Re: SB PRO STOCK
[Re: A/MP]
#2410592
11/29/17 10:43 AM
11/29/17 10:43 AM
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: SB PRO STOCK
[Re: A/MP]
#2410633
11/29/17 12:31 PM
11/29/17 12:31 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
It is an P5 head on an R4 block. Was originally developed by Mopar for Pro Stock Truck with Rick Waters and others. It was the replacement for the W8 stuff they had been using. Cavallo was originally an RWR customer til be went to Book. Awesome parts EXCEPT there are no blocks and you really need the billet head otherwise its a crap shoot on whether they will be good or not. There are a few P5 deals running here in Comp as well, most at 358". It is a very good platform unfortunately with little aftermarket support. Billet heads are produced but blocks are a big issue. Other than possibly a billet block. There was also a "clamshell" version of the P5 head. There is a pair in the classifieds here. There are a few differences in that head and the later P5 stuff. The later heads looks more like an asymetrical 99 Hemi head, which is still used in Pro Stock along with the symmetrical version.
Re: SB PRO STOCK
[Re: Al_Alguire]
#2410737
11/29/17 03:52 PM
11/29/17 03:52 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
...there are no blocks - blocks are a big issue. ...and there you have it.
Re: SB PRO STOCK
[Re: Biginchmopar]
#2410885
11/29/17 07:34 PM
11/29/17 07:34 PM
Posts: 6,138 Melbourne , Australia
LA360
Question? Can a Ritter Block support the P5 head? I thought a Ritter could be machined to except a Baby Hemi? More than likely, it would have to be ordered with blank lifter bores and deck surface. However, it would be no good for Aussie Pro Stock and what was Bob Book's NMCA class. The deck height is too high, far, far too high, many of these engines are around the 8.35" deck height. Lower if the casting allowed. The P5 cast heads tend to crack in the intake bowls, probably what drove companies to make billet versions. VED were the first, although the Slawko offerings are what Bob Book has had success with. CFE offer a billet P5 also. I have been told that MBE make a billet P5, but I've only seen their ported cast heads. As Al said, blocks are the real issue. The recent castings are flimsy, the take 8 sleeves, an almost complete fill with grout and they still beat the pistons skirts up in half the time.
Alan Jones
Re: SB PRO STOCK
[Re: A/MP]
#2411211
11/30/17 12:25 PM
11/30/17 12:25 PM
Al_Alguire
Las Vegas
I believe there are three teams using them. From what I saw at RWR those teams have multiple engines and parts. I recall pallets of heads and blocks at one point on the floor at RWR for one team.
Slawko's heads seem to be the best version going right now. Just not enough parts out there for many to persue this combo. There are a couple of comp teams but they either bought old Pro Stock truck operations or ran PST back in the day. The Mettler Brothers in Cali are one of those teams. From what Ive seen block prep pretty much what has already been said.
Re: SB PRO STOCK
[Re: A/MP]
#2411273
11/30/17 02:06 PM
11/30/17 02:06 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
Isn't this the same type of combo that the copper colored challenger from Texas was running is X275? Marty Pearcy? Whatever happened w/ that car?
Re: SB PRO STOCK
[Re: A/MP]
#2411314
11/30/17 03:32 PM
11/30/17 03:32 PM
Al_Alguire
Las Vegas
Yes he was with billet heads and block as I recall. The car was for sale last year or so. Not sure what happened with it or if Marty still has it..
Re: SB PRO STOCK
[Re: Al_Alguire]
#2411318
11/30/17 03:49 PM
11/30/17 03:49 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I always wondered why Jegs still lists some of these blocks and even lists a shipping date.
Re: SB PRO STOCK
[Re: pittsburghracer]
#2411436
11/30/17 07:57 PM
11/30/17 07:57 PM
LA360
Pro Stock rules over here mandate a mopar block with a mopar head. So they're in the same boat as everyone else. Billet blocks aren't allowed in the class.
Marty Pearcy runs an aluminium A block, it was some prototype block or something like that.
A partially machined R3 could be used, but the deck height is too tall for these guys.
The current casting blocks are too thin, they will run out eventually. To be as good as the Ford and Chevy blocks, the R4 needs a redesign
Alan Jones
Re: SB PRO STOCK
[Re: scottb]
#2411505
11/30/17 10:58 PM
11/30/17 10:58 PM
LA360
Mason Baxter, put in a lot of leg work, tried to obtain all the patterns from Mopar. Despite his efforts, couldn't get it done. He's a pretty stand up guy. He was looking to do a tall deck 48* R3 block and seeing how he went. No R4 blocks though.
Alan Jones
