69 B body lost keys - codes on locks/ign. switch #2417444
12/12/17 05:05 PM
12/12/17 05:05 PM
GA
roadrunninMark Offline OP
GA
Is there a way to find out the key codes if you just have the locks/ ignition switch? Are they located on them somewhere or what is the solution to get a set of working keys?
Re: 69 B body lost keys - codes on locks/ign. switch [Re: roadrunninMark] #2417446
12/12/17 05:07 PM
12/12/17 05:07 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
There is a code on the ignition switch for '70 up, not sure about others.
Someone here mentioned they could make keys from the code here a year or so ago, Dan maybe?
Edit;
Photo of the key code on a 1970 model year ignition switch;
Re: 69 B body lost keys - codes on locks/ign. switch [Re: roadrunninMark] #2417451
12/12/17 05:19 PM
12/12/17 05:19 PM
GA
GA
Is that LTDan? If I don't any other answers, I'll give him a shout.
Re: 69 B body lost keys - codes on locks/ign. switch [Re: roadrunninMark] #2417453
12/12/17 05:24 PM
12/12/17 05:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I think it was Dan P. aka 6bblgt?
Edit;
Link to an older thread;
https://board.moparts.org/ubbthreads/ubbt...-by-6bblgt.html
Re: 69 B body lost keys - codes on locks/ign. switch [Re: roadrunninMark] #2417463
12/12/17 05:39 PM
12/12/17 05:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Local locksmith can make them from your door/ign lock cylinder.
If someone actually saved the knockouts from the car's original keys, buy a lotto ticket on your way to the locksmith!
Re: 69 B body lost keys - codes on locks/ign. switch [Re: roadrunninMark] #2417469
12/12/17 05:49 PM
12/12/17 05:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You can read the insides without too much effort by removing tin cap, hardware, springs etc.
