Valve Seals
#2416343
12/10/17 06:18 PM
12/10/17 06:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When installing new valve seals do you guys heat them up in hot water then press them on.. I am trying to fix my W-5s so they are usable heads.. I leak checked them and look to be OK.. I think my issue was bad inner face between the intake and heads thanks
Re: Valve Seals
[Re: MR_P_BODY]
#2416402
12/10/17 08:38 PM
12/10/17 08:38 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I haven't, I just put a dab of oil and put them on. I have had trouble with valve stem seals twice over the last few years. First was in 2013 when I got my Edelbrock RPM heads back from shady dell. The engine was smoking and I couldn't figure out why. I milled the intake, i leaked it down, i had the guides checked, everything looked OK but there was oil puddling on the intake valve at shutdown and the headers were wet with oil. On one of my tear downs I noticed that Ryan used a different style seal than he had used when he had worked on the heads before, very similar but not the same. I talked to Ryan and he was out of the others and that these should be working fine. I changed them anyways and my problem was gone, I did 3 more drag weeks on those heads and maybe burned 2 quarts of oil between the three. Fast forward to 2015 when my dad and I built a W2 stroker for drag week. We ran the motor 42 miles on a test drive and it was smoking just like the RPM heads. We used all comp stuff for springs, seals, retainers etc. The comp seals were the same style I had problems with on the RPM heads. But I used comps cutter for the guide, and I felt they installed OK so we used them. When we pulled the 416 a week before drag week to put the 360 back in the headers were wet with oil. Summer of 2016 comes and I change the valve stem seals on the W2 motor and it put it back in and there was no smoke. The seals in the left of that picture above were the ones I had trouble with, I know lots of people use them but they didn't work for me. The one second from the left is what has worked great. I would recommend using that kind if at all possible.
68 Barracuda Formula S 340
Re: Valve Seals
[Re: Bad340fish]
#2416413
12/10/17 09:26 PM
12/10/17 09:26 PM
MR_P_BODY
Thanks for the feed back.. I bought seals like the ones in the middle.. did you just push them over the valve stems.. I worry about where the locks are on the stems.. My old set were the white ones( I believe they are a bit loose.. I measured the ID and they looked like the ID had no interference on the fit).. these W-5s have been a PITA since I bought them ... I will see this time.. I just wanted to run them mainly due to the weight reduction.. 40# on the front end is a lot
Re: Valve Seals
[Re: MR_P_BODY]
#2416456
12/10/17 10:13 PM
12/10/17 10:13 PM
Bad340fish
Tulsa OK
I know about the weight deal, I have W2 heads on an R1 block, it took four full turns on the torsion bars to get it to sit like the aluminum headed stock block 360.
I had one of those clear sleeves that slides over the top of the valve stem to help the seal slide over the grooves.
Re: Valve Seals
[Re: Bad340fish]
#2416475
12/10/17 10:34 PM
12/10/17 10:34 PM
MR_P_BODY
I had one of those clear sleeves that slides over the top of the valve stem to help the seal slide over the grooves. Where did you get that clear sleeve.. did you have to buy it? I'd like to use one of those thanks
Re: Valve Seals
[Re: MR_P_BODY]
#2416547
12/11/17 12:12 AM
12/11/17 12:12 AM
Bad340fish
Tulsa OK
I think that is where mine came from as well.
Re: Valve Seals
[Re: mkdart]
#2416550
12/11/17 12:15 AM
12/11/17 12:15 AM
MR_P_BODY
Mr.P, If you find out where to buy those sleeve's can you post it? Awhile back I was looking to buy them and could not find them. Dug through some old gaskets set's and found them in a pack of umbrella seals.
Mike I will let you know.. I see that Fel- Pro has them in their kits... I am looking to see if they sell them
Re: Valve Seals
[Re: MR_P_BODY]
#2416799
12/11/17 03:55 PM
12/11/17 03:55 PM
MR_P_BODY
I havent gotten any response from the seal companies yet on those installing sleeves.. with all the thousands of dollars that I have spent on tools and equipment you would think I would have something that would work.. but noooo... a couple of cheapo plastic sleeves and I cant even get a e-mail or phone call.. the problem is they dont even have a P/N on them so I cant even order them... a $.02 item and I cant find them.. the rest of the guys say they come with the seals.. not mine.. I dont want to just push them over the valve stem in fear of cutting them.. I just cant believe this... a lousy $.02 part is gonna hold me up OK... RANT off.. thanks for listening(if you did)
Re: Valve Seals
[Re: Bad340fish]
#2416833
12/11/17 05:08 PM
12/11/17 05:08 PM
MR_P_BODY
Thanks but I use 11/32 valves.. no problem I found what I need... plus a buddy is gonna give me a few.. he has a automotive machine shop.. he said he has a lot of them.. he also said that they normally come with a couple with each order but I sure didnt get any.. I called Summit and she didnt know what I was talking about.. I finally gave up.. but thanks for the help
Re: Valve Seals
[Re: MR_P_BODY]
#2416934
12/11/17 08:09 PM
12/11/17 08:09 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
You dont need the sleeve things. I never use them. Simply make sure the stem area is lubricated well ( I use Gibbs grease), and put your index finger on top of the seal opening. When you start to push the valve thru, your finger will support the seal, and the valve will nicely just slip thru.You will have no problems doing it that way. The seals wont tear or get damaged or anything, You will quickly get a feel for what I am saying after a couple.
RIP Monte Smith
Re: Valve Seals
[Re: CompWedgeEngines]
#2416938
12/11/17 08:20 PM
12/11/17 08:20 PM
MR_P_BODY
You dont need the sleeve things. I never use them. Simply make sure the stem area is lubricated well ( I use Gibbs grease), and put your index finger on top of the seal opening. When you start to push the valve thru, your finger will support the seal, and the valve will nicely just slip thru.You will have no problems doing it that way. The seals wont tear or get damaged or anything, You will quickly get a feel for what I am saying after a couple. Thanks for the help.. I will try it.. I was reluctant to try it being that these heads have been a major PITA from day one.. I have tried to get them on 3 different times(maybe 4) and they smoked each time.. I thought I did everything correctly but I guess I didnt
Re: Valve Seals
[Re: BradH]
#2416994
12/11/17 09:32 PM
12/11/17 09:32 PM
MR_P_BODY
Thanks.. I'm just being super cautious I guess when I put this thing back together AGAIN.. its had problem the past 3 or 4 times.. I'm doing everything by the proper method.. at least I believe.. I've done this stuff a ton of times but when its mine it wants to fail
