Conversion Radio Wiring??? Help! #2429301
01/05/18 02:05 AM
01/05/18 02:05 AM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
This is a 68 Radio converted to I believe Pioneer.
I bought it years back and I am getting sound but not so great.
If anybody recognizes the harness leads please ID them.
I recall a vendor was converting AM to Pioneer based high Watt Super Tuners.
Red and Orange are on a Factory Plug for power and light.
I got it powered up and lit with ground through Chassis.
Grey and White sound pretty good together.
Blue and purple make noise but sketchy.
Could this be a common ground?
Brown does nothing.... for speakers
Thanks in advance.....
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1997 Ram B3500 Van 5.9
1991.5 W250 Cummins- Big Chief
Re: Conversion Radio Wiring??? Help! [Re: 440PURSUIT] #2429302
01/05/18 02:06 AM
01/05/18 02:06 AM
DC, MD Suburbs
DC, MD Suburbs
brown tag says 241
1972 Charger w 383
Re: Conversion Radio Wiring??? Help! [Re: 440PURSUIT] #2429366
01/05/18 09:54 AM
01/05/18 09:54 AM
Alabama
BigMoneyLewis Offline
Alabama
I have no idea who did your conversion , or what board they used , so this info may be useless to you , but we use the Antique Automobile Radio boards ,
like you see here ..and blue would be positive for one speaker and purple would be ground for that same speaker..then Grey would be positive for the other speaker and white would be ground for that speaker .
This may not apply to your particular radio , but that's how the boards from AAR are configured .
Greg
gregward@mchsi.com phone 256-852-0955
Thanks Greg [Re: BigMoneyLewis] #2429408
01/05/18 12:50 PM
01/05/18 12:50 PM
DC, MD Suburbs
DC, MD Suburbs
Back to the bench with renewed confidence!
1972 Charger w 383
Re: Thanks Greg [Re: 440PURSUIT] #2429436
01/05/18 02:10 PM
01/05/18 02:10 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
mmm usually modern speakers setups are white pair and gray pair for front speakers and green pair and purple pair for rears. On these pairs, the traced wire is negative.
Blue uses to be remote trigger ( powered antenna or amplifier )
black-ground, red-power ( acc ), yellow or orange-memory ( batt ).
as far I recall
Re: Thanks Greg [Re: 440PURSUIT] #2429487
01/05/18 04:17 PM
01/05/18 04:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's an old conversion before they standardized the wire color.
Other than that, I offer nothing of value
Don't be the exception.
Re: Conversion Radio Wiring??? Help! [Re: 440PURSUIT] #2429551
01/05/18 06:37 PM
01/05/18 06:37 PM
central il.
second 70 Offline
second 70  Offline
central il.
I just went out to the garage and pulled the Pioneer super tuner owners manual out of glove box. It was a conversion done in the 90’s.
The factory wire out of the radio were orange always hot,red switched hot,blue power antenna or power amp,green/red left front +, gray/red right front +,green left rear+,gray right rear +. There is only 1 black negative wire that is the ground for all speakers. And there is a separate black on the back of the radio that is the ground. My radio also has pre outs that can be used to connect a rear amp and if you use them you don’t hook up the green and gray rear speaker wires.
Mike
