489 Case U-Joint U-bolt Straps #2415569
12/09/17 01:36 AM
12/09/17 01:36 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Switching out a 3rd member & the one I'm sticking in doesn't have threaded holes. It has smooth holes & a flat area to put a nut on the back side. I went to Napa & they have no idea what part number for a U-bolt kit to bolt these up. They looked thru all different years & models & just come up with the formed flat piece of metal & little bolts. Anyone know what year/model would use the u-bolt style U-joint hold downs?
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: 489 Case U-Joint U-bolt Straps [Re: grancuda] #2415576
12/09/17 01:52 AM
12/09/17 01:52 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
OE?
None.
Aftermarket parts.
Re: 489 Case U-Joint U-bolt Straps [Re: grancuda] #2415580
12/09/17 02:02 AM
12/09/17 02:02 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi cuda,look under brewers performance yokes page .it looks like you need the 1350 style with u bolts. measure and then call them. merry xmas.ronnie
Re: 489 Case U-Joint U-bolt Straps [Re: grancuda] #2415588
12/09/17 02:24 AM
12/09/17 02:24 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You have a 1330 yoke from a Chrysler Imperial constant velocity assembly.
You can use a Spicer #2-94-58X U-bolt kit and a 1330/7290 or 1330/7260 conversion U-joint to mate it to a common A/B/E body driveshaft.
Re: 489 Case U-Joint U-bolt Straps [Re: grancuda] #2415634
12/09/17 08:39 AM
12/09/17 08:39 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
It also looks like it has one of the locating tabs for one of the caps broke off. Am I seeing that right?
Re: 489 Case U-Joint U-bolt Straps [Re: buildanother] #2415680
12/09/17 12:35 PM
12/09/17 12:35 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Yes, I didn't even notice it had tabs to keep the u-joint cups in. I'm used to the snap rings that go around the inside of the caps retaining the U-joint cups.
Looks like I just need a new yoke.
2021 Toyota Supra
Re: 489 Case U-Joint U-bolt Straps [Re: grancuda] #2418233
12/13/17 11:43 PM
12/13/17 11:43 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
I lucked out & one of the tool makers at work was able to fix the yoke & the local, small town NAPA had the conversion U-joint in stock to go from the 7290 driveshaft yoke to the 1330 8 3/4" yoke. I was really surprised about that.
Now running the 2.94 open till summer & going to swap the 4.10 SG to either 3.55 or 3.73.
2021 Toyota Supra
Re: 489 Case U-Joint U-bolt Straps [Re: grancuda] #2418264
12/14/17 12:50 AM
12/14/17 12:50 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Take apart and measure your "conversion" u-joint cross. You might find that the four cross ends are exactly the same, and only thing different are the caps.
Re: 489 Case U-Joint U-bolt Straps [Re: BSB67] #2418301
12/14/17 01:39 AM
12/14/17 01:39 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
It is a SKF UJ458.
It all measured out right as far as cap diameters/widths.
2021 Toyota Supra
