#2408643 - 11/25/17 10:34 AM Ramcharger gas tank source?
ChallengerGary Offline
Loc: Boynton Beach, FL
My son's 1989 Ramcharger is leaking fuel. Anybody know where to buy a new gas tank?
#2408646 - 11/25/17 10:45 AM Re: Ramcharger gas tank source? [Re: ChallengerGary]
3hundred Offline
Loc: Fort Worth, Texas
They're made of unobtainium. Best option I know of is:
http://www.aerotanks.com/vehicles/dodge.html
If you're going to use the engine mounted fuel pump you'll be fine, otherwise you'll have to come up with an alternative electric fuel pump arrangement.
Robert
'68 Fury Convertible
'69 300 Convertible
'93 Ramcharger 5.7 Hemi
'93 Ramcharger 318 sold
'01 3500 4x4 Cummins 6 speed
'13 300 S
'15 Durango 5.7 Hemi
#2408674 - 11/25/17 11:51 AM Re: Ramcharger gas tank source? [Re: ChallengerGary]
amxautox Online   content
Still Retired. Still Posting on Moparts. A Lot.
Loc: On The Boat, On The Lake, Wa. ...
http://www.nwmp.com/
I got mine at the local 4x4 store.
it came from;
northwest metal products--(which is a subsidiary of s.ca. rv products, inc. - it says on the label)
nw mp forest grove, ill.
503-359-4427
Edited by amxautox (11/25/17 11:53 AM)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
#2408779 - 11/25/17 05:03 PM Re: Ramcharger gas tank source? [Re: ChallengerGary]
Hugh Jorgan Offline
Loc: Wills Point, Texas
#2408992 - 11/26/17 12:04 AM Re: Ramcharger gas tank source? [Re: Hugh Jorgan]
rhad Online   content
Loc: garnett kansas
have you considered using fuel tank liner,it comes by the quart and is simple to use and it works on metal tanks,i haven't tried it on plastic,but the manufacture should be able to tell you
the brand i used is called red kote,or redcote?
my ladder of success is missing some rungs
#2409080 - 11/26/17 10:10 AM Re: Ramcharger gas tank source? [Re: Hugh Jorgan]
Originally Posted By Hugh Jorgan
I would be fine with a good used one.
#2409081 - 11/26/17 10:11 AM Re: Ramcharger gas tank source? [Re: amxautox]
it came from;
503-359-4427
Looks like they don't make tanks anymore. They sold that part of their business and the new company does not list the RC as one they make. I will email them and see - thanks
#2412581 - 12/03/17 01:54 AM Re: Ramcharger gas tank source? [Re: ChallengerGary]
77ProStreet Offline
Loc: Marysville, WA
Not sure what size came on the Ram Chargers but I have a plastic one that came off my '80 D150. I think its an 18 gallon.
#2413520 - 12/05/17 09:25 AM Re: Ramcharger gas tank source? [Re: ChallengerGary]
the d150 tank is totally different than the '89 Ramcharger. The RC tank sits in the very rear of the truck between the frame rails. The D150 tank sits on the side of the bed on the outside of the frame rail.
BTW - solved the problem. Turns out it was a small crack. Was able to "plastic weld" it and now she's as good as new. While I was at it, I replaced the in-tank fuel pump and strainer. Glad I did that smile
#2414546 - 12/06/17 11:17 PM Re: Ramcharger gas tank source? [Re: ChallengerGary]
77ProStreet Offline
Loc: Marysville, WA
ChallengerGary,
My truck came with 2 tanks, one on the side and one in the back between the frame rails.
#2415024 - 12/07/17 09:35 PM Re: Ramcharger gas tank source? [Re: ChallengerGary]
poorboy Offline
Loc: Freeport IL USA
The rear tank on the pickups is a lot smaller the most RC tanks. Pickup rear tanks are usually 18 gal range and the RC tanks are in the 35 gal range, at least the ones around here were. I suspect the pickup tank would fit in the RC if you had the straps and sending unit. The RC tank is a lot deeper. Gene
25,083 Registered Members
185,757 Topics
Factory sunroof question
by FuryRoad
25 minutes 55 seconds ago
63 Sport Fury Goldencommando emblem placement
by GOLDENCOMMANDO
35 minutes 57 seconds ago
73-74 B-Body Odometer
by 340cpe
48 minutes 8 seconds ago
bucket seats
by rowin4
Today at 09:32 PM
