Re: Mark Williams 8-3/4 caps worth it? [Re: StealthWedge67] #2418077
12/13/17 06:00 PM
12/13/17 06:00 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
No, not for $200. Looks like the MW caps are $130 EACH (quick ebay search). Not sure what it'd cost to machine the centersection for them, but I'd guess around 100 bucks. About the same as narrowing a rear. Even w/ the good caps, the main problem w/ the 8.75 is still not addressed and you'll still kill gearsets.
I've bought 2 junkyard Dana 60s for $125-150 each. Both came w/ good gearsets and one had the good powerlock diff. So after the initial cost, a pair of axles and housing ends, narrowing, and a pair of perches...ready to bolt in. The brake lines are what, 20 bucks max at the parts store. One of mine already had a 1350 yoke too.
I agree that if you already have a well set up 8.75, swapping to a Dana doesn't SEEM like a cheap option, but it is. Sell the 8.75 to someone who thinks they can use it and build a Dana. Then you can sleep well knowing you'll likely never break your rear again.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mark Williams 8-3/4 caps worth it? [Re: StealthWedge67] #2418080
12/13/17 06:08 PM
12/13/17 06:08 PM
Eagle, Idaho
Neil Offline OP
The Doctor is in.
Neil  Offline OP
The Doctor is in.
Eagle, Idaho
Machined as in having the mating faces shaved so the inside is perfectly round when it goes together? There is a diff shop here that knows their stuff, but I don't know if they can do the machining depending on what needs done. I have not talked to them about the caps.
I have a 489 case with 3.55 gears and a solid spacer. It was clear powdercoated years ago and it started to rust under the clear + it was weeping oil in a few spots so I took it out and removed the clear. I was just going to bolt it back in until I saw the MW caps.
I know the ring gear teeth can shear off and the axle tubes will bend inward under heavy racing. I know a local guy who ran one forever in a first gen Cuda and it wasn't until his car became capable of pulling the front end off the track did he start to have issues making him go to a Dana 60.
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418085
12/13/17 06:30 PM
12/13/17 06:30 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My dad had a 8 3/4 in his duster back in the mid 90's. (440 ran 7.30's in the 1/8th has been in the 6.80's more recent years) Would break a ring and pinion every year. Finally put a Dana in it in the late 90's and hasn't broke anything in the rear since... He did build a duster for my sister in 2011 with a 360 run's 11.80's with the 8 3/4 and hasn't had a problem with it...Keep the build simple and low torque and you'll be fine. Increase torque and power, you'll find the weak link.
Re: Mark Williams 8-3/4 caps worth it? [Re: DusterKid] #2418112
12/13/17 07:38 PM
12/13/17 07:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run high 8s in the 1/4 with a alum 8 3/4 but
the car in light.. I wouldnt waste my time with
a dana 60.. just go to a 9" which I did for my
Rampage being its a bit heavier.. its 2860 race
ready with a 18 gals of fuel.. but thats me..
the guys on this site think you HAVE to run a dana
when you dont.. JMO.. if your not running a tank
or have a ton of power then your fine.. it will
run a lot of years... its up to you what you want
and so far its been a 8 3/4 being that your looking
at caps
wave
Re: Mark Williams 8-3/4 caps worth it? [Re: DusterKid] #2418115
12/13/17 07:44 PM
12/13/17 07:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Please explain then how my stock capped 742 case has lived 14+ years and most of that at 3200 lbs. w/a BB 470, running low 6's in the 1/8 and 9.70`s(5 years ago)in the 1/4 w/1.3 60 fts.............. work
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418125
12/13/17 07:58 PM
12/13/17 07:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
When I did it I went to my engine builder with the empty chuck and the cap, he did the gross cut in the milling machine and the final cut in is rod cap grinder. At minimun do the left side, ring gear side, that side sees the higher loading.
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418145
12/13/17 08:57 PM
12/13/17 08:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have no issue running 8 3/4. 2 of my cars use stock parts without failure (12.50 stick, 11.0 auto). But if it was going in a car that was going to be raced often I'd use a junkyard Dana. Mine and Dizusters turbo car got new ends, axles, and a spool. I cut the ends and brackets off and welded on new perches and ends. Both started out as a 8 lug full floaters. Dizusters still uses the junkyard gear set. Mine uses recycled 8 3/4 factory housing ends. Spool, axles, and gears cost the same either way. With a Dana you'll get either a 3.55 or 4.10 so you may not even need to buy a gear. I'm cheap. Junkyard Dana's are a great bang for the buck.
Doug
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418147
12/13/17 09:00 PM
12/13/17 09:00 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yes, but you will have to size them....
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418221
12/13/17 11:27 PM
12/13/17 11:27 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My car runs mid 10's on a drag radial, footbraking. I don't have money to upgrade to a Dana or 9" right now so I bought a brand new Yukon Nodular iron center section with nodular caps for $250 With a spool and 35 spline axles I think it's good enough for now with my setup. Just another option for you.
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418285
12/14/17 01:12 AM
12/14/17 01:12 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
FWIW, I sell a new, super duty nodular iron 489 case with forged steel (counter-sunk allen bolt style) caps, and billet steel adjusters for $300.
You will spend more than that to put MW caps on a used case.
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418360
12/14/17 08:27 AM
12/14/17 08:27 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Just a bit more info on this, these caps are $105 if purchased from MW enterprises direct, someone is trying to make a fast buck out of a great manufacturer, and as far as I can find out the only one still producing this item.
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418363
12/14/17 09:10 AM
12/14/17 09:10 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I run one on my 489 center section for 20-something years lol, been 1.20's with a best of 1.26@3350 with no problem, but if I had to to it all over my choice will be a 9".Like Mr.P Body say I like the removable center section twocents
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418366
12/14/17 09:31 AM
12/14/17 09:31 AM
gregsdart Offline
gregsdart  Offline
If you ever think you will use a transbrake, or go to a bigger motor (bb)? I would lean to the Dana rear rather than spend $$$ on an 8 3/4. Shock loads and high torque, and or poor gear setup will kill ANY rear eventually. That is why they sell pro gears.
Re: Mark Williams 8-3/4 caps worth it? [Re: DoctorDiff] #2418443
12/14/17 01:24 PM
12/14/17 01:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If I were going to run an 8 3/4 hard this is what I'd run. My 408 broke the 8 3/4 in my Dart on the second pass it hooked up. The transmission had to come out and apart along with rebuilding rear. I sold the rear end complete after I went through it and ordered a new S-60 from Strange.
Looking back I wish I'd been patient and found a deal on a used 9" aluminum center section and bought a new housing and axles.
Re: Mark Williams 8-3/4 caps worth it? [Re: Neil] #2418743
12/14/17 11:16 PM
12/14/17 11:16 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Mine has survived 200+ passes with stock caps, 35 spline spool dead hooking radials with a transbrake and no issues so far. No bracing either. This while working through traction issues so it took lots of abuse. I do however plan to upgrade to Dr. Diff’s 489 nodular case with forged caps this winter as I was starting to get a little concerned about the caps.
