Re: Original headlights
[Re: 4406bbl]
#2412689
12/03/17 03:51 PM
12/03/17 03:51 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
One other variation is that superbirds had 2 ge bulbs and 2 westinghouse, cant remember for sure which were highs or lows, think highs were westinghouse. The headlamps on my Superbird all appeared to be original with correct date codes. All 4 were Westinghouse. Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: RealWing]
#2412841
12/03/17 10:17 PM
12/03/17 10:17 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
One other variation is that superbirds had 2 ge bulbs and 2 westinghouse, cant remember for sure which were highs or lows, think highs were westinghouse. The headlamps on my Superbird all appeared to be original with correct date codes. All 4 were Westinghouse. Jim Same with my bird.
[Re: B5Cuda440-6]
#2413127
12/04/17 04:13 PM
12/04/17 04:13 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I believe "4-8" is for April 8 1968.
Do others believe this to be correct? That would be my guess too but didn't know for sure. Incidentally, my SPD is September 10th 1968, so perhaps a five month vendor supply time?
[Re: hemi70se]
#2413699
12/05/17 06:06 PM
12/05/17 06:06 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
The GE bulbs are just dated with month-year so 4 68 is April of 1968. When considering which type is correct, GE or Westinghouse, you need to think about WHERE your car was built. I have had a bunch of Lynch road cars and they all seem to be Westinghouse. This would include Superbirds. St. Louis cars seem to all be GE. All the musclecar area bulbs would be the wide flute design. I think the narrow flute didn't appear until 73-74 era. Also it is just needless to search for proper date codes as they are only ink stamped on the backside and you can't tell a 1965 bulb from a 1971 on the front side. Exactly - when and where matters LA cars I believe were Westinghouse.
[Re: hemi70se]
#2413789
12/05/17 08:09 PM
12/05/17 08:09 PM
CompSyn
Pacific NW USA
The GE bulbs are just dated with month-year so 4 68 is April of 1968. When considering which type is correct, GE or Westinghouse, you need to think about WHERE your car was built. I have had a bunch of Lynch road cars and they all seem to be Westinghouse. This would include Superbirds. St. Louis cars seem to all be GE. All the musclecar area bulbs would be the wide flute design. I think the narrow flute didn't appear until 73-74 era. Also it is just needless to search for proper date codes as they are only ink stamped on the backside and you can't tell a 1965 bulb from a 1971 on the front side. I didn't think anyone within this thread stated they were actively searching for correct/matching headlight date codes? I was simply referencing the date code on mine to identify what may be an original brand/type to come on my car. That said, can you fill me in on wide-flute versus narrow-flute head lights? Not sure what that means?
