Re: INITIAL SHOCK SET UP.................
[Re: Thumperdart]
#2429450
01/05/18 02:50 PM
01/05/18 02:50 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Dom, if you expect a lot of extension on the hit, you could start there. Something made up to check max travel in both directions, like a rod with gromets on it and something attached to the axle end of the shock mount to push those gromets could tell you a few things.
[Re: Thumperdart]
#2429519
01/05/18 05:24 PM
01/05/18 05:24 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Dom likely little reason to need much more compression on your deal. Except maybe when seeing street duty. Our Camaro is mostly street driven and we have 1.5" com compression on the shocks and every once in awhile on the highway it will bottom out. I am willing to live with that. FWIW it is a Caltrac/mono leaf car as well. If it was more a street car I'd want more but IMO you will be fine. You need all the extension you can get with that set up.
[Re: Thumperdart]
#2429527
01/05/18 05:31 PM
01/05/18 05:31 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Are the shocks mounted straight up & down or like factory angled ? an angled shock travels less VS suspension travel than a straight up & down mount, just sayin
[Re: Thumperdart]
#2429564
01/05/18 06:56 PM
01/05/18 06:56 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
6" is pretty short for a leaf spring car...
The shocks move MORE when they are mounted on an angle...not less, but not by a ton.
Depends on the angle...if you had 30 degrees, every 1.73" of vertical travel = 2" of travel along the angle. Less angle means less difference. So in the end it's not a huge deal, but might make or break you with a short shock.
[Re: dizuster]
#2429573
01/05/18 07:10 PM
01/05/18 07:10 PM
Thumperdart
State of confusion
[Re: Al_Alguire]
#2429589
01/05/18 07:51 PM
01/05/18 07:51 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Dom likely little reason to need much more compression on your deal. Except maybe when seeing street duty. Our Camaro is mostly street driven and we have 1.5" com compression on the shocks and every once in awhile on the highway it will bottom out. I am willing to live with that. FWIW it is a Caltrac/mono leaf car as well. If it was more a street car I'd want more but IMO you will be fine. You need all the extension you can get with that set up. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) but Al come on I really believe the Camaro stuff is ![offtopic offtopic](/ubbthreads/images/graemlins/custom/offtopic.gif) hahaha..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2429591
01/05/18 07:53 PM
01/05/18 07:53 PM
WHITEDART
bean town ....Ca
Oh I have to apologize I just remember the thumper runs bowtie rear suspension
[Re: WHITEDART]
#2429606
01/05/18 08:25 PM
01/05/18 08:25 PM
Thumperdart
State of confusion
Oh I have to apologize I just remember the thumper runs bowtie rear suspension Hows that Mr. "FORD" rear suspension...............lol They are installed and I have a tad over 2" of compression so soon we will see what this lipstick pig will run...............
[Re: Al_Alguire]
#2429719
01/06/18 12:54 AM
01/06/18 12:54 AM
Thumperdart
State of confusion
Dom likely little reason to need much more compression on your deal. Except maybe when seeing street duty. Our Camaro is mostly street driven and we have 1.5" com compression on the shocks and every once in awhile on the highway it will bottom out. I am willing to live with that. FWIW it is a Caltrac/mono leaf car as well. If it was more a street car I'd want more but IMO you will be fine. You need all the extension you can get with that set up. Al, I drive this thing almost weekly and have for many months that's why she's wore out....... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: Thumperdart]
#2429777
01/06/18 03:40 AM
01/06/18 03:40 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
And Don't Forget about adding Preload to the passenger side rear since in the vids your crushing the rear driver side tire and the passenger side tire appears to be floating, since you took that extra batt out of the rear. You did do 3 changes though to lose your 60 ft. from 1.30 to 1.40 Batt remove. Slick change. Carb change. Don't you know the rule of thumb, Change 1/one thing at a time, Cab and Pettis should of drilled that in your head by now. Now, based on the blurry vids, your axel is rotating down on the driver side and up on the passenger side. Exactly how physics would have it do. Keep that into consideration after your initial mechanical shock set up. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Thumperdart]
#2429882
01/06/18 01:27 PM
01/06/18 01:27 PM
Al_Alguire
Las Vegas
Hey now my Camaro has hybrid rear suspension Dana 60 and Caltracs. Did I mention its Panther Pink too ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Given those two items I feel its always on topic here Dom I know you do and I know those beautiful Cali roads. We used to drive the Camaro 55 miles on I80 to get to Sac Raceway and rarely had an issue, you'll be fine as far as compression goes. 6" of travel is NOT a ton but IMO will probably be sufficient. Camaro only has 5 and its been 9.70's with its pump gas pig
[Re: Sport440]
#2429891
01/06/18 01:45 PM
01/06/18 01:45 PM
Thumperdart
State of confusion
And Don't Forget about adding Preload to the passenger side rear since in the vids your crushing the rear driver side tire and the passenger side tire appears to be floating, since you took that extra batt out of the rear. You did do 3 changes though to lose your 60 ft. from 1.30 to 1.40 Batt remove. Slick change. Carb change. Don't you know the rule of thumb, Change 1/one thing at a time, Cab and Pettis should of drilled that in your head by now. Now, based on the blurry vids, your axel is rotating down on the driver side and up on the passenger side. Exactly how physics would have it do. Keep that into consideration after your initial mechanical shock set up. I agree w/you on these things and have watched the "blurry" vid several times and see the same thing, the axle is teeter tottering and the truck shocks, soft sidewall tires and battery removal made it worse. 2nd batt is back, new bad ass shocks ft and rear and we will let er eat............The carb works great but does need some more street testing which I will do before we head back out in a couple of weeks......... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) New goal; 1.29 60 ft. 6.000 et at 113+ mph.............. ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif)
