Re: Improving cnc ported heads
[Re: B3422W5]
#2421085
12/19/17 07:50 PM
12/19/17 07:50 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
if it makes you feel any better.. I am yet to see a c&c head flow as good as they're advertised.. most head companies these days r more into selling a flow number...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: B3422W5]
#2421211
12/19/17 11:34 PM
12/19/17 11:34 PM
Posts: 4,210 New York
polyspheric
New York
Larry Widmer very strong on CFM numbers are less important than velocity at the right lift, producing best transitional horsepower (only shows up on an RPM per second dyno).
Boffin Emeritus
[Re: polyspheric]
#2421400
12/20/17 12:43 PM
12/20/17 12:43 PM
Posts: 19,568 north of coder
moparx
There may be differences in result quality between 2 different programs and 2 different CNC fixtures from the same (already ported) head. How is that possible? One takes smaller readings with the probe, at more angles, then uses more passes and smaller cutters at more axes (hours longer to complete). In some castings (not all) the difference may be significant, especially with small ports and 3 dimensional curves. this something i learned over my 42+ year machining career dealing with castings, both virgin and finished/repaired, although dealing with natural gas transmission meters instead of cylinder heads. also, different cutters most definitely affect flow, sometimes in mysterious ways, such as the helix difference in same sized end mills used in contour cutting.
[Re: Ian]
#2422496
12/22/17 11:27 PM
12/22/17 11:27 PM
Posts: 43,275 Bend,OR USA
Cab_Burge
Where both test done on the same machine and in similar weather conditions?
[Re: Cab_Burge]
#2422507
12/22/17 11:42 PM
12/22/17 11:42 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
Where both test done on the same machine and in similar weather conditions? same day 2 hrs apart same port same bench mate
[Re: Ian]
#2422578
12/23/17 03:53 AM
12/23/17 03:53 AM
Cab_Burge
[Re: polyspheric]
#2422942
12/24/17 01:12 AM
12/24/17 01:12 AM
Posts: 7,506 Az
Crizila
Az
heads are only so thick, once you get them thin, seats start to move around This^^^
Vizard reported on intake valves that didn't seat properly because the seat itself moved laterally when hot. The cure: weaken the valve head so it bends to conform. !!! Vizard reading his weegie board again. Anyone who does this needs a frontal lobotomy.
Fastest 300
