Re: 383 backfires [Re: 8urvette] #2430368
01/07/18 04:00 AM
01/07/18 04:00 AM
Is the polarity correct from the mag pickup in the distributor to the MSD box?
Re: 383 backfires [Re: 8urvette] #2430729
01/07/18 09:30 PM
01/07/18 09:30 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
checked MSD wiring- that is correct
You verified this by swapping the two wires and saw that the way you have it has the timing retarded compared to when the wires are the other way?
Or you just know the colors are what they're supposed to be?
I've seen both the distributors and control boxes have the polarity of those wires be incorrect.
Re: 383 backfires [Re: 8urvette] #2430802
01/07/18 11:30 PM
01/07/18 11:30 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i just verified the MSD by colors. this box was in another car running normally. The distributor is another story. I have other one to try out once the motor is back together.
