Re-drilling axles for 5/8" studs
#2416052
12/10/17 03:18 AM
12/10/17 03:18 AM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
I have Strange axles that need 5/8 studs, can it be done without super expensive tooling? Boring the holes is no problem but I'm concerned about tapping.
Steve
Photobucket sucks
Re: Re-drilling axles for 5/8" studs
[Re: Dave Hall]
#2416114
12/10/17 11:56 AM
12/10/17 11:56 AM
72chrgrally
Hamilton,Ont
What does Strange want to do it? I inquired about it via e mail and they suggested buying new axles.
Photobucket sucks
[Re: 72chrgrally]
#2416212
12/10/17 02:57 PM
12/10/17 02:57 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
What does Strange want to do it? I inquired about it via e mail and they suggested buying new axles. Of course they do.You might consider bringing your axles to a machine shop for precision.
[Re: 72chrgrally]
#2416298
12/10/17 04:48 PM
12/10/17 04:48 PM
72chrgrally
Hamilton,Ont
My good friend is a machinist and he told me cutting the holes wasn't an issue but he did not have a tap he was confidant in to cut the threads. I really don't want to buy a $300 tap to thread 10 holes.
Photobucket sucks
[Re: The Shadow]
#2416366
12/10/17 07:04 PM
12/10/17 07:04 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I have Mark Williams axles years ago I broke the 1/2 studs I had, i sent them back to Mark Williams and had them redrill the axles and install 5/8 studs and haven`t had a problem since it wasn't expensive. Perhaps Strange could do it for you
[Re: 72chrgrally]
#2416380
12/10/17 07:41 PM
12/10/17 07:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What does Strange want to do it? I inquired about it via e mail and they suggested buying new axles. If thet wont do it send them over to Mark Williams or on of the other axle companies.. dont bother to try it yourself
[Re: 72chrgrally]
#2416395
12/10/17 08:19 PM
12/10/17 08:19 PM
72chrgrally
Hamilton,Ont
I'll do some more research, a friend of mine has done his own axles in the past and he has a tap he claims will do the job. I'll let everyone know how it goes. If I end up needing to get axles I'll be narrowing my rear end another 2".
Photobucket sucks
[Re: 72chrgrally]
#2416476
12/10/17 10:35 PM
12/10/17 10:35 PM
Posts: 11,693 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Tried to machine Strange axles by hand one time, only one time. Many years ago. That job is listed in the Strange catalog as part #A1065 for $80.
[Re: 72chrgrally]
#2416644
12/11/17 04:07 AM
12/11/17 04:07 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have Strange axles that I bought years ago for my Barracuda. Last year I found I broke 1 stud and bent the other 4 on one axle. As I had did business with Moser before I sent them to them to have the holes re drilled for 5/8 studs. Moser called and said the axle flanges were to hard to drill, they didn't know why. So I called Strange, they said ship them, they could do it. Called Moser, asked if they could ship the axles to Strange to avoid shipping back to me then reshipping to Strange, no problem. Moser called Strange and Strange told them they wouldn't accept them as I didn't have an account with them. I asked why that Strange didn't tell me that when I was talking to them? Moser asked Strange the same question and the guy got nasty . So I called Strange back, got an account set up to send the axles back to them. While I was on the phone I questioned again weather they could re drill / tap the hardened flanges. Answer was yes, continuing with the conversation , why don't you check with the machinist who does the work. He came back with [ As long as they haven't been welded on ] I replied that the bearing retainer ring was tack welded on from them. Then came the screaming. WE DON'T DO AXLES WITH BEARINGS ON THEM, [ Moser does ] YOU HAVE TO REMOVE THEM, IF WE DON'T LIKE THE WAY YOU CUT OFF THE RETAINER WE WON'T DO THEM AT ALL. I didn't say it but F U Strange. Called Moser back and just had them ship them back. Installed new ARP 1/2 studs. Moser took all the dimensions from my axles so if I need another set they WILL get the call.
[Re: 72chrgrally]
#2416791
12/11/17 03:37 PM
12/11/17 03:37 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Part #A1065 says "Axles must be sent in with bearings and studs removed".
Strange says "Do NOT weld on an axle".
They won't touch an axle if either instruction is ignored. Doing anything to an axle that has been welded on, or that has been hacked up when the wedding ring is removed, and then sending it back, is a huge liability when the thing breaks.
Following instructions and sending them back to the guy who made them would have made it easy.
[Re: SportF]
#2417021
12/11/17 10:27 PM
12/11/17 10:27 PM
MR_P_BODY
The pair of Strange axles that are in my car right now have about a 1/4 turn of twist in them.. all right near the splines(within about a 1/2").. still going strong
[Re: 72chrgrally]
#2417024
12/11/17 10:31 PM
12/11/17 10:31 PM
rowin4
I bought the axles, retaining axle plate and bearings installed from Strange. They tack welded the retainers on.
