Page 3 of 4 1 2 3 4
Re: Engine Build Philosophy: Port Size vs Application [Re: GTX MATT] #2416882
12/11/17 06:20 PM
12/11/17 06:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted By GTX MATT
Originally Posted By RAMM
Victors should be used only by masochists
Do you follow Brad's posts on here?
Brads Victors were less work than his stage 6's(well, pretty much any non-Chapman stage 6's)......and no more time or labor intensive than a set of 280cfm 906's.
Re: Engine Build Philosophy: Port Size vs Application [Re: HotRodDave] #2416922
12/11/17 07:35 PM
12/11/17 07:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By HotRodDave
It seems to me that a too big of port thing is not as important as it seems at first glance, a stone stock 392 CID GEN III hemi runs great at 2000 RPM with huge ports, next time you drive one with a 6spd try lugging it at low RPM, seems to run just fine, as a matter of fact the eagle 5.7 has almost as big of ports with even less displacement and make plenty of TQ down low and has great throttle response once the DBW crap is tuned right.
Wet flow dynamics is more than just high velocity. These modern engines work so well because the engineers work on improving all aspects like flow, swirl, velocity, cam timing, runner length, ex flow, chamber shape, spark plug placement (find a way to get the plug in the richest mixture part of the chamber), cool intake air (hint... the manifold is a lot more important in keeping the charge cool before entering the chamber than the part the air filter is hiding in).
Bottom line is you can still make big TQ with big efficent ports but you can not make big HP with little ports no matter how "efficent" they are. I got a set of modern cylinder head CNC 302 casting heads and velocity is incredible but even jeff said he had a hard time making 500 hp with em but TQ was great. You just got to find a balance that works for you.
Your talking dry flow VS wet.. 2 different worlds
I love the power in my 416 W2.. its injected
with multi port injection.. it was less power with
the carb on the street.. but I did make some changes
so its not 100% the same... I did go with a smaller
cam for one thing
wave
Re: Engine Build Philosophy: Port Size vs Application [Re: BradH] #2416923
12/11/17 07:37 PM
12/11/17 07:37 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted By BradH
HRD - I don't think that's an apples-to-apples comparison. How's a 426 N/A Drag Pak with a 270+ at .050" cam pull at 2000 RPM under a load? And how would it behave if it was also retro-fitted with a carb and old-tech mechanical-advance ignition?
The original question was port size vs aplication, this is a very exagerated example of really big ports in both size and flow for the CID but still makes plenty of TQ in the aplication and velocity will be really low at lower RPM yet it works. If you heard of someone putting heavily ported W2s (similar flow to an eagle but smaller cross section) but on a stock 340 short block you would think they were crazy and going to kill there streetability but the Gen III engine seems to defy old school logic. All I am saying is you can not just say you need velocity more than flow, there is a lot more to it and some of the old hard fast theory no longer seems to hold up. Now we have a 485 hp SAE Net 392 with plenty of low end TQ.
Re: Engine Build Philosophy: Port Size vs Application [Re: HotRodDave] #2416953
12/11/17 08:35 PM
12/11/17 08:35 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
The original question was port size vs aplication, this is a very exagerated example of really big ports in both size and flow for the CID but still makes plenty of TQ in the aplication... Now we have a 485 hp SAE Net 392 with plenty of low end TQ.
True, as it is w/ the GM LS7 "stuff". But what works using current tech doesn't always apply -- much less retro-fit -- to the old sh!t most of us are building on here. laugh2
Re: Engine Build Philosophy: Port Size vs Application [Re: HotRodDave] #2417043
12/11/17 10:56 PM
12/11/17 10:56 PM
jersey
Spaceman Spiff Offline
jersey
What do you consider " big HP?" Modified eliminator guys were running in the 9's, under 300 cubic inches, and with stock head castings. and that was 40 years ago.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Engine Build Philosophy: Port Size vs Application [Re: Spaceman Spiff] #2417177
12/12/17 03:15 AM
12/12/17 03:15 AM
When you discuss the old days in Modified eliminator you have to remember that all those drivers let the clutch out at 8000 + RPM with either 6.17, 5.86 or maybe as tall as 5.57 with a 3.25 low gear and shifted them between 8500 up to 9800 RPM, NO torque what so dang ever shruggy
They idle at 1500 + RPM, those motors flat scream from when the top bulb came on until they let off on the other end, none of those motors ran in gear below 2500 RPM until they stuck the clutch in to reverse directions or were shutting the motor off shruggy
Re: Engine Build Philosophy: Port Size vs Application [Re: Cab_Burge] #2417227
12/12/17 09:30 AM
12/12/17 09:30 AM
jersey
jersey
That was my point. Those cars made big HP, from little cubes, and a production head, with not very large ports( compared to what is available in the aftermarket today).
Re: Engine Build Philosophy: Port Size vs Application [Re: Spaceman Spiff] #2417392
12/12/17 03:42 PM
12/12/17 03:42 PM
The smaller the motor the more sensitive it is to port size at WOT below peak torque RPM up
Did you ever drive a 351 Cleveland powered Mustang or Torino? Talk about port size being over sized for the application whistling grin They where dogs to me below 5000 RPM down
Re: Engine Build Philosophy: Port Size vs Application [Re: BradH] #2417505
12/12/17 06:51 PM
12/12/17 06:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Glad the cleavland was brought up, it is about 2.9 square inch and the eagle 5.7 is about 3.0 sq inch. One is good at making TQ and one sucks both are good at making HP but one is better.
Re: Engine Build Philosophy: Port Size vs Application [Re: BradH] #2417578
12/12/17 08:56 PM
12/12/17 08:56 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice analysis and research, good reading and food for thought as ever.
Is there a timeframe for the ol' E body to come back out with the new bullet in it?
Any changes anticipated to better accommodate the motor?
Rich H.
Esse Quam Videri
Re: Engine Build Philosophy: Port Size vs Application [Re: HotRodDave] #2417716
12/13/17 01:02 AM
12/13/17 01:02 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Put port injection and a fast burn chamber that only needs 25 degrees of timing on the Cleveland and I think the torque gap disappears.
Kevin
Re: Engine Build Philosophy: Port Size vs Application [Re: Twostick] #2417718
12/13/17 01:06 AM
12/13/17 01:06 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Comparing old to new is a bit moot, New motors have either port or dirct chamber fuel injection, the manifold and port only have to move AIR and not carry fuel in suspension. Put a carb manifold on a modern hemi in a 4400 pound car nd watch the torque plummet at low/medium piston speeds.
The cleveland in smaller 2V form still needed a long skinny intake manifold runner just ot make decent torque, and the 4V was a bit soft on the bottom end unless you had steep gears, you basically had a smallblock with a 427 Chevy size intake port , they used to sell port stuffer sheetmetal plates to pick up the velocity in the Cleveland heads which blocked the lower third of the port....but Clevelands still make really stout 408+ " short rod stroker motors.
WIZE
In Car:
Re: Engine Build Philosophy: Port Size vs Application [Re: BradH] #2417762
12/13/17 02:14 AM
12/13/17 02:14 AM
AndyF Offline
AndyF  Offline
I had a 351C 4V in my '56 F-100 pickup when I was in high school. No idea how much torque it made but I'm lucky I'm still alive. I'd drive that truck on a two line highway over to visit a girlfriend and I would pass 5 or 6 cars at a time. Just punch it from 55 and it would bury the speedo in nothing flat. 100+ mph in a '56 F-100 with drum brakes and a straight axle was not the smartest thing to do. But I was only 17 and didn't know any better! I don't recall any flat spot in the torque curve.......
Re: Engine Build Philosophy: Port Size vs Application [Re: BradH] #2417763
12/13/17 02:16 AM
12/13/17 02:16 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Newer engines also have variable runner length intake manifolds, this is an OLD Harley engine I built, this is a 94 inch Harley, very old design with heads I ported on the large side for cid, it is also EFI, the blue run on the dyno is with a 8 inch long individual runner length, very gutless down low, the red line is with 22 inch runners, everything else is the same, tie both these power bands together with a Variable runner set up & you will have something that has power all over the place with a HUGE intake port on the cyl head. this is only for a 2 cyl, X the results by 4 for an 8 cyl
Re: Engine Build Philosophy: Port Size vs Application [Re: AndyF] #2417764
12/13/17 02:19 AM
12/13/17 02:19 AM
When your 17 yrs old and ten feet tall, bullet proof and Superman nothing bothers you does it whistling
It never bother me when I was that way whistling realcrazy grin
Re: Engine Build Philosophy: Port Size vs Application [Re: HotRodDave] #2417852
12/13/17 12:04 PM
12/13/17 12:04 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Look at the flow out of the box though, the Hemi head flows ~50 CFM more at .300 (190 vs 240) and ~60 CFM more at .600. (270 vs 330).
Re: Engine Build Philosophy: Port Size vs Application [Re: CSK] #2417876
12/13/17 12:41 PM
12/13/17 12:41 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
The yamaha r600 has something simular to what you found. The velocity stacks electronically lift off the carbs at a certain rpm for better top end power. Best of both worlds. That 600 red lines at 18000 rpm. If we could just do this with our motors we would really have something.
Re: Engine Build Philosophy: Port Size vs Application [Re: mopar dave] #2417927
12/13/17 02:02 PM
12/13/17 02:02 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
So do most of the gen3 Hemi's, Active Intake Control
Re: Engine Build Philosophy: Port Size vs Application [Re: CSK] #2418019
12/13/17 04:34 PM
12/13/17 04:34 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
only the trucks have active runners and only on 09 up
Re: Engine Build Philosophy: Port Size vs Application [Re: ZIPPY] #2418044
12/13/17 05:12 PM
12/13/17 05:12 PM
BradH Offline OP
BradH  Offline OP
Thanks. grin
2018... or my family will find me swinging by a rope tied around my neck on New Years Eve 2019
Replaced the 8.75" with a Strange S-60, and the S-60 has CalTrac's reinforced spring perches to take the hit off the line better
Went back to 22" front spring segments from the SS-spec 20" while staying w/ CalTracs and their mono-leaf springs
Switched from 8" to 10" rims to help spread the footprint of the 275/60R15 drag radials; also going with M&H radial "skinnies" up front that will lower the ride height of the car a tad
The Drag-Pack inspired hood mod gives me room for an air cleaner and at least some amount (1/2" or maybe 1") of carb spacer; I wasn't even sure the standard T/A scoop would fit a 3" air cleaner with the Victor heads & a tall intake like a Victor or Trick Flow
Maybe some other things that don't come to mind at the moment...
Probably need better rear dampers than my old Rancho 5-ways; a nice DA would help getting the rear suspension dialed in
Page 3 of 4 1 2 3 4
