Source for 70 fury big block positive battery cable assembly #2419587
12/16/17 08:03 PM
12/16/17 08:03 PM
IL
furious70 Offline OP
IL
I can only find up to 68, not sure if there'd be a reason that one wouldn't fit?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2419593
12/16/17 08:42 PM
12/16/17 08:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2419698
12/17/17 01:24 AM
12/17/17 01:24 AM
IL
IL
I mean the whole oem assembly with the relay wire
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2419743
12/17/17 05:03 AM
12/17/17 05:03 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I couldn't find a reproduction when I was restoring the pink Fury I have, call Antique Auto Battery (330) 480-0755), I sent them my original and they made me one. I had to use my original secondary plug if I remember correctly.
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2419836
12/17/17 01:32 PM
12/17/17 01:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, you want OEM style, then no the 68 won't work.
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2419974
12/17/17 07:51 PM
12/17/17 07:51 PM
md
mopars4ever Offline
mopars4ever  Offline
md
69 should be the same. Mopar part numbers should be 2983499 or 2983636. I don`t see any available.
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2420019
12/17/17 09:11 PM
12/17/17 09:11 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Any chance E and B body are same on big block '70? This one is pricey
https://www.ebay.com/itm/NOS-70-71-E-B-Body-Dodge-Ply-Big-Block-MOPAR-Battery-Cable-Positive-2983649/192385059845?hash=item2ccb0b0c05:g:GWMAAOSwywRaJEgq&vxp=mtr
Facts are stubborn things.
Re: Source for 70 fury big block positive battery cable assembly [Re: Supercuda] #2420120
12/18/17 01:03 AM
12/18/17 01:03 AM
IL
IL
Sounds like I'm missing an obvious reason it won't work? The picture looks similar.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2420127
12/18/17 01:13 AM
12/18/17 01:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If they were the same they would have the same part number.
It appears you want a resto look and that precludes using anything other than the original setup. If close enough would work, then I refer you back to the link I posted.
The difference is length.
Re: Source for 70 fury big block positive battery cable assembly [Re: Supercuda] #2420377
12/18/17 03:50 PM
12/18/17 03:50 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I just know they have so many part numbers for same part at times. I guess so-called superceded numbers?
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2420404
12/18/17 04:40 PM
12/18/17 04:40 PM
IL
IL
I'm with you too Larry, but looking them up on rock auto 68 to 70 there is a substantial length difference. I would have lost a $1 bet on that. Would be nice if they at least made them with red insulation...autozone and oreily only have black as well.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Source for 70 fury big block positive battery cable assembly [Re: furious70] #2420764
12/19/17 01:50 AM
12/19/17 01:50 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
I have been involved with the company that manufactures many of the restoration battery cables that the different vendors offer. We have built all of our cables off of assembly line pieces from documented samples. You cannot go off of the parts books for documenting the cables. You will find that the same part number will possibly interchange with numerous applications.
Most parts books used back in the day were updated at least two to four times during the first three to five years of the production year. During that time this battery cable may have been changed in some way in say length to work on a different application. They did not always change the part number and then on another situation, it would be superceded to a new number for a different application, even though the physical characteristics of the cable did not change. There is no set pattern to the logic.
We have added several C-Body positive and negative cable applications and will probably have them available by March of 2018.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
