70 Charger R / T finish panel restoration
#2417357
12/12/17 02:34 PM
12/12/17 02:34 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
I just started restoring some 70 Charger R/T finish panels. I am also converting a standard Charger finish panel to an R/T panel .
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
Re: 70 Charger R / T finish panel restoration
[Re: chargervert]
#2417458
12/12/17 05:32 PM
12/12/17 05:32 PM
chargervert
I am converting a standard Charger finish panel to an R /T finish panel. I removed the Charger arrow emblem and drilled new holes. The new emblems cover the original holes in the panel.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#2417465
12/12/17 05:42 PM
12/12/17 05:42 PM
chargervert
I used a Scotch bright pad and Mothers mag wheel polish to clean the exposed aluminum stripe. Then I fixed any dents and tweaked it until it was straight. These are parts that have to be handled with care. These panels are fragile. I cleaned the panel with lacquer thinner, then masked off the stripe with fine line tape. I used Rustoleum satin black paint on the panel. I carefully removed the tape before the paint cured. I installed the new emblems the next day. Here is the finished product.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: 70RT Charger]
#2418458
12/14/17 01:40 PM
12/14/17 01:40 PM
chargervert
I thought about painting the silver stripe,but it cleaned up enough to be passable. I have three 70 Charger R/T projects in the works,so I still have two more panels to do.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#2418465
12/14/17 01:47 PM
12/14/17 01:47 PM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
Did you coat the bare aluminum with anything after you painted the black? I assume you sanded through the original anodizing and are now exposing the bare aluminum. Just curious!
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2418469
12/14/17 01:55 PM
12/14/17 01:55 PM
chargervert
I only used a scotch brite pad with Mothers mag wheel polish on it. The other panel I have is going to need to be sanded like you said. I will used satin clear on that one so it won't oxidize.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: yellow70charger]
#2418873
12/15/17 04:40 AM
12/15/17 04:40 AM
chargervert
I got the emblems from Vans. They do not reproduce the Charger tailpanel script emblem for 70 Chargers. I bought the 69 Charger tailpanel script with the arrow on it and cut the arrow off it. The emblem is the same except for the arrow. The 70 R/T tail panel emblem is available.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
