Page 3 of 4 1 2 3 4
Re: Cold air in a WO23 scoop [Re: astjp2] #2426259
12/31/17 12:22 PM
12/31/17 12:22 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
Tim,
I purposely had a 1" wide, 90 degree bend in the metal while it was still a straight piece. That way I could use the stock rubber seal for an A12
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2426262
12/31/17 12:26 PM
12/31/17 12:26 PM
Tennessee
Tennessee
My goal from the beginning was to make it look as "factory" as I could. This rubber is hollow, and has a compression distance of 1-3/4". This should conform around the bracing. It won't be air tight exactly, but should still allow the carbs to receive mostly cool outside air.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2427066
01/01/18 02:17 PM
01/01/18 02:17 PM
Tennessee
Tennessee
Remember the "notch" that I had to cut out of the base to clear the wiper motor, well that is the next problem to solve. Here is the Kick In required to clear the wiper motor, still working on it.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2427364
01/01/18 08:12 PM
01/01/18 08:12 PM
Tennessee
Tennessee
Well, I have worked through the holidays, and made progress. Here is the finished product, minus trimming and painting.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2429681
01/05/18 11:26 PM
01/05/18 11:26 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Lets see the final product! top, bottom, and sides!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2430930
01/08/18 07:07 AM
01/08/18 07:07 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Bump
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cold air in a WO23 scoop [Re: astjp2] #2430941
01/08/18 08:48 AM
01/08/18 08:48 AM
Tennessee
Tennessee
Sorry I know I'm slow. I have the whole thing at a friends to be tig welded. I chose not to use my little 110 mig welder in the basement when he can use his commercial tig welder. Should pick it up this week.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2431068
01/08/18 02:53 PM
01/08/18 02:53 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Looks like it is going to be very nice. Good Job!
Re: Cold air in a WO23 scoop [Re: 340Cuda] #2438658
01/21/18 09:44 PM
01/21/18 09:44 PM
Tennessee
Tennessee
I know it has been several weeks. In a project like this (creating a one of a kind), you find your limits! Mine were, no tig welder, no bandsaw, not enough clamps, and expertise! So, with the help of good friends, I finished the structure today.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2438662
01/21/18 09:47 PM
01/21/18 09:47 PM
Tennessee
Tennessee
After cutting off the excess metal, we trimmed, then broke the sheet metal to provide a trough. And began to tig weld it together.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2438665
01/21/18 09:49 PM
01/21/18 09:49 PM
Tennessee
Tennessee
Now it is in it's final shape, tig welded, (spot). Then I will "panel bond" the seams, paint and install.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2438668
01/21/18 09:50 PM
01/21/18 09:50 PM
Tennessee
Tennessee
Trial fit.
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2439088
01/22/18 05:00 PM
01/22/18 05:00 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Very nice. Quite a project!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2439152
01/22/18 07:06 PM
01/22/18 07:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By Hemi ragtop
Trial fit.
WAY cool to do this stuff yourself........... thumbs
Re: Cold air in a WO23 scoop [Re: Thumperdart] #2439206
01/22/18 09:16 PM
01/22/18 09:16 PM
Tennessee
Tennessee
Thanks! I didn't know if I could until I tried! LOL
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2440733
01/25/18 09:45 PM
01/25/18 09:45 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Any finished photos yet?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2440818
01/26/18 01:31 AM
01/26/18 01:31 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Wow! Nice work. Where did you get the hood scoop from?
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2440890
01/26/18 08:20 AM
01/26/18 08:20 AM
Tennessee
Tennessee
I'm doing "body work" getting ready for paint. I have to blend in the area in the rear where I had to make a metal extension to clear the rear carb bowl. Almost finished with that. Hopefully this weekend I will get the "panel bond" epoxy in the corners where the wall meets the base. This will seal the air gap where it was spot welded on (tig with silicon bronze). Then it has to be metal prepped (cleaned) for paint.
I got the hood scoop from Joey Cole. He is a master metal worker! He built it from a flat sheet of steel!
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2440894
01/26/18 08:45 AM
01/26/18 08:45 AM
Tennessee
Tennessee
Modification to rear carb bowl
Re: Cold air in a WO23 scoop [Re: Hemi ragtop] #2440933
01/26/18 12:20 PM
01/26/18 12:20 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Very cool project & nicely done. I am getting ready to start on a similar project but adapting my Shaker hood on my 70' Challenger. I am going to be making a custom drop base to fit to my Indy tunnel ram with dual Dominator carbs & a custom larger/taller Shaker Scoop.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Page 3 of 4 1 2 3 4
