Any one buy from Mr G
#241783
03/03/09 10:12 AM
03/03/09 10:12 AM
340dart4spd
Parts Problem
Parts Problem
Re: Any one buy from Mr G
[Re: m46rat]
#241785
03/03/09 12:12 PM
03/03/09 12:12 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Do some digging on Google. I have read some threads where folks were not happy customers. Quality of work not always as expected and his 'personality' made some folks not want to deal with him.
I've had no dealings with him, so I'm just saying you should keep digging and draw your own conclusions.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#241786
03/03/09 12:27 PM
03/03/09 12:27 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I wouldn't use them if they were the only shop on earth! Several years ago I sent them beautiful plastic dash cores for re-chroming for a customer of mine (which they gauranteed I'd get back) and they sent me back someone elses junk, no reason, no excuses, horible after the fact service. The parts they sent were improperly detailed to boot and the quoted lead time was off by months. I've heard many other similar stories from others. You have several other choices these days, I see no reason to chance it with "G's". *I never used them for off the shelf items like screws etc.
[Re: ScottSmith_Harms]
#241787
03/03/09 12:31 PM
03/03/09 12:31 PM
OLD318
for nuts and bolts I don't think you can beat www.amkproducts.com. I redid a 70 Coronet, every nut, bolt, widget, doo-hickey, and screw. I found 99% of everything at that place. Not cheap, but definitely there! I did not find: factory A/C water valve mounting screws factory power steering gearbox bolts... Everything else you can either get an exact match right down to the plating and ensignia on the bolt or something very, close finish, size wise w/o the matching ensignia.. Good luck...
[Re: OLD318]
#241788
03/03/09 08:42 PM
03/03/09 08:42 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I just sent in my 68 Roadrunner bezel.. IT was in aveage shape for 40 year old plastic. In about a week I had a nice (NOT PERFECT) replated bezel that I am very happy with. Best of all it was made in USA..
[Re: earlybee]
#241791
03/03/09 10:37 PM
03/03/09 10:37 PM
i found his attitude is horrible and his work is the worst i have ever seen. run not walk. hes a disgrace to the hobby.
#241792
03/03/09 11:09 PM
03/03/09 11:09 PM
Posts: 1,022 Green Lane, PA
sawdust
Green Lane, PA
I had a 67 cuda dash rechromed by him, sent in plywood fitted foam case, received back in case but cracked at the radio holes like someone picked it up by one end and broke the plastic. Refused to make good on it as was damaged in shipment!!!! Due to poor packaging, [Edited by Moparts - Keep it clean]? Worse yet when taped off and painted the 3M tape pulled off the chrome. Never again, p poor customer service and accountability, would suggest Paul's Chrome plating in PA, as I understand they have a much better process for chroming plastic.
#241794
03/04/09 12:18 AM
03/04/09 12:18 AM
Posts: 28,604 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Same here Then the lady calls me back after everything is done{me getting rippped off} and tells me next time use a card that matches the address I am shiping to. I told her it was shipped to my work since they are there during biz hours and the card is at my home address. So if they deliver to my home no one is there to sign so work it is! I asked her did the payment go threw? She said yes.So whats the problem? They are thats the problem
[Re: 340dart4spd ]
#241796
03/04/09 11:43 AM
03/04/09 11:43 AM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
Same out come for http://www.cvvacuumplaters.com/ too! Sent a dash bezel for a 66 chevy there took 6+ months to get it ony to have it cracked. sent it back to get repaired since they were going to do it free. Got it back in 2 1/2 months with runs in the clear.
Contact Me about AMD Prices
