tunnel Ram small Block #241343
03/02/09 09:00 PM
03/02/09 09:00 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
I want your guy thoughts on putting a holley pro dominator tunnel ram with two 1000 cfm hp holleys on my 398 small block. i got all the parts laying around so maybe i should just try it and see how it goes... what do you think? the car is a duster with fully ported w2's 2.08 intake valves 13.2 comp. 630/650 roller cam 1 7/8 headers 3.79 crank.torqueflite with brake dana 60,,4.88 gears 32 tire.6000 stall..indy intake and one 1000 cfm holley hp..car with driver 2750 lbs and runs 9.70 with good air right now,,soooo do you think the tunnel ram will make me happier as in lower et's and would it be as consistent as it is now,,which is very consistent,,,,,thanks
Re: tunnel Ram small Block [Re: Plymouth340] #241344
03/02/09 09:26 PM
03/02/09 09:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to run the Mopar tunnel on the same motor as
you are... but I had 2 junk carbs. I am planning on
building sheet metal tunnel and using a pair of 1050s,
I hope they arent too much.... so I say...try it
Re: tunnel Ram small Block [Re: Plymouth340] #241345
03/02/09 09:34 PM
03/02/09 09:34 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Thats a strong running w2 motor, I'd say your combo is about dead on imo. Although I'm biased because I'm a believer to the saying "If it ain't broke don't fix it"
Post deleted by Defbob [Re: MR_P_BODY] #241346
03/02/09 09:37 PM
03/02/09 09:37 PM
Re: tunnel Ram small Block #241347
03/02/09 09:43 PM
03/02/09 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Who's manifold is that? Are you running it on the
street
Post deleted by Defbob [Re: MR_P_BODY] #241348
03/02/09 09:50 PM
03/02/09 09:50 PM
Re: tunnel Ram small Block #241349
03/02/09 11:02 PM
03/02/09 11:02 PM
oregon
greendart408 Offline
oregon
Try it I am trying one as well for the first time.
Re: tunnel Ram small Block [Re: greendart408] #241350
03/02/09 11:23 PM
03/02/09 11:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
THe 1050's are probably going to be too big, but call quick fuel and get some info from them. A lot of people really like quick fuel carbs, especially the tunnel ram carbs they build.
Re: tunnel Ram small Block [Re: Dragula] #241351
03/02/09 11:40 PM
03/02/09 11:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had them convert my 1050 dom to E-85 and if I do the
tunnel I'll have them do the other 1050 dom I have
Re: tunnel Ram small Block [Re: MR_P_BODY] #241352
03/03/09 06:31 AM
03/03/09 06:31 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I had one. I was really amazed at the driveability it had. It was hard on the fuel though with the center squirter carbs. But really streetable as far as behaviour was concerned. Never got around to plimbing it up properly, but the car went two tenths quicker and it was a stock stroke 340. As Mr.Peabody kinda noted, you need good carbs.
Re: tunnel Ram small Block #241353
03/03/09 07:33 AM
03/03/09 07:33 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
i'm trying one on mine. [image][/image]
STAMPED ROCKER ARMS
What is your combo have you run the tunnel ram already ?
good luck
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: tunnel Ram small Block [Re: 10 o to go] #241354
03/03/09 07:51 AM
03/03/09 07:51 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I can tell you about my setup - mostly street - some strip
back to back testing went 12.56 @ 106 with the t-ram and 13.2 @ 102 with a ported cast iron intake
2-390 cfm holley vac secondaries on the t-ram and a holley 780 vac sec on the single.
60' times were 1.74 with the t-ram
1.82 on the 4 bbl
mileage was 16 on the highway for the t-ram, never checked with the single
with 3.23's and in a street car the setup would act like a single 4, had the scoop not been through the hood you would never know !
Re: tunnel Ram small Block [Re: Hot 340] #241355
03/03/09 08:21 AM
03/03/09 08:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
In a race application I would never use the vac secondary
carbs again... fine for the street
Re: tunnel Ram small Block [Re: MR_P_BODY] #241356
03/03/09 10:02 AM
03/03/09 10:02 AM
Dragula Offline
Dragula  Offline
When I called Quick Fuel about carbs for mine, they recomended dual 750 Annular carbs...Not cheap, but I am sure they would work very well. I currently run one of their 850 annular race carbs on an air gap intake, and I have to say its the best carb I have ever had.
Re: tunnel Ram small Block [Re: Dragula] #241357
03/03/09 10:08 AM
03/03/09 10:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the same Holley manifold you show there and
sold my Mopar manifold(should have kept it) but I
will build a sheet metal one for my new set up
Post deleted by Defbob [Re: 10 o to go] #241358
03/03/09 01:14 PM
03/03/09 01:14 PM
Re: tunnel Ram small Block #241359
03/03/09 01:19 PM
03/03/09 01:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume you have a hyd cam in there... that would be
my concern at the higher revs... hyd dont like alot of rpm's
Re: tunnel Ram small Block [Re: Hot 340] #241360
03/03/09 01:53 PM
03/03/09 01:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Check out this Tunnel Ram Small block, talk about "Day 2", this was in the May 1972 Drag Illustrated magazine and it's a 1971 Duster!
Re: tunnel Ram small Block [Re: ScottSmith_Harms] #241361
03/03/09 01:54 PM
03/03/09 01:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: tunnel Ram small Block [Re: Hot 340] #241362
03/03/09 02:48 PM
03/03/09 02:48 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I had the Weiand T/R also, it was a kit from
Summit and came with 2 / 450 mech sec. Holley's.
It was on my 67 Cuda. Stock 340 with a Lunati
BR II cam. 22 years ago it made for a cool
looking combo, and ran fine on the street.
Ran 12.20's at the track, and never ran it over
6200 rpm.
I think 2 Dom's are a bit much, but if it's all
you have, go for it.
Snap your neck, mega G-force launch, is all I want!
