Re: Help me choose a cam - 500ci [Re: DGS] #2419343
12/16/17 02:26 AM
12/16/17 02:26 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Originally Posted By DGS
500ci (4.25" stroke - 4.34" bore 440 block)
Trick Flow 240 heads ootb (lightest spring package but don't mind changing them)
10.5 compression ratio - 0.040 quench
Indy dual plane 440-2d intake manifold
2" headers (Dougs)
Rocker arms not purchased but will probably be a set of 1.5 or 1.6 PRW + B3RE geometry kit
This is a street car so low and mid rpm torque is important.
As for a cam:
Master______advertised___@050__@200___lobe lift__valve lift (1.5)___valve lift (1.6)__lash
FC270/360_____270______240___157____.3600_____.540__________.576______.012
FC269/350_____269______242___159____.3500_____.525__________.560______.011
FC275/365_____275______244___161____.3650_____.548__________.584______.014
LSA? I'm thinking about 112° for a broad torque curve..
What about these two Hughes cams?
Duration @050__lobe lift_____lift 1.5 RR____lift 1.6 RR
238/242______.372/.376___.558/.564___.595/.602 - 109° LSA
242/246______.376/.384___.564/.576___.602/.614 - 109° LSA
Considering that a stock 1968 to 1972 340 came with a 272 duration cam from the factory at about 465 lift, I think either of the above cams will be very mild in a 500 inch motor. Stump puller maybe.
Just my opinion of building Dodge engines the last 40+ years.
Try this link to the Cam article in archives.
http://www.moparts.org/Tech/Archive/motor/5.html
Old Geezer Racing
Re: Help me choose a cam - 500ci [Re: DGS] #2419384
12/16/17 05:00 AM
12/16/17 05:00 AM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
Call Jim @ Racer Brown his CAMS make power he is good at choosing correct cam everything is custom ground 1410 866 7660
Re: Help me choose a cam - 500ci [Re: 71Pan] #2419438
12/16/17 01:08 PM
12/16/17 01:08 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Talk to Dwayne Porter on the board here, He picked the cam for my combo, which is similar to yours and it works great. Comp Cams Nitrided cam and EDM lifters.
The only Carbs I care about are under the hood!
Re: Help me choose a cam - 500ci [Re: DGS] #2419449
12/16/17 01:35 PM
12/16/17 01:35 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Would you consider a hydraulic roller? The ultimate in reliablity!
Re: Help me choose a cam - 500ci [Re: DGS] #2419551
12/16/17 06:09 PM
12/16/17 06:09 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I am using a solid FT cam from Dwayne Porter.
My engine is 470" 10.7-1 .040" quench RPM heads. Performer RPM intake, Comp Pro Magnum 1.5 rockers
244* intake 252* exh. @ .050"
.520 int .540 exh.
110 Lobe sep
Howard's EDM lifters
In @ 106*
Valves adjusted cold @ .012 and .014 "
I have dyno time only and the pulls started @ 3500 so I can't say for sure what we have below that RPM or what vacuum is either.
I would think with your heads and 500" your numbers would be higher, and maybe a lower RPM peak HP .
I hope that this info is helpful ? shruggy
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Help me choose a cam - 500ci [Re: 71Pan] #2419649
12/16/17 11:09 PM
12/16/17 11:09 PM
Washington
madscientist Offline
Washington
I agree 100%.
Jim wants you to call AFTER 5 pm eastern time. You get to talk to the guy who,is actually going to grind your cam.
Re: Help me choose a cam - 500ci [Re: DGS] #2419972
12/17/17 07:48 PM
12/17/17 07:48 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Thanks for all the great input! I'll definitely make some calls soon. Good to see that the cams/lobes I came up with are in the ballpark and not totally off.
