Page 2 of 2 < 1 2
#2366101 - 09/05/17 08:56 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
NV69B7RR Offline
Loc: Reno, Nevada
Very cool Sami. You going to autocross it? AWD can be a lot of fun!
72 Demon 340
71 Duster 340 Resto http://board.moparts.org/ubbthreads/show...part=1&vc=1
#2366181 - 09/05/17 11:08 PM Re: 275/35/18's on a Dart [Re: NV69B7RR]
MuuMuu101 Offline
I got lucky at Woodward!
Loc: SoCal
Originally Posted By Frankenduster
Really? No witty comment?
Nah, it's blue and pretty cool. laugh
Probably not, or at least anything competitively, unless my Dart is down. I've driven it about 300 miles since Thursday and it's pretty fun and the ride quality is 1000x's better than my Scion. I love how you can just throttle through the corners. Plus, this is my first turbo car so that's always fun to deal with. I'm going to try to baby this car as much as possible for a daily driver unlike my Scion.
Besides that, the plan is to pick up the Dart on Friday. We'll see how finances go, but maybe I'll bite on wheels and tires early. wink I want to do quite a bit of measuring first to see what wheels will work.
Ignore the Chevy Spark in the background.
68 Dart GT Project Thread: Linky!
#2367775 - 09/09/17 03:36 AM Re: 275/35/18's on a Dart [Re: MuuMuu101]
MuuMuu101 Offline
Loc: SoCal
The car drives a lot better with 1.18" T-bars and the leaf springs moved in, but now I think I have transmission problems... confused
I drove the car from the shop to my work and then to my gf's house (about 30 miles all on streets) and it seemed to do fine. Later on in the day, my gf and I went on a little joy ride and the Dart was great. My gf was ecstatic and loved it. It was really fun.
Well, a couple hours later I had to take on the 30 mile journey home (mostly freeway). When I started the car, I kind of had a feeling there was a problem. I could sort of hear a little clunking noise from the car as it was idling and every time I pushed the clutch pedal it went away, but I wasn't sure. I put the car in reverse and backed out and as I shifted into 1st and was moving forward, it sounded like a mystery bolt came loose and clunked around for a second, dropped out of the car, then the car stopped and shut off. Keep in mind, the car was still a little cold (135-150F water temp) and has shut off on me when trying to move the car in 1st if it's not too warm (I rushed the warm up a little as I was trying to get home as it was late). I immediately started the car back up again and the noise was gone. I didn't want to scare my gf, so I drove away, planning on pulling over in a nearby neighborhood in case something happened as I didn't want her to worry (I know, not the smartest idea).
Well, as I was driving, the car felt fine, until I got on the freeway. It could just be me since I haven't driven the car in 2 months, but it felt like the car was fighting itself to stay at speed (70-80 mph). My frame of reference could be out of wack because I just got a new daily driver last week and have been driving that a lot. But I also noticed that when I hit the exhaust drone RPM band and tried cruising at that speed that the vibration was a lot more than usual, but would smooth out significantly after I raised the engine speed outside of drone RPM. Lastly, what I thought was kind of weird, and I don't remember it doing this before, was that sometimes when I'd try to accelerate to pass a car (let's just say I'm at 2500 RPM in 5th gear) the RPM would rise to about 3000 (still in 5th) for a second or two, but the car would stay at the same speed, then the RPM would drop to about 2700 RPM and it would increase speed by a small amount. This also did sometimes occur when shifting from 5th to 6th and vice versa. It may have done it before, but who knows, my memory could be off.
Anyways, I ended up getting home safe, but now I'm all freaked out that I have a transmission problem and I'm tired of spending money on this car. I swear this car hates me. I'm pretty frustrated with it at this point and if this ends up being something big, I'm parking the car until next June (when I finish my masters) because I don't have the time, patience, or money anymore to work on it. But who knows, this could all just be me and my tiredness.
#2367777 - 09/09/17 04:25 AM Re: 275/35/18's on a Dart [Re: MuuMuu101]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
A bolt holding the pressure plate could have rattled loose and fallen out. This will result in UNeven pressure to hold the clutch, especially under power.
#2367961 - 09/09/17 03:16 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
MuuMuu101 Offline
Loc: SoCal
That would make sense. It seems like the clutch discs were slipping when trying to pass cars (no bueno). I have the car propped up in the front under jack stands, but it seems like all of the bolts on the outside and all along the drivetrain are still intact. I'd hate to pull the trans out of this car.
#2367985 - 09/09/17 05:07 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
RylisPro Offline
Loc: NorCal
The T56 Magnum isn't that bad to pull out and service. I have done it myself when I had to flip the ring gear on my flywheel around. The worst part is putting everything back & aligning the trans so that the splines line up but its easy with the clutch tool and when you use the drive shaft to spin the input shaft. Also having the car on jacks as high as possible and a trans jack helps!
/Drive
Instagram: @rylispro
YouTube:RylisPro
www.rylispro.com
925-214-9192
Tremec T56 Magnums & Quick Time bells
Lightened Billet Steel Flywheels
Prefix Performance
#2368052 - 09/09/17 08:10 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
MuuMuu101 Offline
Loc: SoCal
What's a clutch tool? Getting the car high up on jack stands has been difficult for me and on top of that, I don't have a trans jack besides me bench pressing it. But this does not sound like a fun job.
#2368085 - 09/09/17 09:39 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
Loc: Granite Bay CA
A "Clutch tool" is a plastic copy of the input shaft of the transmission. It is used as a dowel to properly position the clutch disc in exactly the right position while bolting on the pressure plate. It aligns the clutch so that the transmission should (In theory) bolt right up.
I would make sure to put LOCKTITE on the pressure plate bolts!
#2368099 - 09/09/17 10:09 PM Re: 275/35/18's on a Dart [Re: Frankenduster]
MuuMuu101 Offline
Loc: SoCal
Blue or Red? laugh
#2368251 - 09/10/17 10:37 AM Re: 275/35/18's on a Dart [Re: Frankenduster]
NV69B7RR Offline
Loc: Reno, Nevada
[ I could sort of hear a little clunking noise from the car as it was idling and every time I pushed the clutch pedal it went away, but I wasn't sure. I put the car in reverse and backed out and as I shifted into 1st and was moving forward, it sounded like a mystery bolt came loose and clunked around for a second, dropped out of the car,
quote=Frankenduster]A bolt holding the pressure plate could have rattled loose and fallen out. This will result in UNeven pressure to hold the clutch, especially under power. [/quote]
I'm going to guess that he's right. Put the car up on jackstands, pull the inspection cover off and check to make sure all of the bolts holding the clutch/pressure plate to the flywheel are still there by rotating the engine over.
Is there anyway to go look for that mystery bolt? Finding it may answer the question of where it came from rather quickly.
Edited by NV69B7RR (09/10/17 10:40 AM)
72 Demon 340
#2368293 - 09/10/17 11:36 AM Re: 275/35/18's on a Dart [Re: NV69B7RR]
MuuMuu101 Offline
Loc: SoCal
Where's the inspection cover? The bellhousing doesn't really have any slots to inspect the pressure plate.
I'd have to go to my gf's house and look around the street to find the bolt.
#2368436 - 09/10/17 05:57 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
BergmanAutoCraft Offline
Loc: Long Island, NY USA
I run 275 35s square as well. BFG Rival S. 18x9s.
Trimmed rear lips, moved springs in 5/8". Removed front lips entireley. No rubs even in track conditions.
#2368763 - 09/11/17 10:13 AM Re: 275/35/18's on a Dart [Re: MuuMuu101]
NV69B7RR Offline
Loc: Reno, Nevada
My apologies, apparently there is no inspection cover on a Quicktime T56 SBM bell housing. Guess you have to pull the trans. Good news is the bolt is probably still in there.
72 Demon 340
#2383180 - 10/06/17 08:36 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
MuuMuu101 Offline
Loc: SoCal
So, I just sent the Dart to a credible trans shop and they seem reasonable and will get the work done so, it's back to thinking about wheels and tires.
So, I'm doing the math, and I'm not sure if the 275/35/18's are going to fit very well with the wheel setup I have. I only gained about 0.5" with the offset shackles. Curently, the rears are rubbing on the quarters. I'm trying to keep things affordable as much as I'd like the Enkei's. I'm thinking about going to Bridgestone Re-71R's 265/35/18's with the M/T 18 x 9" +32mm wheels and +5mm spacers. I'm hoping with the 9" wheels, it will bring the sidewalls in a little for clearance. I know it's not ideal, but I just want to make sure everything fits. I'll test fit the front wheels on the rear for reference when I get the car back.
#2383225 - 10/06/17 10:02 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
Loc: Granite Bay CA
That is a great chart, Samy. Thank you.
#2383541 - 10/07/17 05:39 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
MuuMuu101 Offline
Loc: SoCal
I also found these little tiny front spacers (+2-3mm = 0.090"-0.125") to add with my +5mm spacers to buy me a tad extra room. +7-8mm total spacer.
https://www.summitracing.com/int/parts/wil-300-10716/overview/
https://www.summitracing.com/int/parts/joe-38120/overview/
#2409966 - 11/27/17 11:10 PM Re: 275/35/18's on a Dart [Re: MuuMuu101]
MuuMuu101 Offline
Loc: SoCal
Well, I just poked around at Summit to see my wheels (M/T SC-5, 18x9, +32mm). I put them in my cart and hit checkout and it seems that Summit says they're discontinued and they only have one in stock. So, I may end up going to Enkei's in the future. I just don't know when due to finances. I'd need a higher paying job or a big raise (not going to happen where I work) in order to afford them.
#2416637 - 12/11/17 12:43 AM Re: 275/35/18's on a Dart [Re: MuuMuu101]
MuuMuu101 Offline
Loc: SoCal
I flipped the front and rear wheels on the Dart yesterday to see how much room I have. With a +27mm offset wheel and a 255/40/18 on an 18x9" wheel, I have about 3/4" of room on each side. A 275/35/18 might seem easier than I think, even with the +35mm Enkei's I was thinking about getting.
First 3 pictures display the room between the tire and the leaf springs, inner wheel well, and outer fender in the rear. Pictures are upside down.
Last picture is how close the wheel is to the outer fender in the front with -10mm offset (from +32mm to +22mm offset).
All pictures are from the driver's side.
#2416641 - 12/11/17 12:55 AM Re: 275/35/18's on a Dart [Re: MuuMuu101]
MuuMuu101 Offline
Loc: SoCal
I'm thinking about going with Falkens in the future as they're cheaper and likely to fit better than the Bridgestones even though the Falkens don't perform as well. But we'll see when I'll be able to afford them.
1st picture is for 255/40/18 Michelin Super Sports.
2nd picture is for 265/35/18 or 275/35/18 Falken Azenis RT615K+.
3rd picture is for 265/35/18 or 275/35/18 Bridgestone Potenza RE-71R.
Page 2 of 2 < 1 2
25,737 Registered Members
192,817 Topics
Rotella Synthetic Rebate
by ZIPPY
36 minutes 40 seconds ago
73-79 Dodge PU Roof Repair/Replacement
by dart4forte
Today at 01:43 PM
Need more rear spring
by mickm
Today at 01:37 PM
Lexan
by SpeedRacer
Today at 01:25 PM
