Re: 1989 W250 360 rough running in cold weather issues
[Re: wannadrag]
#2420732
12/19/17 01:00 AM
12/19/17 01:00 AM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
moisture inside the dist. cap?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: buildanother]
#2420757
12/19/17 01:38 AM
12/19/17 01:38 AM
Posts: 1,281 WI
wannadrag
WI
The ignition temp sensor? Would that be the 2 wire coolant sensor then? Yes
[Re: wannadrag]
#2420800
12/19/17 03:17 AM
12/19/17 03:17 AM
RapidRobert
strickly WAG ing, when you take it out from the warm shop does it act up immediate or does it take several hours of sitting shut down like you mentioned? I'm wondering if a coolant heater in a rad hose bringing the coolant temp up if it would still not be right when sitting outside which would point me toward A/F mixture. I'm just bored.
[Re: wannadrag]
#2420919
12/19/17 01:54 PM
12/19/17 01:54 PM
Posts: 2,255 IL
furious70
IL
does it miss or backfire or just the idle hunting around? Idle surging like that can be a very lean condition and then the IAC starts to try to chase it around and it gets even worse
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: RapidRobert]
#2421259
12/20/17 01:10 AM
12/20/17 01:10 AM
Posts: 1,281 WI
wannadrag
WI
strickly WAG ing, when you take it out from the warm shop does it act up immediate or does it take several hours of sitting shut down like you mentioned? I'm wondering if a coolant heater in a rad hose bringing the coolant temp up if it would still not be right when sitting outside which would point me toward A/F mixture. I'm just bored. It takes a couple hrs then back to running like crap.
[Re: furious70]
#2421261
12/20/17 01:13 AM
12/20/17 01:13 AM
Posts: 1,281 WI
wannadrag
WI
does it miss or backfire or just the idle hunting around? Idle surging like that can be a very lean condition and then the IAC starts to try to chase it around and it gets even worse It pops back though the thottle body once in a while along with surging idle.
