440 Bench Build
#2417487
12/12/17 06:26 PM
12/12/17 06:26 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I have grown bored with the 360 I built for my '72 Charger. IT has been a great engine but I am ready for more attitude in the car. I am ready to pull out a '74 model 440 I have had stored away for many years and build it for the Charger. The goal would be at 500 hp/torque at the flywheel. Where is the best resource for determining the parts needed for the application?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 440 Bench Build
[Re: dfsmopars]
#2417491
12/12/17 06:34 PM
12/12/17 06:34 PM
crabman173
crabman173
Easy way is call one of the many builders here Todd at Marsh Perf will put you dead on his Sidewinder heads are better than others in that price range and all you need--he can also put you on the rest of the combo--500HP is THE MAGIC number that 90% of all engine customers request for some reason 100 different ways to get there but with those heads and correct cheap flat tappet cam and then add in a set of the new Wiseco Street Protru pistons ( less than $425 with rings --lite and forged and awesome for a street build) add some PRW stainless rockers for cheap reliable performance in that category--pick your intake--I love the Performer RPM but it can be a pain with drop base thin air cleaner needed so the Holley Street Dominator still available new is low and makes killer street intake cheapo headers any 750 carb you can locate and Bam! ya gots 500 HP that will melt tires and be tons of fun
Re: 440 Bench Build
[Re: dfsmopars]
#2417523
12/12/17 07:14 PM
12/12/17 07:14 PM
dogdays
Choices: 4+ inch stroked 360 440 511 stroked 440 Any of the above will do 500 hp easily using modern parts. Stock Mopar engines of that era were hampered by three design deficiencies: 1. Cylinder head flow 2. Compression 3. Huge (heavy) reciprocating parts So for any Mopar engine of the ages in question, plan to replace cylinder heads with your choice modern aluminum head, work with us to get the compression right, and also in choices of rotating and reciprocating parts. A good place to start looking are the online vendors, starting with www.440Source.comCampbell Enterprises.com Mancini Racing.com Todd Marsh of Marsh Performance If you look into the Moparts sponsor lists you will find many good guys who live in the Mopar world. There are many tricks and traps to building a Mopar engine from the ground up. If you stick around here long enough you will begin to understand that there are board members who think a car is driveable if it idles at 1800rpm and gets 4.8 miles per gallon of race gas. SO, take cam recommendations with a grain of salt. There are a thousand ways to do ignition but there is no need to spend a zillion dollars unless it satisfies one of your urges. Sometimes you will ask a question and there will be a tornado of contradictory opinions. Don't be afraid to send a PM or two to get rid of the chatter. Don't start buying things before you know which way you're going. Don't jump at a particularly great deal on a particular part and then have to stand on your head to build the rest of the engine around it. Realize that by increasing the engine power in your car by 150 lb-ft of torque or 125hp that you will need to redo many of the systems such as drivetrain, brakes, chassis, etc. Finally, DO MAKE A BUDGET and be truthful about how much you are willing to spend. R. PS: I speak from experience on these warnings. My first cam swap resulted in the engine power increasing enough that it overpowered the suspension and I wrecked the car. I have a mountain of really excellent parts that won't fit my current needs, but they were a great deal at the time. I have another mountain of parts that have become obsolete before they were ever used. This represents literally thousands of dollars that have been spent with no chance of getting them back, or putting the investment to use. So if I can help you avoid those pitfalls, it would make me feel better about my own mess-ups.
Re: 440 Bench Build
[Re: dogdays]
#2417534
12/12/17 07:32 PM
12/12/17 07:32 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If my car was already set up for a small block, and I already had a 360 engine, and I only wanted 500 horsepower i sure as heck wouldn’t switch to a big block. But to each his or her own
Re: 440 Bench Build
[Re: dfsmopars]
#2417550
12/12/17 08:19 PM
12/12/17 08:19 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
If your not going to stroke it then you can build your basic mild 440 street bruiser as I did with my old combo. It was basically a stock crank and rod bottom end that I had the crank checked and the rods reconned with new ARP bolts. I use KB quench pad pistons to get quench with my 906 heads and 10.0 pump gas friendly comp. Then I ran Isky ductile adjustable rockers and the MP .557 solid flat tappet cam. Ran the Holley Street Dominator intake and my 850 DP. Basic Mopar electronic ign and Hedman 1-3/4 headers. The 906 heads I milled for 10.0 comp and ported them myself with new bigger valves. A very simple basic combo that is almost a stock 440 shortblock with home ported iron heads and a nice solid cam with bolt on's. In my 3725 lb 63 it ran a best of 11.49 @ 116 driven to the track and on pump through the exh. It was a nice running mild street driver that was good for 11.50's to 11.80 depending on the weather. Ron
Re: 440 Bench Build
[Re: dfsmopars]
#2417649
12/12/17 11:01 PM
12/12/17 11:01 PM
dfsmopars
Kentucky
Honestly I like posting in this section of Moparts the most because of the experience, knowledge and honesty of the replies. The unfortunate part for me is I have not needed to come in here since building the ‘95 5.9 about six years ago. Back then this section was a very instrumental in helping me on my first solo build. I used Hughes Engines for all the parts and technical guidance and the engine turned out just as I wanted. The current 5.9 is a full roller motor with iron Indy X heads. It winds up quick and made 275 hp/316 lb ft at the rear wheels with a 625 Carter (since replaced with a Quick Fuel). With a full interior, 44RE trans, stock suspension and with 3.55 gears it turned its best time at the Nats two years ago of 13.92 @ 97 mph. It ran out of air at the top end. Recently I had Hughes quote a stroker kit and heads for the 5.9 but as said by dogdays I need to make sure that it would satisfy. I also had Brewers quote a four speed four it for added fun. I’ve had a strong 383 and a stock 413 but never raw 440 torque.
Re: 440 Bench Build
[Re: dfsmopars]
#2417815
12/13/17 08:54 AM
12/13/17 08:54 AM
dfsmopars
Kentucky
OK let me ask this- a 5.9 Magnum stroked to 408 and produces 450 hp/475 lb ft compared to a basic 440 build at the same performance output what will be the difference in sound, feel and enjoyment? I also assume it would cost less to build a BB to reach the same numbers as a small block?
Re: 440 Bench Build
[Re: dfsmopars]
#2417916
12/13/17 01:47 PM
12/13/17 01:47 PM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
So many variables...
It sounds like you're building a street car. I would be more concerned about the torque curve than peak numbers. The more low end torque you have on tap, the more friendly a gear ratio you can run for street manners without negatively impacting the fun factor.
Your car has a relatively low curb weight, so a 408 would probably work just fine. Do you have overdrive transmission? A 450HP / 500ft/lbs 408 with a 3.91 gear is a hoot. My dad has that setup in his Diplomat coupe with a 518 transmission. It'll put the car sideways from a 40 MPH role with 275 tires on the back. There is a lot left in the motor too - heads are untouched Eddies.
Re: 440 Bench Build
[Re: MarkZ]
#2417934
12/13/17 02:13 PM
12/13/17 02:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a car with a 416 in it..was a solid roller and I took that out to run a FT cam.. it has all the torque that I want.. also I run a 518 OD trans and elec dumps for the track.. with 4.10 gears in OD and 295 tires I can cruise at 75mph at 2900 rpms.. it will get side ways in a blink if I roll into it .. before I swapped cams it was 595HP on the dyno.. now with fuel injection it drives great EDIT it did make 525 torque before the cam awap
Re: 440 Bench Build
[Re: dfsmopars]
#2418026
12/13/17 04:43 PM
12/13/17 04:43 PM
Posts: 43,282 Bend,OR USA
Cab_Burge
to make 500 HP with right at 500 FT Lbs. with a stock stroke 440 on pump gas may be harder to keep the torque even with the HP, normally the stock stroke motors with less than 10.5 to 1 compression all made 20 to 50 ft. lbs. more torque than HP The parts you need to make 500+ HP and torque are a decent set of aluminum heads and a good set of adjustable rockers, pistons that will make between 10.to 1 and 10.5 to 1 compression, a 850 CFM or larger carb., a Eddy Performer RPM intake and a decent cam with between 235 to 250 degrees @ .050 duration and as much lift as you can get at the valves and a decent set of headers and a minimum of 2.5 exhaust system on the car with a good set of Hi Po muffs That formula works good on midly ported Mopar iron heads with 2.14 and 1.81 valves with under 9.5 to 1 compression ratio so with the better aluminum heads like the Eddy RPM and the increase in compression you should be nearer 550 HP than 500 HP Let us know what you decide to do, a good SB stroker will work well also so compare the costs and effort needed before deciding
Re: 440 Bench Build
[Re: dfsmopars]
#2418412
12/14/17 12:19 PM
12/14/17 12:19 PM
dfsmopars
Kentucky
I keep thinking that improving the 5.9 is the way to go. Block and heads are proven. Don't have to swap out the k-member and suspension. I got a quote from Hughes Engines a couple of months ago for the stroker kit (425 hp/475 torque) when I started thinking about it. As a way of a competitive quote and second source for the entire SB stroker kit who would be a recommended vendor?
Re: 440 Bench Build
[Re: dfsmopars]
#2418431
12/14/17 12:50 PM
12/14/17 12:50 PM
MR_P_BODY
I think the 5.9 might be the way to go.. you can get them fairly cheap for a complete engine but you might want to get a hold of some of the builders on this site to see what they can do for you
Re: 440 Bench Build
[Re: ]
#2418442
12/14/17 01:16 PM
12/14/17 01:16 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Easy way is call one of the many builders here Todd at Marsh Perf will put you dead on his Sidewinder heads are better than others in that price range and all you need--he can also put you on the rest of the combo--500HP is THE MAGIC number that 90% of all engine customers request for some reason 100 different ways to get there but with those heads and correct cheap flat tappet cam and then add in a set of the new Wiseco Street Protru pistons ( less than $425 with rings --lite and forged and awesome for a street build) add some PRW stainless rockers for cheap reliable performance in that category--pick your intake--I love the Performer RPM but it can be a pain with drop base thin air cleaner needed so the Holley Street Dominator still available new is low and makes killer street intake cheapo headers any 750 carb you can locate and Bam! ya gots 500 HP that will melt tires and be tons of fun Thats by far the easiest and most simple way to do it....100% spot on, unless he is going to keep the small block, which is almost the same recipe there too, other than the intake.
RIP Monte Smith
