Shock setting for transbrake #2416091
12/10/17 07:49 AM
12/10/17 07:49 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ok finally get my new transmission this week , i hope 🤔. Nah should be good .
Anyway what if any change in rear shock adjustment should i think about ?
Currently footbrake no 2 step .
I do run radials , 28x10.5r15 pro bracket radials @16 1/4psi . I have Viking Crusader rear shocks , dbl adjustment and radial valving .
I have Caltracs .
Shocks are 10 from softest compression and 5 from softest on extension
I am hoping to get down towards a 1.45 sixty . Best currently is 1.47 with national event track prep , 1.48/.49 normally
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Shock setting for transbrake [Re: tex013] #2416478
12/10/17 10:39 PM
12/10/17 10:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
As someone was known to say on here, "tighter is faster".
Re: Shock setting for transbrake [Re: CMcAllister] #2416508
12/10/17 11:23 PM
12/10/17 11:23 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
huh ?
Tex
New best MPH 130.32
Re: Shock setting for transbrake [Re: tex013] #2416574
12/11/17 12:48 AM
12/11/17 12:48 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Video tape the launch from the side with an I-Pad/phone and replay the launch frame by frame. If you can see the tire driving down before the car starts moving you need to tighten the extension. You want the cars first movement to be forward. The compression for my car has always been an assomoter thing. If I can feel that it's too tight while driving through the pits, I loosen it up a tad. My car is more than 50% weight on the rear and is slammed to the ground though. I would tighten the extension from 5 clicks from tight the first time that you hit it. There really isn't a heavy shock to the ring gear foot braking. With a trans. brake the ring gear is hit and immediately wants to hit the ground.
Re: Shock setting for transbrake [Re: tex013] #2416598
12/11/17 01:38 AM
12/11/17 01:38 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Kool thanks Dave .
I only have 1 video of a launch in slomo .it does show some tyre sidewall wrinkle on the hit , so I will try some tighter ext
I know all the still shots show wrinkle .
Tex
New best MPH 130.32
Re: Shock setting for transbrake [Re: tex013] #2416628
12/11/17 03:01 AM
12/11/17 03:01 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The tire is going to do what it does. You should be able to add air pressure to the tires until it starts to slow the 60'. Run the most air you can without spin. Maybe in 1/2 pound increments or something. You've probably already been there and can try this again later. You are looking for excessive separation of the wheel from the body. I gained a bunch by limiting this. The old school book was 1" max. on a car like yours. Don't know if the trans. brake was included in the book calculation??? Just from the photo it looks as if it was set pretty good for what you were doing. up
Re: Shock setting for transbrake [Re: tex013] #2416638
12/11/17 03:44 AM
12/11/17 03:44 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i run Strange Dbl adjustables on my junk, my settings are 2 from total soft on compression & 2 from total stiff on extention. this usually gets me in the 1.2x 60's. its down side is, huge long wheelstands but i'm so use to it i dont even notice anymore.
Re: Shock setting for transbrake [Re: tex013] #2416663
12/11/17 05:56 AM
12/11/17 05:56 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks guys
Rebel i think i might need more omph to go where you do.
Dave , car seems happiest at this psi . I did start at 18.5 same as in Hoosier and et street radials i used to use .
This new motor wanted the new Viking rears and lower pressure to hook up .
So it will need some testng
Tex
New best MPH 130.32
Re: Shock setting for transbrake [Re: tex013] #2416676
12/11/17 08:28 AM
12/11/17 08:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The difference here is radials vs slicks. Radial will want more hit. Rather the try to hook of the bat I suggest you test with video and start over tight. Then move both adjustments a few clicks at a time until it hooks. You will need video as the amount of spin will change very little. 1/2 turn, 3.4 turn, 1 turn of the tire. Once there you can split the adjustment a few clicks and watch the video. Read up on how to see if you need to move the compression or rebound.It'll take time but you will know what adjustments do what on your particular car. look at some of Dizusters video's on You tube.
Doug
Re: Shock setting for transbrake [Re: tex013] #2416788
12/11/17 03:25 PM
12/11/17 03:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
huh ?
Tex
https://board.moparts.org/ubbthreads/ubbt...uys-inside.html
Re: Shock setting for transbrake [Re: tex013] #2416904
12/11/17 06:47 PM
12/11/17 06:47 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks for the input guys
Tex
New best MPH 130.32
Re: Shock setting for transbrake [Re: tex013] #2416920
12/11/17 07:34 PM
12/11/17 07:34 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
If the shocks are valved for your application, unfortunately no one will be able to tell you what number of clicks to use. A setting of 5 on your shock could be a 13 on mine. Best thing to do is call your shock guy and ask where to start.
They are the ONLY ones who know how your particular set of shocks are valved. Aanyone else is simply guessing.
