Transmission shield/blanket. 69 GTX stock floor #2420938
12/19/17 02:40 PM
12/19/17 02:40 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Switching from a glide to a torqueflight on my Hemi GTX. What brand/model blanket or shield are you guys running. Ease of installation and maintenance are of importance. Remember, this car has stock floor pans Thanks!
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2420956
12/19/17 03:07 PM
12/19/17 03:07 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
What shifter do you use?Cable or rod ?All but the CF will get burned depending on the headers[fender exit or under chassis]I liked the more flexible blankets w/full coverage.
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2420957
12/19/17 03:11 PM
12/19/17 03:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
RCI blanket is a tight fit but works on my car (904, Duster, stock floor).
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2420958
12/19/17 03:11 PM
12/19/17 03:11 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Anyone run the short 727 blanket from A&A Transmission?
Re: Transmission shield/blanket. 69 GTX stock floor [Re: Clanton] #2420967
12/19/17 03:34 PM
12/19/17 03:34 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
The motor is a hemi....under chassis headers. Shifter is a B&M mot sure if cable enters front or rear. Really only need B body big block experience. Thanks!
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2420990
12/19/17 04:13 PM
12/19/17 04:13 PM
an8sec70cuda Offline
Mine is an E body w/ a hemi, but should be the same as B body in this situation. I use the carbon fiber CSR shield. Have to hammer the seam flat where the firewall meets the floorpan and have to cut the lugs off the trans case where the factory shift linkage bolts up. It's all snug, but works great. It saved my feet when my 727 exploded in 2008. I have 2.25" primary TTI headers and they fit fine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Transmission shield/blanket. 69 GTX stock floor [Re: an8sec70cuda] #2421100
12/19/17 08:18 PM
12/19/17 08:18 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
an8sec70cuda.... Do you have pictures you can post of the floor seam remodeling required? When I swap to the 727 I will not be pulling the engine, so if it can be done correctly with the trans out then no problem.
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2421118
12/19/17 08:54 PM
12/19/17 08:54 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That is why I posted the pic of the seam,you can see how far back iy is.
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2421119
12/19/17 08:54 PM
12/19/17 08:54 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Make some cuts, about n inch apart n tap them against the tunnel. A billet drum would save some headaches.
Re: Transmission shield/blanket. 69 GTX stock floor [Re: ProSport] #2421230
12/19/17 11:57 PM
12/19/17 11:57 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Is that the same as DJ Safety ? I will hopefully be fitting a short DJ blanket next week in my 68 Satellite
I took some advice i read , will weld a curved rod to cable / trans bracket to support blanket off shift lever
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Transmission shield/blanket. 69 GTX stock floor [Re: tex013] #2421334
12/20/17 07:10 AM
12/20/17 07:10 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Tex
Yes I believe DJ Safety makes it to A&A's specs.
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2421340
12/20/17 08:29 AM
12/20/17 08:29 AM
Sydney,Australia
Sydney,Australia
Kool , as soon as new converter arrives i will be fitting it
Tex
New best MPH 130.32
Re: Transmission shield/blanket. 69 GTX stock floor [Re: tex013] #2421344
12/20/17 08:45 AM
12/20/17 08:45 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Tex
Perfect, let us know how it goes.
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2421378
12/20/17 11:49 AM
12/20/17 11:49 AM
Yes you can do it w/ the motor still in the car. I don't have any pics, but you'll see it immediately when you drop the trans. Just hammer it so it's flush w/ the rest of the floor. You can see what it looks like before hammering it flush in Clanton's pic.
Rickraw...even if you have a billet drum, you still need some sort of shield or SFI bellhousing to be legal.
CHIP
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2422133
12/22/17 12:52 AM
12/22/17 12:52 AM
Sydney,Australia
Sydney,Australia
This is the modded canle bracket , holds blanket up off shift arm and cable
Tex
New best MPH 130.32
Re: Transmission shield/blanket. 69 GTX stock floor [Re: an8sec70cuda] #2422138
12/22/17 01:04 AM
12/22/17 01:04 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Ditto,my engine is also set back a few inches.Also use a PB shifter with no issues.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2430927
01/08/18 06:50 AM
01/08/18 06:50 AM
Sydney,Australia
Sydney,Australia
Finally got all my stuff today - converter from A1
Fitted it all up . Blanket fits a treat , from ext housing gasket to just up bell housing . Plenty of space on passenger side to header . Barely 1/4" - 1/2" clearance on driver side . I fitted aluminium heat shield to help out .
I go have Dougs headers , 3 1/2" collectors .
Testing tbis saturday so any isdues let you know
New best MPH 130.32
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2430987
01/08/18 12:06 PM
01/08/18 12:06 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
My advice for the driver side header is to get some ceramic matt 1/2" thick and wrap the header with header wrap around the matt on the pipe.
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2431181
01/08/18 06:37 PM
01/08/18 06:37 PM
Sydney,Australia
Sydney,Australia
the shield I use is a waffle type , same as factory oe . Have used it to protect shift cable with great results .Will find out .
Tex
New best MPH 130.32
Re: Transmission shield/blanket. 69 GTX stock floor [Re: mercman1] #2431196
01/08/18 07:25 PM
01/08/18 07:25 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That is ok and is how we find out what works.
