Bronze Lifter Bore Bushing on the Street - Experience?
#2410409
11/28/17 11:34 PM
11/28/17 11:34 PM
Posts: 4,277 Morrow, OH
markz528
Morrow, OH
How much do bronze lifter bore bushings wear with a .650 lift mechanical roller cam? How will they survive on the street?
My bores are bad and need to be bushed.
Any experience running bronze lifter bore bushings on the street?
Re: Bronze Lifter Bore Bushing on the Street - Experience?
[Re: markz528]
#2410413
11/28/17 11:41 PM
11/28/17 11:41 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
They are fine if the clearances are set right, they are honed round ( or bored on Rottler etc) and you get the right size oil hole for the application. I used to use one brand of lifter bushing, but have since switched to another brand, which seems to be a little more robust in the wear department.Its really all a case of having everything set up right for the combination and block ( oiling etc). I have more and more people bushing blocks now than before, and all without issue. Street and strip. Most will say ( or argue) , you should have cast iron for street use. Cant completely argue that, but it will really depend on how the car is used, miles, spring and lifter arrangements etc. There is more to it than just, " will it work", but for me, I wouldnt be afraid at all if done right.
RIP Monte Smith
[Re: markz528]
#2410414
11/28/17 11:41 PM
11/28/17 11:41 PM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
Ran them with a 699/672 roller in a small block for the 6 or 7 years i had that motor in a car i used to own. Zero issues. Ran the car on the street a bunch
[Re: CompWedgeEngines]
#2410461
11/29/17 12:57 AM
11/29/17 12:57 AM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
They are fine if the clearances are set right, they are honed round ( or bored on Rottler etc) and you get the right size oil hole for the application. I used to use one brand of lifter bushing, but have since switched to another brand, which seems to be a little more robust in the wear department.Its really all a case of having everything set up right for the combination and block ( oiling etc). I have more and more people bushing blocks now than before, and all without issue. Street and strip. Most will say ( or argue) , you should have cast iron for street use. Cant completely argue that, but it will really depend on how the car is used, miles, spring and lifter arrangements etc. There is more to it than just, " will it work", but for me, I wouldnt be afraid at all if done right. Well said
[Re: markz528]
#2410600
11/29/17 11:05 AM
11/29/17 11:05 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
My X block small block has the lifters bushed with bronze bushings, no oil holes. It was ran for 560 passes as a bracket car before I bought it with a 296/557 MP cam. I put a Hughes flat tappet in it, around .580 lift, and put 120 more passes on it before I converted it to a street car and did Drag Week twice (about 2700 street miles). Then I stroked it with a bigger arm, went to a .600 lift flat tappet from Comp, and have since finished four more Drag Weeks and local cruises (about 5100 miles) and another 55 passes. So far, so good, no cam/lifter issues. 10.39-128 motor, 9.43-139 on a 165 shot.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: markz528]
#2410666
11/29/17 01:16 PM
11/29/17 01:16 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
FWIW...my KB aluminum hemi block has no oiling to the lifters (solid rollers). Just a straight aluminum bore. Been that way for 10+ years now w/ a good bit of street time, no noticeable wear.
[Re: an8sec70cuda]
#2410716
11/29/17 03:18 PM
11/29/17 03:18 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
FWIW...my KB aluminum hemi block has no oiling to the lifters (solid rollers). Just a straight aluminum bore. Been that way for 10+ years now w/ a good bit of street time, no noticeable wear. Just curious if you or anyone running a aluminum block with out lifter bore sleeves have checked the lifter bores with a bore gauge to see if they have started to get egg shaped from ware.
#2410728
11/29/17 03:36 PM
11/29/17 03:36 PM
BradH
They are fine if the clearances are set right, they are honed round ( or bored on Rottler etc) and you get the right size oil hole for the application. My ... don't use them without oiling holes to lube the bushing. About 5K miles on bronze-bushed lifter bores with a .400"-lobe SFT and NO oiling holes left definite wear "steps" in the bushings at the tops of the lifters' rise in the bushings. I've since switched to solid rollers and added holes to the bushings. I added the holes for the pressure-fed roller bearings, but in retrospect should have added them years earlier. The taller lifter bodies sit above the wear steps left from the flat-tappet lifters, so that doesn't appear to be an issue... at this point.
[Re: BradH]
#2410743
11/29/17 04:02 PM
11/29/17 04:02 PM
CompWedgeEngines
Syracuse,NY
They are fine if the clearances are set right, they are honed round ( or bored on Rottler etc) and you get the right size oil hole for the application. My ... don't use them without oiling holes to lube the bushing. About 5K miles on bronze-bushed lifter bores with a .400"-lobe SFT and NO oiling holes left definite wear "steps" in the bushings at the tops of the lifters' rise in the bushings. I've since switched to solid rollers and added holes to the bushings. I added the holes for the pressure-fed roller bearings, but in retrospect should have added them years earlier. The taller lifter bodies sit above the wear steps left from the flat-tappet lifters, so that doesn't appear to be an issue... at this point. thumbs up on that.
RIP Monte Smith
[Re: RATTRAP]
#2410754
11/29/17 04:16 PM
11/29/17 04:16 PM
an8sec70cuda
FWIW...my KB aluminum hemi block has no oiling to the lifters (solid rollers). Just a straight aluminum bore. Been that way for 10+ years now w/ a good bit of street time, no noticeable wear. Just curious if you or anyone running a aluminum block with out lifter bore sleeves have checked the lifter bores with a bore gauge to see if they have started to get egg shaped from ware. I have not, but I do check them for wear w/ the lifters at teardown. Kinda like checking valveguides, you get a feel for it. I've been surprised they haven't felt like they're loosening up.
#2411057
11/30/17 12:14 AM
11/30/17 12:14 AM
markz528
Morrow, OH
They are fine if the clearances are set right, they are honed round ( or bored on Rottler etc) and you get the right size oil hole for the application. I used to use one brand of lifter bushing, but have since switched to another brand, which seems to be a little more robust in the wear department.Its really all a case of having everything set up right for the combination and block ( oiling etc). I have more and more people bushing blocks now than before, and all without issue. Street and strip. Most will say ( or argue) , you should have cast iron for street use. Cant completely argue that, but it will really depend on how the car is used, miles, spring and lifter arrangements etc. There is more to it than just, " will it work", but for me, I wouldnt be afraid at all if done right. Thanks for all the replies! Based on feedback, I'm taking it to a different vendor than I planned. The new vendor will do it on a Rottler CNC. The others do it on a Bridgeport with a jig.
[Re: markz528]
#2411059
11/30/17 12:20 AM
11/30/17 12:20 AM
Superfreak
Superfreak
I just got my new hemi iron block from FHO yesterday and the lifter bores are bushed with the oil holes and this will be a street/strip combo.
[Re: markz528]
#2411279
11/30/17 02:16 PM
11/30/17 02:16 PM
Posts: 8,311 fredericksburg,va
cudaman1969
fredericksburg,va
Wasted effort for the street. Like putting on a fire suit to go to the grocery store.
#2411315
11/30/17 03:37 PM
11/30/17 03:37 PM
Posts: 292 NY
challenger451ci
NY
They are fine if the clearances are set right, they are honed round ( or bored on Rottler etc) and you get the right size oil hole for the application. My ... don't use them without oiling holes to lube the bushing. About 5K miles on bronze-bushed lifter bores with a .400"-lobe SFT and NO oiling holes left definite wear "steps" in the bushings at the tops of the lifters' rise in the bushings. I've since switched to solid rollers and added holes to the bushings. I added the holes for the pressure-fed roller bearings, but in retrospect should have added them years earlier. The taller lifter bodies sit above the wear steps left from the flat-tappet lifters, so that doesn't appear to be an issue... at this point. thumbs up on that. Anyone have a trick for drilling oil holes on bushed lifter bores that are already installed? We have a block that was bushed with no oil holes. It took out a lifter. Not saying it was 100% caused by the lack of oil feed, but I'd sleep better knowing it had some pressure feeding the lifter bores this time around.
[Re: challenger451ci]
#2411364
11/30/17 04:54 PM
11/30/17 04:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
MP use to sell a lifter tool that would work.. I have one that I bushed down so I could do it.. normally you would have the bushing drilled before pressing it in... The tool is P4120603.. its part of the reaming package for drilling and reaming a SB for doing roller lifters.. I pressed in a piece of steel then drilled it for a .030 drill bit.. you might see if that will work(the tool was cut on a angle to intersect the bushings)
[Re: rebel]
#2411379
11/30/17 05:25 PM
11/30/17 05:25 PM
dogdays
It seems that some people DO need that firesuit!
There are plenty of bronze valve guides running around on the streets.
Would a pro answer this question? Is there any difference between bushing the block using a jig or by using a Bridgeport milling machine? Seems to me if the machinist took time to measure the spacing it would be as good as using a jig. Probably the jig would take less setup time though.
R.
[Re: MR_P_BODY]
#2411487
11/30/17 10:29 PM
11/30/17 10:29 PM
Posts: 292 NY
challenger451ci
NY
MP use to sell a lifter tool that would work.. I have one that I bushed down so I could do it.. normally you would have the bushing drilled before pressing it in... The tool is P4120603.. its part of the reaming package for drilling and reaming a SB for doing roller lifters.. I pressed in a piece of steel then drilled it for a .030 drill bit.. you might see if that will work(the tool was cut on a angle to intersect the bushings) Ok, I think I follow. Basically I need to make a solid slug that fits the lifter bore. Drill a hole at an angle and use it as a guide. Makes sense. Thanks!
[Re: cudaman1969]
#2411690
12/01/17 10:13 AM
12/01/17 10:13 AM
BradH
No, they don't, but they fool themselves into thinking they do. In my case it was because the lifter bores were scored badly from the debris when my SFT cam started eating lobes about 1200 miles after break-in. I wasn't fooling myself about needing to bush the lifter bores in order to salvage the block. Another viable reason is when the factory lifter bores are not sized properly for the proper clearance with the chosen lifters, especially with rollers. I've seen close to .001"difference between body diameters of different manufacturers, yet the clearance is supposed to be only .002".
[Re: dogdays]
#2411700
12/01/17 10:36 AM
12/01/17 10:36 AM
Posts: 3,089 Michigan
A727Tflite
R. - a jig used just to install the bushing will not correctly locate the bushing centerline relative to the cam and crank center lines. A milling machine set up to locate off the mains will properly locate the lifter center lines.
[Re: markz528]
#2411734
12/01/17 12:25 PM
12/01/17 12:25 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I would not bush lifter bores on a iron or aluminium since the charateristics on cast material is porous and retains lubercation.Bushing lifter bores should be done to correct any misalignment such as spacing or angle.Bronze/bronze alloy bushings are hard and dense.Hard steel lifters on a hard bronze bore = wear.Before everyone goes off on my statement let me say that any race application can run that combination because of the run time compared to a long duration street driven engine.Nascar used to use a cast iron sleeve to bush the lifter bores for correcting production blocks,now most topline builders machine the bores in aftermarket blocks that they get with no bores so they can set the spacing and angles where they need for the specific applications.We have purchased blocks with bushed bores for specific customers at their request and found alignment issues since all that was done was the bores were bored and bushing pressed in.When having this done be specific to who is doing the work and have the spacing and angle refrences.There is a need for the process but not for street use,$600 can be better spent on other performance products and mods. Respectfully Bob George
[Re: markz528]
#2411965
12/01/17 09:04 PM
12/01/17 09:04 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
The R1 block in my car has bushed bores and after around 2000ish miles they "felt" good when I had the intake off not to long ago. I did over 1000 of those miles in 4 days on 1 oil change.
I killed a bronze gear in about 3000 miles back in 2012. I was running rotealla 15W40 and had more oil pressure than I needed. I went to a thinner oil to lower the oil pressure and I put 6000-8000 miles on the next gear and it still looks great.
68 Barracuda Formula S 340
[Re: B G Racing]
#2412013
12/01/17 11:20 PM
12/01/17 11:20 PM
cudaman1969
fredericksburg,va
I would not bush lifter bores on a iron or aluminium since the charateristics on cast material is porous and retains lubercation.Bushing lifter bores should be done to correct any misalignment such as spacing or angle.Bronze/bronze alloy bushings are hard and dense.Hard steel lifters on a hard bronze bore = wear.Before everyone goes off on my statement let me say that any race application can run that combination because of the run time compared to a long duration street driven engine.Nascar used to use a cast iron sleeve to bush the lifter bores for correcting production blocks,now most topline builders machine the bores in aftermarket blocks that they get with no bores so they can set the spacing and angles where they need for the specific applications.We have purchased blocks with bushed bores for specific customers at their request and found alignment issues since all that was done was the bores were bored and bushing pressed in.When having this done be specific to who is doing the work and have the spacing and angle refrences.There is a need for the process but not for street use,$600 can be better spent on other performance products and mods. Respectfully Bob George Thank you for explaining it better than I did. Mike
[Re: cudaman1969]
#2412035
12/02/17 12:15 AM
12/02/17 12:15 AM
CompWedgeEngines
Syracuse,NY
I'll maintain my position, thats it is not a problem, when done right. I understand the cast iron bore, and that thought, and wont argue that. Going back to what was said earlier, this is the reason a oil hole of PROPER size is used. The wear is almost nill at that point, as the oil helps immensely.
I still like the idea of 1) correcting the bores to where they SHOULD have been in the first place. If you do enough of these, and the other two corporate brands, you will see how bad they are.2) making the clearances where they need and should be to begin with. ( yes, same can be said for cast iron) 3) Controlling oil pressure to where you want it to go. ( this can go in a lot of different directions, but depending again, on the application, it may be more critical than you think. 4) If you EVER have the misfortune of popping or breaking a lifter, you are not going to trash your engine due to no oil pressure and 5) kinda goes along with # 2, making the holes round, mosty impiortant on used hi mileage blocks. Its not uncommon to see +.002-.003 wear or more.Do enough of them. and you will see it.
Bob, if your getting blocks that have just have bushing " popped in", without fixturing, you better find a new guy!( unless it is a Rottler type deal)...lol..as you know, thats no good. There are some places that offer a reamer to repair a single bore, which doesnt correct anything, but does make the bore servicable again. Thats a totally different deal.I have a shop that borrows my extended hone all the time to repair damaged bores.
Everyone will have a different " opinion" on this. As always, I will go with what has worked for me without fail over 25 years.Would I take a new block and put bushings in it " just to feel good" ? Hell no. You get a feel for who's stuff is good and who's isnt after doing many other the aftermarket blocks like Dart , World etc, for BBC, SBC and BBF and so forth. Most hi end BBC and BBF etc are running Mopar .904 lifters and bigger anyways, so if its a Ford Motorpsorts block, or a Dart Big M, and it wasnt running anything other than STD bores, most will bore and correct to .904 to begin with to take advantage of that lifter size and how it can help.
I am of the opinion, the oil is an issue, but again, I have not seen the wear with oiling holes for the most part. I do believe along with RobR about the street driven oil, but a couple things come into play along those lines. Most street drivers, will often buy more generic oils. Racers typically buy a bit more robust oil.( No , please dont get the oil debate started again..please dont) Couple that with the fuel dilution that is much higher in a street application, and the oil simply isnt doing the job it may in a race motor.( which also are often higher viscosity, although that trend is slowly changing a bit) Couple that with racers ( the good ones...lol) change their oil pretty religiously. A street guy, maybe, maybe not.Like I said, a lot of fuel contamination, and dirt infiltration from street driving.
Lets face it, much of the Mopar machining left a lot to be desired in the factory stuff.
Is there anything wrong with cast iron bores? Nope. Does every street engine NEED bushings? Nope.Is there anything wrong with taking advantage of the positives of bushing a block? Nope. The debate will rage on after we're too old an tired to talk about it, so it comes down to builder/owner interaction and discussion, and somewhere in that , they decide what they want to do.
RIP Monte Smith
[Re: markz528]
#2412073
12/02/17 02:10 AM
12/02/17 02:10 AM
markz528
Morrow, OH
Thanks again for all the replies! All of them are greatly appreciated.
What I did not say is that this is a brand new cast iron block and the lifter bores are terrible. This is not from normal wear but from bad machining.
The bores have a surface finish of between 100 and 115 microinches Ra. They should be around 32 Ra although I do know enough about surface finish to know that Ra doesn't tell the whole story but 115 is so bad that it doesn't really matter what the peaks and valleys are. I have significant experience with cast iron surface finishes and understand the significance of poor surface finish. 7 of the bores also have a nasty taper - 0.0014 inches down about 0.5 inches.
I considered trying to run these bores since the short block was already assembled but I came to my senses and no way do I want to run the bores in this condition.
The block is now disassembled and in good hands and will get the bores bushed along with some other corrections.
#2412190
12/02/17 12:21 PM
12/02/17 12:21 PM
B G Racing
Eighty Four, PA
Bob, if your getting blocks that have just have bushing " popped in", without fixturing, you better find a new guy!( unless it is a Rottler type deal)...lol..as you know, thats no good. There are some places that offer a reamer to repair a single bore, which doesnt correct anything, but does make the bore servicable again. Thats a totally different deal.I have a shop that borrows my extended hone all the time to repair damaged.
I understand,blocks are offered from manufactures and suppliers with bushed lifter bores.Even though they may have corrected to the correct specs for the engine design,it may not be for the end users application ie: changes in rockers& geometry,changes in deck height and angle or a different head design. We ran into these problems when using StageV Millinium Hemi heads on a standard deck and a standard cam height block and found that the pushrod holes ran into the cylinder liner.We had to tilt the angle of the lifter a few degrees up to get the hole away from the bore.Now we get the raised cam block with the lifter bores spread .050 and upward angle tilt and no need for bushing.This was why I commented that the correct specs for a specific application needs to be considered for bushing bore.I still maintain that for street use it is not necessary. I respect everyone opinions and experiences that have been shared here,a lot of good info,and agree lets not get into an oil debate. Respectfully Bob
[Re: B G Racing]
#2412226
12/02/17 01:45 PM
12/02/17 01:45 PM
CompWedgeEngines
Syracuse,NY
Boy, we could really go off into hyper space if we start talking about current quality control issues couldnt we????....I dont think I have enough blood pressure medicine for that.
Here's the good news, from my birds eye, head janitors position view, here at CWE ( I like to better refer to it as Janitorial Executive,although I may be fired today, we were out of crapper paper this morning)......lol...the original poster, is now better informed, has made a decision, and I think everyone feedback has helped, we all shared some different viewpoints and thats a win for us all.
RIP Monte Smith
