Oil pressure Question #241388
03/02/09 10:28 PM
03/02/09 10:28 PM
Denver Co.
BadBelvedere Offline OP
Denver Co.
I have a single line oil system on a big block.with a M63HV pump.and a Muscle Motors filter addaptor. I added a remote dual oil filter set up. will it afect the oil pressure? Thanks!
Re: Oil pressure Question [Re: BadBelvedere] #241389
03/02/09 10:33 PM
03/02/09 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No it wont, it'll require a little more oil to fill
it thats all
Re: Oil pressure Question [Re: BadBelvedere] #241390
03/03/09 12:23 AM
03/03/09 12:23 AM
If you use a Mopar- Ford type oil filter adapter it will have no affect on the oil pressure down low in the rpm range, it may have negative effect above 5500 rpm I had two dual oil filter mounts that did make the pressure drop above 5500 rpm. If you use a dual oil filter adapter that uses the GM filter it may affect the oil pressure as they are full flow filters with no internal bypass built in like the Ford/Mopar oil filters have
