Re: Carter 750 rebuild questions
[Re: NTOLERANCE]
#2416679
12/11/17 10:20 AM
12/11/17 10:20 AM
RapidRobert
there have been issues with that carb but I have one that I am going to rebuild/use. I bought it for $25 way back (on here) so it might be one of the problem ones but I knew that going in. If you have a bucket of soup I would soak it in that & several times go in there & swish it around then let it set some more, then rinse it with solvent & blast out the passages with brake kleen then shop air. I'm sure it is the std 2 step rods (cruise/power). that's all I can add for you.
[Re: lewtot184]
#2416721
12/11/17 12:52 PM
12/11/17 12:52 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I've had pretty good luck soaking them in carb/parts cleaner using an ultrasonic parts cleaner. I found a good used one through craigslist and use the heck out of it for neglected carb cleaning: everything from cars to motorcycle and small engine carbs.
Then spray all the passages with aerosol carb cleaner. I'll sometimes carefully use a welding tip cleaner to run through suspect passages. I know that's not recommended. The pipe cleaner approach mentioned is a safer one.
Ditto on the previously mentioned accelerator pump plunger.
Generally I've been able to get them running ok again. I've never cared for the step up rod design, but it's sure used in a lot of different carburetors.
That said, I did have one of that style that never would cooperate no matter what I tried. That one went down the road at a swap meet, with a tag saying it had been gone through but would not run right. Guy took it for $25 and was happy to get it. He said he could fix it.
Being simple minded I've always preferred the Holley jet number scheme for tuning. The combination of jet, step up rod and springs always drove me crazy.
Lead, follow or get the hell out of the way
[Re: lewtot184]
#2418785
12/15/17 12:33 AM
12/15/17 12:33 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
i'm thinking that with the blue accelerator pump and .098" primary jets that the carb is a 625 not a 750. Guess I shoulda ran the numbers. You're correct. 625.
