1970 Challenger - Brake Lights Not Working
#2412371
12/02/17 08:23 PM
12/02/17 08:23 PM
Posts: 238 Florida, US
72ls5fla
Florida, US
Hey ...
No brake lights .. Switch is ok - works as intended. I get flashers, directionals and parking/running lights. So I know the bulbs are okay.
If I bypass the BL switch - same issue.
Also- car has new dash harness, new ignition switch but original turn switch. I checked pins on the turn switch connector, they look to be on good condition - no corrosions and the coupler makes a nice tight connection.
This is a new problems - they were working fine a week ago when I drove to s swapo meet/car show.
Where else can I look ??
Not sure of the BL circuit, so don't know where else to trouble-shoot.
Thanks in advance --
Bill
Got me a NEW Project 1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior. Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: 1970 Challenger - Brake Lights Not Working
[Re: michiganhotrod1]
#2413375
12/05/17 01:29 AM
12/05/17 01:29 AM
72ls5fla
Florida, US
Many thanks!!
Will check the wiring running through the coupler on the turn switch harness.
thanks for the insight on the 70 vs. 71-74 switch type differences. I like the fix you figured out :-)
Bill
