489 Case U-Joint U-bolt Straps
#2415569
12/09/17 01:36 AM
12/09/17 01:36 AM
Posts: 1,011 Central US
grancuda
Central US
Switching out a 3rd member & the one I'm sticking in doesn't have threaded holes. It has smooth holes & a flat area to put a nut on the back side. I went to Napa & they have no idea what part number for a U-bolt kit to bolt these up. They looked thru all different years & models & just come up with the formed flat piece of metal & little bolts. Anyone know what year/model would use the u-bolt style U-joint hold downs?
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: 489 Case U-Joint U-bolt Straps
[Re: buildanother]
#2415680
12/09/17 12:35 PM
12/09/17 12:35 PM
grancuda
Central US
It also looks like it has one of the locating tabs for one of the caps broke off. Am I seeing that right? Yes, I didn't even notice it had tabs to keep the u-joint cups in. I'm used to the snap rings that go around the inside of the caps retaining the U-joint cups. Looks like I just need a new yoke.
[Re: grancuda]
#2418233
12/13/17 11:43 PM
12/13/17 11:43 PM
grancuda
Central US
I lucked out & one of the tool makers at work was able to fix the yoke & the local, small town NAPA had the conversion U-joint in stock to go from the 7290 driveshaft yoke to the 1330 8 3/4" yoke. I was really surprised about that.
Now running the 2.94 open till summer & going to swap the 4.10 SG to either 3.55 or 3.73.
[Re: grancuda]
#2418264
12/14/17 12:50 AM
12/14/17 12:50 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Take apart and measure your "conversion" u-joint cross. You might find that the four cross ends are exactly the same, and only thing different are the caps.
[Re: BSB67]
#2418301
12/14/17 01:39 AM
12/14/17 01:39 AM
grancuda
Central US
Take apart and measure your "conversion" u-joint cross. You might find that the four cross ends are exactly the same, and only thing different are the caps. It is a SKF UJ458. It all measured out right as far as cap diameters/widths.
