CAN'T locate correct front wheel grease seals #2415502
12/08/17 11:29 PM
12/08/17 11:29 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
1968 Dodge Dart GTS, Front Disc Brakes.
Attached picture.
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2415522
12/09/17 12:02 AM
12/09/17 12:02 AM
WA
tman Offline
tman  Offline
WA
You check rockauto.com? Click on info for measurements on each part. I forgot for disc that 9 or 10" drum will work with Disc. One of the 2. Had same question like you for my Ebody. They don't say for Disc, just 9" or 10". Someone may know for sure.
Did you try local parts house?
Re: CAN'T locate correct front wheel grease seals [Re: tman] #2415528
12/09/17 12:17 AM
12/09/17 12:17 AM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
That is a SKF brand seal. Should be a number on it and any NAPA would be able to get them.
Dan.
Re: CAN'T locate correct front wheel grease seals [Re: mopar4ya] #2415533
12/09/17 12:21 AM
12/09/17 12:21 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Disc seals, are the same thing as 10 inch drum brake seals.
Just buy seals for 10" brakes.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2415578
12/09/17 01:53 AM
12/09/17 01:53 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi moe, try Timken #8121S . at napa or ? ... webster ma says hi. ronnie
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2415601
12/09/17 03:35 AM
12/09/17 03:35 AM
WA
tman Offline
tman  Offline
WA
That is the answer, 10" drums fit rotors.
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2415722
12/09/17 02:23 PM
12/09/17 02:23 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2418766
12/14/17 11:53 PM
12/14/17 11:53 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Thanks Guys. I have been sent the INCORRECT seals about 3 times.
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2418782
12/15/17 12:29 AM
12/15/17 12:29 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Why are they incorrect? What is incorrect about them? Got pictures?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2418824
12/15/17 01:51 AM
12/15/17 01:51 AM
md
mopars4ever Offline
mopars4ever  Offline
md
should be a number on the old one
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2418855
12/15/17 02:58 AM
12/15/17 02:58 AM
CA
crackedback Offline
crackedback  Offline
CA
Might help if people KNEW what seal number they sent you!
HemiX has the correct answer. The same as a 10" drum is the correct seal.
I bet they are sending the 73+ seal.
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2418909
12/15/17 10:52 AM
12/15/17 10:52 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Lots of the new seals dont have the rubber piece sticking out like OE did.Ive used bothe and never a problem.Rocky
Chrysler Firepower
Re: CAN'T locate correct front wheel grease seals [Re: Moe] #2420055
12/17/17 10:39 PM
12/17/17 10:39 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
Like others have said, all the seals and bearings I've taken off of cars have had numbers and manufacturer on them.
inherited a 69 roadrunner from my grand pop.
