Re: 727 Rear Clutch Upgrade worth it?
[Re: Hot 340]
#2415638
12/09/17 09:51 AM
12/09/17 09:51 AM
Posts: 2,937 A shed in England
Tig
A shed in England
We've used the thinner, pre '74 washer in the trans with no issues. Usually lives behind a 655, or a 572 motor when the reserve motor steps in. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2415641
12/09/17 10:21 AM
12/09/17 10:21 AM
Posts: 3,397 Pa
Hot 340
Pa
[Re: Hot 340]
#2415684
12/09/17 12:46 PM
12/09/17 12:46 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
I would upgrade while you have it apart. There are a couple of factors at work. The wave spring allows fore and aft movement, which effectively increases piston travel irrespective of clutch retainer clearance. Not all piston retainer to clutch retainer fit, is the same. The looser the fit, the worse the problem of excessive piston travel and consequential over centering of the spring. If you have a good selection of oem, and aftermarket snap rings, you will find that a combination of 2, will replace the wave spring nicely.
[Re: Hot 340]
#2415766
12/09/17 04:10 PM
12/09/17 04:10 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The early Belleville works OK when it's new but will fatigue with use and weaken more than the later one. HP has nothing to do with failures, line pressure kills them. Even if they don't break, the early ones can flex enough to allow the piston to pop out of its bore...very common failure.
I've seen a bunch of the early ones fail but never the later one. A worthwhile upgrade IMO.
[Re: Hot 340]
#2416094
12/10/17 09:01 AM
12/10/17 09:01 AM
Tig
A shed in England
Good Info ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: 451Mopar]
#2416447
12/10/17 10:07 PM
12/10/17 10:07 PM
John_Kunkel
Rio Linda, CA
The video claims the early piston isn't any different than the late; I've found, by actual measuring, the late piston is taller. The casting number 2124834 ('62-'73) is .783" thick and the 3743623 ('74-later) is .830".
[Re: Hot 340]
#2418656
12/14/17 08:39 PM
12/14/17 08:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just picked one up. Casting number 3743623AB. Measures .782 thick. Maybe the "AB" is a revision? Most anytime you have letters following the numbers its been upgraded and on yours with a AB it was down a couple times ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2418704
12/14/17 09:51 PM
12/14/17 09:51 PM
Posts: 3,397 Pa
Hot 340
Pa
Just picked one up. Casting number 3743623AB. Measures .782 thick. Maybe the "AB" is a revision? Most anytime you have letters following the numbers its been upgraded and on yours with a AB it was down a couple times 👍
[Re: Hot 340]
#2418798
12/15/17 12:53 AM
12/15/17 12:53 AM
Posts: 3,105 Michigan
A727Tflite
I just saw your last photo. - yes - depending how you measure. Thickness is different - as long as you measure correctly using the machined register on the bottom of the piston ( the machined radial ridge ) to the top of the outer rim of the piston. EDIT- The way you are measuring in the last photo should show the different thicknesses between the two p/n's.
[Re: A727Tflite]
#2418809
12/15/17 01:16 AM
12/15/17 01:16 AM
Posts: 3,397 Pa
Hot 340
Pa
part numbers 623 and 834
