Re: 512 BBM-- How much power???
[Re: qwkmopardan]
#2418926
12/15/17 11:59 AM
12/15/17 11:59 AM
Posts: 570 UK
rb446
UK
According to Wallace...at 2250 at the line and your gearing/tyres> 8.60's@159mph is 700hp on the day, ....@780hp it would be 60 Foot E.T. : 1.15 1/8 Mile E.T. : 5.23 1/8 Mile Trap Speed : 129.92 1/4 Mile E.T. : 8.29 1/4 Mile Trap Speed : 162 1/4 Mile Trap RPM : 6,751+slip
However from my experience with very light cars it tends to mess up the Wallace calcs/numbers somewhat for reasonable accuracy.
900hp would be>
60 Foot E.T. : 1.10 1/8 Mile E.T. : 4.99 1/8 Mile Trap Speed : 136.26 1/4 Mile E.T. : 7.91 1/4 Mile Trap Speed : 169 1/4 Mile Trap RPM : 7,081+
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: qwkmopardan]
#2418977
12/15/17 01:49 PM
12/15/17 01:49 PM
Posts: 31,054 Oregon
AndyF
Hard to say on the power, could be 800 hp with those parts or it could be 900 hp. In my experience with engines like that it comes down to details. Porting the intake is worth 25 to 30 hp, running more rocker ratio and more valve lift is worth some power, Jesel belt drive and belt driven distributor helps out, big oil pan helps the power, correct headers help the power, vacuum pump helps, gas ported pistons help, etc.
[Re: qwkmopardan]
#2419075
12/15/17 04:20 PM
12/15/17 04:20 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have -1 ported heads ,15/1 comp 528 cubes, alky terminater injection, cam is a Jones 285/296/114 with 8.70 intake lift, .830 exhaust lift, 33 x15 inch bias slicks with a 3 speed T F , and 4.56 gears. At 2000 DA I average 8.90 at 150 in a 3065 lb car with driver. Trap rpm is 7400, I shift at 7450.
[Re: qwkmopardan]
#2419085
12/15/17 04:34 PM
12/15/17 04:34 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
Just finished a friends 512 BBM. Indy block--4.375 bore--4.25 stroke--15 to 1 CR--Indy-1 Heads--titanium valves--385 max flow on intake--Ultradyne .690" lift 281* at .050 roller cam--300# seat and 700# open spring pressure--T&D single shaft rockers--Indy single dominator intake--1050 alcohol dominator carb--Charlies dragster oil pan. It has a fairly heavy Crower crankshaft. We are expecting it to cross finish line at 7400-1/4 mile. How much aprox. power? I am thinking close to 900 horsepower. No $$$$ in his budget for Dyno. Why not find, earn, do anything, to get the money needed to put it on the dyno to help tune it before putting it in the car? I've dyno tested a similar bracket race motor (526 C.I. 4.375x4.375 stroke, RB with 12.8 to 1 comp. ratio on 110 race gas) and a 518 CI low deck 10.78 to 1 comp. ratio pump gas motor, with the same set of CNC ported 440-1 heads with 2.25 intake valves. the race motor made right at 850 HP on 110 octane race gas and the smaller motor made 775 HP on the pump gas motor on 92 octane Oregon pump swill compared to a set of SR with M.W intake ports and the 2.19 intake valve, both sets of heads had the same 76.0 CC on the combustion chambers, same headers and so on with no other changes than swapping the heads On your deal I wouldn't be a bit surprised to see over 900 HP at or above 7500 RPM and a little less torque I've never ran straight Methanol alcholol so I have no idea what it is worth as far as HP and torque compared to race gas, I did test one other 511 C.I. low deck bracket race motor on race gas and then on Oregon pump E85, which tested to be E89, that motor lost 11 HP on that pump E85 but made 15 ft. Lbs more torque than on race gas after jetting both carbs. to get the best results on both combinations
[Re: qwkmopardan]
#2419129
12/15/17 06:39 PM
12/15/17 06:39 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Engine going in a car that weighs 2250# with driver. A mutt. 1963 split window Corvette. What E.T. 1/4 mile???? 2 speed trans. and 4.10 gears with 16X33 tires--2250# with driver Man I'd love to see some pics of that BBM in a 63 Vette!! Give my GM friends heart attacks. LMAO!!
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: qwkmopardan]
#2419541
12/16/17 05:59 PM
12/16/17 05:59 PM
Superfreak
Superfreak
