sense since it will have no way of protecting the Voltage Regulator since they mounted it "downstream" of the current. THANK YOU Here are two links showing different Capacitor configuration: http://1962to1965mopar.ornocar.org/ml-instrument-voltage-regulator64.htmlhttp://www.jefframin.org/library/IVR.2.jpg
Re: Instrument Voltage Regulator upgrade: why 5V instead of 6V?
[Re: copperSwinger]
#2429610
01/05/18 08:34 PM
01/05/18 08:34 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
[Re: copperSwinger]
#2429735
01/06/18 01:32 AM
01/06/18 01:32 AM
RapidRobert
when I test the gauges with 3V they go to half way (give or take 1/16") FWIW when I bench checked mine they were exactly halfway with 3 volts.
[Re: rarefish]
#2429949
01/06/18 02:37 PM
01/06/18 02:37 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory IVR s a thermal resistor, it won't work well with the minimal load of the Fluke.
[Re: 451Mopar]
#2430091
01/06/18 06:48 PM
01/06/18 06:48 PM
Posts: 1,505 TN
SCATPACK 1
TN
How many gauges are you powering, Temp, Fuel, and oil?
The reason I ask, is if all three, the linear IVR (7805) can go into thermal shutdown unless it had a good heat sink.
The 7805 regulator circuit should have both input and output capacitors. Is there a picture of one of these electronic conversions completed? My dash does not work and I am pretty sure this is the reason. I would like to replace the old point type with a newer electronic version. OOPS! Never Mind. I just found th elink already posted back a few pages.
Old Geezer Racing
[Re: BDW]
#2430231
01/06/18 11:11 PM
01/06/18 11:11 PM
NachoRT74
Valencia, España
I'm wondering what's wrong with the factory regulators. Has anyone ever really had 1 go bad AND destroy the gauges?. Not me, but yes know some and have dissasembled many other clusters damaged because that. Any fail able to keep stuck the points burn the gauges. Even a missed ground which still with a good conditions VL will make the bimetall never to open and feed straight 12v
