Hellcrate - what else is needed? #2410586
11/29/17 10:24 AM
11/29/17 10:24 AM
Bowling Green, KY
BlakDak71 Offline OP
Bowling Green, KY
With Mopar coming out with the Hellcrate 6.2L setups, it got me wondering what else would be needed to run one of these. There was no mention on their press release of any of the low-temp radiator cooling circuit for the supercharger. I know on production vehicles, there is an oil filter adapter with two ports in it that run to the heat exchanger behind the fascia. There is also a low temp radiator on the other side of the fascia, as well as a dedicated pump and cooling circuit.
Does anybody have a complete list, maybe part numbers for somebody who is considering making the swap? Seems kind of important, surprised Mopar didn't have an add-on kit like they do for the FEAD/AC expansions.
Re: Hellcrate - what else is needed? [Re: BlakDak71] #2410685
11/29/17 01:48 PM
11/29/17 01:48 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I'd contact the Graveyard carz guys about what would be needed , they did a Superbird with a Hellcat crate engine.
Re: Hellcrate - what else is needed? [Re: BlakDak71] #2411154
11/30/17 04:55 AM
11/30/17 04:55 AM
Northern California
B5 Classic Offline
B5 Classic  Offline
Northern California
You have to consider that all the external cooling components outside of the engine are designed for the late model cars that they come in. Mopar sells OEM parts and has no idea what all cars this engine will end up in and which OEM Hellcat parts would fit them.
I have a Hellcrate on order, expected in about a week. It will be going in my '69 Cuda. I expect to have to figure out what areas would be good for inter coolers and research what (probably aftermarket) inter coolers will work.
The Hellcrate and its accessories are designed for plug and play. If you want one, don't be afraid of it. Your biggest concern will be in reinforcing the chassis, tubbing wheel wells, etc so the car can handle the power and get traction. Oh, and brakes.......don't forget good brakes!
Re: Hellcrate - what else is needed? [Re: B5 Classic] #2411162
11/30/17 05:55 AM
11/30/17 05:55 AM
Kirkland, Washington
Pacnorthcuda Offline
Wow! Welcome to Moparts!!! Please tell us you will be providing pics and info on this project!
This will be of great interest!
Re: Hellcrate - what else is needed? [Re: BlakDak71] #2411248
11/30/17 01:17 PM
11/30/17 01:17 PM
Northern California
B5 Classic Offline
B5 Classic  Offline
Northern California
Thanks for the welcome. I would love to post a thread here but have been using an IPad for a while and am not sure how to post pics with it. It was difficult with my last laptop too because I couldn't figure the newer operating system. I do have a thread over on FABO, but the pic site I was using now wants fees to use them and all my posted pics there went away. What's an old dinosaur like me to do? I can't keep up with all these technology (advancements?). The thread there included a 6.1 based 392 that was intended for the car but I'm moving on to the Hellcrate.
The new systems for these crate motors are really plug and play. They're very "stand alone" except for just a few wires that integrate into whatever main wiring system is in you car.
Re: Hellcrate - what else is needed? [Re: BlakDak71] #2560678
10/08/18 02:36 AM
10/08/18 02:36 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I bought one a month ago, its in and running, with 6 speed trans
Re: Hellcrate - what else is needed? [Re: 70blackfish] #2561701
10/10/18 12:17 AM
10/10/18 12:17 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
